mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Oct 1, 2013 at 6:59 PM
    #141
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So when you did your tubing you did the drill holes and tac method yes? after that did you weld a solid seam on the top edge of the new metal plates??
  2. Oct 1, 2013 at 7:33 PM
    #142
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Yup. Drilled holes...filled the holes then welded around the entire perimeter of the plates.
  3. Oct 1, 2013 at 7:47 PM
    #143
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool man. Thanks.
  4. Oct 2, 2013 at 9:47 AM
    #144
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
    I just got over wanting 35's... now i want them again lol. Your truck looks awesome man! What are you planning for a rear bumper?
  5. Oct 2, 2013 at 11:44 AM
    #145
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Haha thanks man! 35's are sweet! Everyone that looks at the truck asks if they are 37's just due to the fact that its a small truck. With big tires :) haha
    I don't know what Im gonna do for a bumper. Still waiting for this one to rip off. I've tried a number of times, and have come up unsuccessful haha. I would like to do a plate bumper eventually....who knows.
  6. Oct 2, 2013 at 11:48 AM
    #146
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    You should make templates for the tubbing! :D
    I'd buy one... :spy:
  7. Oct 2, 2013 at 12:15 PM
    #147
    04Tacomabuild
    Reese
    Kenora, ON, Canada
    They just look more filled in with 35's I love the look of then! How do you like the kevlars? That's what I'm wanting to get, and keep the duratracs for winter. A plate bumper wouldn't be too hard to do if you took your time with it I don't think!
  8. Oct 2, 2013 at 3:05 PM
    #148
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    You mean this one!? Hahaha
    image by Tanner Tucker, on Flickr
  9. Oct 2, 2013 at 3:11 PM
    #149
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I told myself 35s is not doable on 3 inches and then I come across this...
  10. Oct 2, 2013 at 3:13 PM
    #150
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I wouldn't trade the kevlars for anything! I love them. I've had them on anything from heavy rock, to cracked up slate, to mud. The rock we have here in Alberta is unbelievably sharp. Razor sharp. I already have a fair number of cuts and gashes in the lugs but nothing like I did with my Duratracs. The kevlars are holding up nicely!
    Haven't had them in the winter yet, but from judging last winters pathetic dump of snow, I think I'll hold off on buying a dedicated snow/ice tire such as a geolander or something along those lines.
  11. Oct 2, 2013 at 3:14 PM
    #151
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Less than 3 ;)
    I'd say more about 2"!
  12. Oct 2, 2013 at 3:21 PM
    #152
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Damn... I want to go to 35s one day without going to a drop bracket and under 6 inches. As long as I can do it without destroying my flares...
  13. Oct 2, 2013 at 3:25 PM
    #153
    Blackdawg
    Monte
    Wyoming/St. Louis
    35s no doable on 3" lift. You have been lying to yourself man haha. Most 35 tacos are on 2-3" haha.
    Temples would be cool...but unless you cut exactly the same as him..won't do you any good.
  14. Oct 2, 2013 at 3:33 PM
    #154
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    This is correct! Hence why I have 2 templates. One for each side. It would be extremely hard to cut both sides exact from one template. Mostly because so much sheet metal comes out.
  15. Oct 2, 2013 at 3:39 PM
    #155
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea basically.
    That said. The cardboard method for making your own is pretty easy. If you can't do that...probably shouldn't be welding and cutting the truck in the first place haha
  16. Oct 2, 2013 at 3:48 PM
    #156
    PcBuilder14
    Brent
    Nor Cal
    Hmm, true. I was thinking maybe more of a template on what to cut. Kind of like what you get when you buy a Safari Snorkel.
  17. Oct 2, 2013 at 4:01 PM
    #157
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can't do that either. Wheel BS and brand will effect that as well as wear and suspension setup.
    It's a custom job. No way around it. Why not a lot of people do it.
  18. Oct 2, 2013 at 4:03 PM
    #158
    PcBuilder14
    Brent
    Nor Cal
    You have to suck the fun out of everything, huh?
    Fun sucker! Haha :p
  19. Oct 2, 2013 at 4:05 PM
    #159
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    You just destroyed Brent's hopes and dreams haha
  20. Oct 2, 2013 at 4:05 PM
    #160
    PcBuilder14
    Brent
    Nor Cal
    Haha nah, just trying to see if I could make the process a bit easier.
