mrbeggins 04 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by mrbeggins, Mar 24, 2013.
  1. Oct 2, 2013 at 4:11 PM
    #161
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    haha im just a blunt realist..haha
    if only..
  2. Oct 2, 2013 at 5:03 PM
    #162
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Easiest way to do it...have someone holding the door open and ready with a fire extinguisher. Cover all the electrical wires with a damp rag, and make small cuts. More less plunge cuts. And get the thinnest cut off wheels you can. Once you have everything cut out, and cleaned up with the flap disk, take a hand full of grease and cover the edge of the cut. Then press your cardboard cut out up next to it. Walla! You have the imprint of the cut on your cardboard. Take it to your piece of sheet metal and add half inch to the template for welding surface. It's a lot of running back and forth fitting stuff. But once your done fitting the welding portion goes very quick.
    Once it's all tacked up and pressed tight, finish welding it out. Weld the drilled holes first, then go around the perimeter. Make sure you switch locations frequently to keep the heat down. (I would imagine this isn't your first time welding if your thinking of tackling a job like this)...
    After it's all welded out, go to town with the silicon on the inside of the cab. The cut out sheet metal isn't going to look pretty, and the piece you put back in for the tubbing isn't going to fit that great on the inside. I just covered all the joints on the inside of the cab with silicon. Just to make sure :)
  3. Oct 2, 2013 at 5:07 PM
    #163
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Got any interior pics?
  4. Oct 2, 2013 at 5:11 PM
    #164
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    That I don't. Mostly because it was pitch black when I had everything put back together. If I get some free time this weekend I will pop the kick panel off and pull everything out of the way and take a picture.
    Sorry!
  5. Oct 2, 2013 at 5:36 PM
    #165
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
  6. Oct 2, 2013 at 6:45 PM
    #166
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
    Sweet! Im probably gonna end up with those when i go 35's, heard nothing but good things about them so far.
    Yea last year sucked! I was up in revelstoke for a while then came back to kenora and it felt like there was just a dusting, even the ice roads didnt open till almost christmas.
  7. Oct 3, 2013 at 12:25 PM
    #167
    Augie95toy
    Augie95toy Augies Adventures
    Andrew
    Old Town VA
    1st Gen Tacoma for play
    Bumpers, skids, OME suspension,
    I'm really liking this Mod...35's in my future...Jus maybe..
  8. Oct 3, 2013 at 4:47 PM
    #168
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Order from discount tire direct. Their awesome! I wish I would have bought every other set of tires from them. I called fountain tire in high river and they wanted $1911 for 4! WTF!!! Not to mention not a single fountain tire in Alberta has 1 tire. I called up discount tire and within 20 minutes I had 4 315/75/16 Kevlars on my way. Took 5 days...and cost $1548 to my door. Awesome service to!
  9. Oct 3, 2013 at 4:56 PM
    #169
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Finally done with moving and had some time to go explore my new town. Okotoks is nice! Small town feel with all the amenitie! I found a rock...
    image by Tanner Tucker, on Flickr
  10. Oct 3, 2013 at 5:34 PM
    #170
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Forgot to add...I got rid of the TJM compressor and put in the ARB High Output. Wayyy better haha. Pumps up the 35 in about 1:45. Plus I'll be eventually running an air locker in the front. That the next major purchase:)
    Switch location
    Hose location
  11. Oct 3, 2013 at 5:41 PM
    #171
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Hey what's your opinion about those M.O.L.L.E seat covers? I was debating buying those but have heard mixed reviews about them and didn't really want to pay that much for them
  12. Oct 3, 2013 at 6:06 PM
    #172
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    These are the smittybilt ones for the 07-present JK's. Now if these and the Molle ones are the same I don't know? I love them though. They fit just fine in the truck....just have to snug up the straps that's all. The pockets are a must. I keep a knife, spare radio, batteries and a lighter in the top black one. Winch remote and a roll of toilet paper in the bottom one. Next to that I have a small first aid kit where the hose hangs. On the bottom part of the seat next to my left leg I keep my deflators
    I'd buy them again! I build custom homes for a living, so they see everything from carharts to mud to the odd coffee spillage haha.
  13. Oct 3, 2013 at 11:04 PM
    #173
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    is that $1548 including mounting and balancing?
  14. Oct 3, 2013 at 11:06 PM
    #174
    Blackdawg
    Monte
    Wyoming/St. Louis
    1500 for only 4? Shit..think Jon got 5 for that here in the states.
  15. Oct 3, 2013 at 11:08 PM
    #175
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    yea 1500 is really high. tire rack is 1200 for 4
  16. Oct 3, 2013 at 11:27 PM
    #176
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Did you get them shipped across the border? Was it still worth it after all the duties?
    Ive been looking at discounttiredirect for a couple weeks now. Trying to find a good tire for this winter and next summer. Whats your thoughts on the Duratracs? I probably get a lot more snow than you so im wondering if they will serve me well
    Discounttiredirect ships for free in the US. To ship a set of tires to Canada, they charge something like $200 for duty
  17. Oct 4, 2013 at 4:57 AM
    #177
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    ^yes. Thanks for clarifying that. $1548 is shipped to my door step up here in polar bear land. So they went across the border. That doesn't include mounting and balancing. That was another $150. Discount tire direct charges a flat rate of $240 to get them across the border.
  18. Oct 4, 2013 at 4:58 AM
    #178
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    No. To my door step. M/B was another $150
  19. Oct 4, 2013 at 5:01 AM
    #179
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    A buddy of mine bought the exact same tire and size as myself and definitely didn't pay 1200 for 4. He paid close to what I paid. I think a bit more actually.
  20. Oct 4, 2013 at 5:15 AM
    #180
    somethinboutayota
    Parker
    Dodge City, Kansas
    What about durability? I heard that's where they were lacking it. How long have you had those and how are they holding up?
