MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Sep 21, 2018 at 4:52 PM
    #181
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Excellent! I'd like it to say "Fuck you Toyota Accumulator, you're not the Boss of ME!"
  2. Sep 21, 2018 at 4:53 PM
    #182
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Telling you! Just wait until you sample it. It's like crack!
    Happy Friday!
    TeecoTaco[QUOTED] and mtip like this.
  3. Sep 21, 2018 at 5:12 PM
    #183
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    @7r41lbr34k3r, put me down for one if you make a drop in replacement.
    oconnor, 7r41lbr34k3r and tonered[OP] like this.
  4. Sep 21, 2018 at 6:51 PM
    #184
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    My machines bring all the bois to the yard.
  5. Sep 21, 2018 at 6:51 PM
    #185
    tonered
    tony
    Lynnwood, WA
    If you like it, put a ring on it!
    TeecoTaco and 7r41lbr34k3r like this.
  6. Sep 21, 2018 at 7:16 PM
    #186
    TeecoTaco
    SW Ontario
    If your proud of it, put a roof over it
  7. Sep 21, 2018 at 7:59 PM
    #187
    tonered
    tony
    Lynnwood, WA
    You guys rock.
    Now, hold my beer. :mudding:
    7r41lbr34k3r and TeecoTaco like this.
  8. Oct 3, 2018 at 6:43 AM
    #188
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Just drove a friend's '17 TRD OR M/T, and found it to be smooth.... but this accumulator issue was on my mind the whole drive. I'm thinking of getting a '18 or '19 M/T Taco. Learned to drive M/T in the mid 1970s, and really want to get back into one. The 3rd Gen slush box is not impressing me, even with OVtunes recent advancements.
    tonered[OP] and doublethebass like this.
  9. Oct 3, 2018 at 7:49 AM
    #189
    tonered
    tony
    Lynnwood, WA
    It is on my mind every time I shift also! Like when I can I do it again, and again. :burnrubber:
    With the TSB ECU update and the accumulator delete, the Taco has gone from fun to drive to competing with the bike. There will never be anything like carving corners on 2wheels with a torquey motor to make you feel like a hero from the apex and out, but for everyday commuting, I am finally happy on 4wheels for the first time in since I started riding. About 125,000mi since 2006 with 80% of it doing a 10mi commute.
    mtip, TD90S and su.b.rat like this.
  10. Oct 3, 2018 at 8:55 AM
    #190
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Looks like the fittings on the accumulater are M10 x 1.0 inverted flare. I found these on a quick search, so it's as simple as making a cross drilled block of (brass?) with 1/8" NPT threads to accept the above linked adapter. The accumulator housing is actually cast aluminum, so we could also just use 6061-T651 (I even have material laying around that can work).
    This certainly seems like the simplest way, and simple usually means cheaper.
    Norton, SigSense, MOC221_ and 4 others like this.
  11. Oct 3, 2018 at 8:57 AM
    #191
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Sounds awesome. I'm in for 1...
  12. Oct 3, 2018 at 9:04 AM
    #192
    tonered
    tony
    Lynnwood, WA
    Well that's pretty freaking sweet! I would not have guessed that was cast AL. I was assuming plated cast steel. 6061 with those fittings sounds like a winner.
    Those should use a wrench larger than 10mm so that should make installation easier.
    Down on the ground, bitches!
  13. Oct 3, 2018 at 10:44 AM
    #193
    su.b.rat
    su.b.rat broken truck
    truly exciting. if i can get this done right it will be one of the best mods yet.
  14. Oct 3, 2018 at 10:48 AM
    #194
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    It'll definitely be a cool mod. I suppose the only reason to go with me is just to have something with mounting holes. You could get a 1/8" NPT female/female elbow and just wrench those adapters in with teflon tape. I could even just make some sort of clamp bar for a universal part. *shrugs*
    tonered[OP] and su.b.rat like this.
  15. Oct 3, 2018 at 10:49 AM
    #195
    thefreshtaco
    thefreshtaco Well-Known Member
    Indianapolis Indiana
    2016 White TRDOR DCSB M/T Tech
    IN.
    su.b.rat likes this.
  16. Oct 3, 2018 at 11:15 AM
    #196
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    Put me down on the list for one
    Toyota has been putting these "dampers" on their manual cars for a long time, I installed an aftermarket damper delete on my manual Lexus IS300. Even the throttle had a spring damper on it, solved that real quick with a shock spacer clip from a r/c car.
    tonered[OP] likes this.
  17. Oct 3, 2018 at 11:54 AM
    #197
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I'm in. This sounds great.
  18. Oct 3, 2018 at 12:00 PM
    #198
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    YES YES YES YES YES YES YES.
    I'll take one.
  19. Oct 3, 2018 at 12:09 PM
    #199
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I'm going to wrongly assume that you wanted another picture, because I can't find another reason to post it.
    tonered[OP] and MOC221_[QUOTED] like this.
  20. Oct 3, 2018 at 12:11 PM
    #200
    MOC221_
    Frank
    :rofl::rofl:
    I'd like an accumulator delete block of brass or aluminum with M10 flare o matic double shielded thingamabobs please!
