MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. May 13, 2021 at 7:29 AM
    #2261
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    We should have a pay it forward kit. All needed wrenches and a spare accumulator along with laminated instructions. Replace with your accumulator and send it forward.
    OZ TRD, PNWTacoma, JDSmith and 4 others like this.
  2. May 13, 2021 at 7:30 AM
    #2262
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You could, but for the cost of postage, you can pretty much grab that set from HF that is really good.
    CygnusX191 and MOC221_ like this.
  3. May 13, 2021 at 7:38 AM
    #2263
    daveeasa
    David
    PNW
    HF doesn’t carry accumulators :)
  4. May 13, 2021 at 7:38 AM
    #2264
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    How much is a new accumulator?
  5. May 13, 2021 at 7:39 AM
    #2265
    su.b.rat
    su.b.rat broken truck
    now why would you do that?
  6. May 13, 2021 at 7:41 AM
    #2266
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I mean, I get your suggestion.
    Quick swap/bleed and you're done.
    If you have a dremel though it's really easy. You just have to be careful you don't nick the sealing surface, and then clean the thing out really well.
    CygnusX191 likes this.
  7. May 13, 2021 at 7:44 AM
    #2267
    tonered
    tony
    Lynnwood, WA
    Sure, but you don't need an accumulator. Also, I wouldn't want someone else dremel work.
    C41n, CygnusX191 and MOC221_ like this.
  8. May 13, 2021 at 7:47 AM
    #2268
    daveeasa
    David
    PNW
    Of course not.
    Kit would include wrenches, bottle, tubing, clamp, takeoff accumulator.
    Pay last guy $50 to get kit.
    receive and purchase dot 4 fluid.
    dremel accumulator in advance.
    unbolt and swap using wrenches
    bleed using bottle
    package takeoff accumulator and tools / supplies for shipment to next guy who pays you $50
    Makes sense to me.
  9. May 13, 2021 at 7:50 AM
    #2269
    MOC221_
    Frank
    I wouldn't either.
    It cost me a bottle of brake fluid, and that's it.
  10. May 13, 2021 at 7:51 AM
    #2270
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Would you happen to have the part number??
  11. May 13, 2021 at 7:52 AM
    #2271
    tonered
    tony
    Lynnwood, WA
    I suppose some might like that?
  12. May 13, 2021 at 7:53 AM
    #2272
    daveeasa
    David
    PNW
    I have all the parts and even a laminator.
    I would assemble a kit if we think this will actually work. If it fizzled though, I’ll be bummed.
    OZ TRD, JDSmith and CygnusX191 like this.
  13. May 13, 2021 at 8:00 AM
    #2273
    tonered
    tony
    Lynnwood, WA
    It might have been a hit when this all kicked off. Now, there are only a new person or two per month posting here. You'd have to judge the worth from other folks.
    Myself, I had the stuff on the shelf and only grabbed new wrenches because the one that I had was weak and seen better days. I'm always looking for an excuse to trawl through HF.
    The other variable is that folks approached it three different ways. Some pulled the drive shaft, others pulled the exhaust support, and some did neither. :D If you don't pull the exhaust support, you need a hinged wrench. There's no room for straight ones like in the HF set.
    MOC221_ and CygnusX191 like this.
  14. May 13, 2021 at 8:07 AM
    #2274
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I have been watching this thread and missed this Drexmel business . I guess I started following too long ago
    Edit. Found the ported accumulator pic.
    I want this mod so bad now that I know it's even easier
    :bananadead:
  15. May 13, 2021 at 8:09 AM
    #2275
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Accumulator bad.
    MT is best T.
    Circles: jerked.
  16. May 13, 2021 at 9:04 AM
    #2276
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I'm aware, Just thought the wording was odd when he said he didn't have a reservoir. All good.
    AutoZone carries them, both in sets and as individual wrenches. I didn't have any trouble digging up what I needed
    Oooorrr.... Don't pull any of that stuff and still use straight flare wrenches. :D
  17. May 13, 2021 at 9:07 AM
    #2277
    tonered
    tony
    Lynnwood, WA
    An autoparts store was where I got the one that failed, but I think I tried to use it in a tight spot for a standard fastener and it yield.
    I'm a fan of working easier. Beyond that, I'm clumsy with what I think are large hands, so space is good.
    CygnusX191[QUOTED] likes this.
  18. May 13, 2021 at 9:53 AM
    #2278
    daveeasa
    David
    PNW
    That's a good point, I didn't have that hinged wrench and had to pull the exhaust bracket. Having a full set of every tool you need and color photos showing how to use it would add some value vs the extra work of finding the best possible tool. I didn't even know what a flare wrench was before doing this.
  19. May 13, 2021 at 12:12 PM
    #2279
    MOC221_
    Frank
    Ppl pulled the front driveshaft for this?!
    I've done it both ways (removal on the 16 and dremel on the 19) and didn't think of going that far lol. The exhaust bracket did come off though.
  20. May 13, 2021 at 12:17 PM
    #2280
    tonered
    tony
    Lynnwood, WA
    Yeah. I think trident recommended that?
