MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jun 27, 2021 at 9:57 AM
    #2361
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    i dremel’d. Just bc it meant I didn’t have to buy anything. Well until I couldn’t reach the recessed bolt on the heat shield so I bought a flex head ratchet.
    But I would think it would slightly easier to just add the flex brake line thingy.but again hardest part is just getting it off which you have to do both ways.
    CygnusX191, tonered[OP] and MOC221_ like this.
  2. Jun 29, 2021 at 6:55 PM
    #2362
    philth
    philth .
    Anyone have an extra accumulator laying around and are willing to ship to Canada? I’ll cover shipping + trouble costs!
    CygnusX191, Junkhead and tonered[OP] like this.
  3. Jun 29, 2021 at 8:32 PM
    #2363
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    At that point you may as well order the part from your local dealer. Lol
    MOC221_ and Junkhead like this.
  4. Jun 29, 2021 at 8:41 PM
    #2364
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I think you are not wrong there.
    CygnusX191[QUOTED] likes this.
  5. Jun 29, 2021 at 8:47 PM
    #2365
    Shellshock
    Iowa
    Or get it from one of the Canadian taco bros
  6. Jun 29, 2021 at 8:48 PM
    #2366
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I got one laying around but would like to keep it Justin Case.
    CygnusX191 likes this.
  7. Jun 29, 2021 at 9:27 PM
    #2367
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Dibs on that band name
    arthur106 and Junkhead like this.
  8. Jul 2, 2021 at 11:05 AM
    #2368
    andagi808
    andagi808 Well-Known Member
    Hawaii
    2021 Black Tacoma TRD OR MT
    Has anyone ever had the dealership remove the accumulator for them? I tried searching this thread for an answer but couldn't find anything. I'm just nervous about doing it on my own since I'm not familiar with any type of engine work (especially with having to bleed lines).
    CygnusX191 and Junkhead like this.
  9. Jul 2, 2021 at 11:18 AM
    #2369
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Very few dealers will do modification work. Most lift kits and project trucks that you see at dealers are either done by secondary shops or a select group at the dealer. Typically, they work to what the OEM gives them.
    Learning to bleed is a good thing. All vehicles should have a bleed every few years at a minimum. Try it out on brakes as they are a bit easier to do. It is something that can be self taught. Basically, never relieve pressure on the pedal / lever until the bleed nipple is closed. That's it.
    Brakes are:
    -- Pressure on the pedal
    -- Crack the bleed nipple, let fluid come out, and close the nipple
    -- Let the brake pedal come back up
    -- Pump the brake to regain pressure
    -- Repeat until virgin fluid flows out
    Clutches are:
    -- Pedal to the floor
    -- Pull the pedal up off of the floor
    -- Pump the clutch to regain pressure
    -- Repeat until all air is out / virgin fluid flows out
    Seriously though, if I can ham-fist my way through it, most anybody can get there.
    Of course, there are also remedies for mess ups that happen.
    blackhwk27, C41n, JDSmith and 4 others like this.
  10. Jul 2, 2021 at 11:18 AM
    #2370
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    You can get any local shop do it for you. That is what I did, cost me 60$.
    C41n, su.b.rat, CygnusX191 and 2 others like this.
  11. Jul 2, 2021 at 11:24 AM
    #2371
    Shellshock
    Iowa
    I made it through it..
  12. Jul 2, 2021 at 11:34 AM
    #2372
    tonered
    tony
    Lynnwood, WA
    See!
    :dancingbacon::dancingbacon::dancingbacon:
    C41n and CygnusX191 like this.
  13. Jul 2, 2021 at 11:50 AM
    #2373
    andagi808
    Hawaii
    Had to google some of those terms (a little risky while at work lol) to get a visual, but doesn't seem too bad once you broke it down. I think I'll pick up an extra one and dremel it so that I'll have a backup in case I mess up.
    I just worry that if I have any kind of problem they'll point to the removal and deny any warranty claims
    doublethebass and CygnusX191 like this.
  14. Jul 2, 2021 at 11:53 AM
    #2374
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    If they see no accumulator and you complain about any kind of clutch/tranny problem, they will do everything to blame it on the mod. But honestly if you have any issues with the clutch, most likely they won’t warranty it since it’s a wear item.
  15. Jul 2, 2021 at 11:55 AM
    #2375
    tonered
    tony
    Lynnwood, WA
    Yeah. Just about anything can bring up interesting sites these days. Be sure to pick up a good line wrench, I have these: You only need the 10mm one.
    On the warranty side, there is not much of the clutch system that will get a warranty repair. Most of it is considered a wear item and will be a good fight no matter what.
    Just my $0.002.
  16. Jul 2, 2021 at 12:09 PM
    #2376
    andagi808
    Hawaii
    well hell, guess I've got an upcoming project to get started on then.
  17. Jul 2, 2021 at 12:10 PM
    #2377
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    There is a tsb out on some of the clutch wear components, especially if you're getting any kind of creek out of the pedal. Get that done first so there's really no reason for them to look at your accumulator.
    andagi808 and Junkhead[QUOTED] like this.
  18. Jul 2, 2021 at 12:10 PM
    #2378
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Great decision! You will love the predictable clutch pedal!
    CygnusX191 and andagi808[QUOTED] like this.
  19. Jul 2, 2021 at 12:12 PM
    #2379
    tonered
    tony
    Lynnwood, WA
    Let us know if you have any questions!
    Folks with the updated clutch pedal are still getting noises. A dremeled accumulator would be unnoticeable for that TSB, even when bleeding the system.
  20. Jul 2, 2021 at 12:14 PM
    #2380
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Good point.
    But doesn’t lithium grease solve the creaking? I had the TSB done pretty much a few months after I bought my truck. It started creaking again about couple months later for a week or so then it stopped. Been about 2 years on the “new” assembly and no funny noises.
