MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Oct 20, 2018 at 8:48 AM
    #221
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
  2. Oct 20, 2018 at 8:59 PM
    #222
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    83F4D82D-A6F9-4BC6-AEEB-81BD91F0CF82.jpg 34200B05-3767-4F7D-AD9E-C8A37C86E7D1.jpg A0FC853D-CC76-4448-A56D-930B951B340F.jpg Spent 6 hrs today milling out a bolt in replacement block for the accumulator, using the 1/8 npt to m10x1.00 adapters sold by LRO. Only to find out that the adapters are to shallow to accept the fittings on the lines. There is a 3mm section on the fittings that have no threads. I was only able to achieve 1-1.5 threads of engagement. I now wish I had checked first before going through all the trouble. This was only meant to be a “prototype” anyway out of aluminum, then another would have been milled out of brass. I’m looking into endmills that will cut the flare seat without using any adapters. Here’s what I came up with, without getting too crazy with corner rounding, and such. I like to mess around on the mill at work from time to time, but I dont even consider myself a novice. Alot to learn. I’m going to install a female-EF9A300F-889B-40AC-9D73-79D5E2C2E6D4.jpg female coupler for now with a new piece of line from the slave, similar to @TD90S, while I come up with a better solution.
  3. Oct 20, 2018 at 10:33 PM
    #223
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Nice effort! That does suck that they are too shallow.
  4. Oct 21, 2018 at 5:42 AM
    #224
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    tonered[OP] likes this.
  5. Oct 21, 2018 at 8:37 AM
    #225
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Yeah... Toyota uses a different kind of flare nut. I stumbled across that fact by chance a couple of days ago while doing part of my overly anal planning for the project.
    Of course, they're harder to find. Summit Racing has some, but I might just hit up a junk yard for a couple of flare nuts and some brake line. I already have the 90 degree union.
    https://www.summitracing.com/parts/urr-br205
  6. Oct 21, 2018 at 11:13 AM
    #226
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
  7. Oct 21, 2018 at 1:56 PM
    #227
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
  8. Oct 21, 2018 at 5:17 PM
    #228
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Nice start!
    This is exactly what I want but don’t have the means to make.
    If you invest the time and money to see this through, I’m in for one. I think others will too.
    WalkinTaco likes this.
  9. Oct 21, 2018 at 5:20 PM
    #229
    TD90S
    GA
    ‘18 TRDOR 6MT
    Unless I missed it I don’t see the length of that hose but that would be the easiest solution.
    The problem is the proximity of the exhaust to this area. I would want it to fit under the heat shield and not be rubbing on the shield or the transmission case.
  10. Oct 21, 2018 at 5:31 PM
    #230
    TravelingTacoma
    TravelingTacoma Member
    Eric
    Rock Hill, SC
    '19 Cement DCSB TRD Offroad MT
    There was shipping added, but was like $25 shipped to me. For that price I'll be the guinea pig and see how it works out. I do still like the idea of a machined replacement for the accumulator, so I'd be in on that when it comes to fruition.
    TD90S likes this.
  11. Oct 21, 2018 at 5:37 PM
    #231
    TravelingTacoma
    Eric
    Rock Hill, SC
    12" long and I'll let you guys know if it's going to work or end up rubbing anything. I've wasted more money on less if it doesn't work out.
    oconnor and TD90S[QUOTED] like this.
  12. Oct 21, 2018 at 7:10 PM
    #232
    Vitalzone
    Arizona
    Im not confident I could pull off mass produced parts. I’m working with a manual mill. It takes forever to produce even simple parts such as this. However alot of my time was spent figuring out, bore depths, bolt patterns, and generally just copying the oem accumulator dimensions. I have the ok to work on personal projects at work, but it’s corporate aerospace, they will fire my ass if I get caught using the shop for what they would consider all the wrong reasons.
    SigSense and TD90S[QUOTED] like this.
  13. Oct 21, 2018 at 7:22 PM
    #233
    TD90S
    GA
    ‘18 TRDOR 6MT
    Totally understand. Super jealous you have access to the equipment!
  14. Oct 21, 2018 at 7:53 PM
    #234
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    Wait a moment, all you need a short piece of brake line to bypass the accumulator correct? I just replaced all my brake lines with some braided ones, can I just reuse one of my old brake lines? It should have the same flair and fittings?
    Norton likes this.
  15. Oct 22, 2018 at 5:37 AM
    #235
    ShirtTucker
    2017 V6 Sport AC MT
    Lots-o-stuff
    Yup. All you need is an M10x1.0 union. Unless you want to mail me your brake line and fittings. :thumbsup::D
    tonered[OP] and MOC221_ like this.
  16. Oct 22, 2018 at 7:12 AM
    #236
    tonered
    tony
    Lynnwood, WA
    I'm not 100% sure about that. A loop will create high spot where an air bubble might get caught and be hard bleed out?
    12in might be long enough to get from the upper line to the slave directly, if one end had a male fitting?
  17. Oct 22, 2018 at 7:30 AM
    #237
    fatboyfirebass
    I wasn't sure if the loop would cause issue or not. I like the idea of replacing the block and the lower line. I always like fewer connections. I think my next weekend internet search will be 18" line, male on one end, female on the other.
    In that train of thought, how difficult would it be to replace the hole length up to the firewall with a stainless braided piece or a hand bent length of line from an auto parts store? By that I mean, how accessible is the upper connection? I am not sure what the maneuvering room is like on the back side of the firewall.
  18. Oct 22, 2018 at 7:39 AM
    #238
    tonered
    tony
    Lynnwood, WA
    Sorry to be a downer. I'm not saying it isn't going to work, but I have struggled in the past when bleeding lines that had air bubbles. OTOH, it was a piece of cake to bleed the clutch after this mod. So, just a word of warning in general.
    The upper part of the line is very inaccessible with the transmission in place. The whole area is tight, but thankfully, it isn't hard to get the cat support out for a bit of room.
    Also having a connection there is convenient if you need to drop the transmission for a clutch swap. Of course, there is still the connection at the slave for that esp if you are going with a flexible line.
    Regardless, this mod continues to make me smile.
    MOC221_ likes this.
  19. Oct 22, 2018 at 8:02 AM
    #239
    fatboyfirebass
    So, it sounds like replacing the entire run is not really an option unless you are replacing the clutch or some other work requiring the transmission to be dropped.
    I am excited to get his done on my truck. Unfortunately, I will most likely be waiting to the weather warms up here again in the spring, or hopefully one more weekend warm snap before winter.
    Depending on how the search goes, I may just try a union and replacing the lower length with a hand bent replacement that is a little longer than the stock one. I'm a little nervous trying to re-bend the lower stock line like the picture shown in post #212. I can leave everything hooked up until I get a piece of line the right length bent up the way I like it before I disconnect everything. I'd hate to tear it apart and then be stranded in my driveway because I kinked a line or got the wrong length, etc.
  20. Oct 22, 2018 at 8:15 AM
    #240
    TD90S
    GA
    ‘18 TRDOR 6MT
    I don’t think replacing the entire run from the firewall down would be any harder if you are using a premade flexible hose.
    If you are using a hard line you will need have the tools to flair the line, or find one the exact length you need. I guess the same would apply to a flexible hose.
    I wanted the ability to go back stock if needed/wanted. Used another piece of line to replace the accumulator and lower line. This is what I have left over.
