MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Nov 13, 2022 at 1:30 PM
    #3221
    Firn
    Firn Well-Known Member
    White OR
    As others have answered, that is not correct. The clutch should return fully and smoothly.
    When I bled mine I bled it two ways. One was with a second person pushing down the clutch pedal just like you would with brakes. The other way is to close the bleeder and depress the clutch fully, then just crack the bleeder.
    The clutch is spring loaded so if you fully depress the clutch and load the spring it will also force fluid out the bleeder.
    The very first time I did it I had air in the system too (very short clutch travel). It worked itself out in a day.
    CygnusX191 likes this.
  2. Nov 13, 2022 at 1:35 PM
    #3222
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I probably need to rebleed mine.... Two years later..... :anonymous:
    About time for new fluid anyways
  3. Nov 13, 2022 at 1:36 PM
    #3223
    bosco76
    bosco76 Well-Known Member
    Near A² MI
    '17 OR DC MT MGM
    Good info, Thanks. I've also got very short clutch travel. Appriciate the tips
  4. Nov 13, 2022 at 1:39 PM
    #3224
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I bled mine for probably 20 pumps (open bleeder, slam clutch to the floor, close bleeder, pull clutch pedal back up) after gravity bleeding a few minutes. It still had a super soft feel after the bleeding. After a drive or two just using the clutch pedal fixed itself and it’s felt normal ever since.
    I think air gets trapped in the MC when you pinch the hose. Even if you pinch the hose super tight, fluid will still run out to some degree while you work. I think this ends up putting some air in the MC which works its way back out once you’re using the clutch naturally again.
  5. Nov 13, 2022 at 1:43 PM
    #3225
    bosco76
    Near A² MI
    '17 OR DC MT MGM
    Well, the idiot who installed mine didn't pinch the hose. So I.... I mean, he let all the brake fluid out.
    slowpoke_671, andagi808, mtip and 2 others like this.
  6. Nov 13, 2022 at 2:37 PM
    #3226
    Shellshock
    Iowa
    I bled mine like 500 pumps lol
    slowpoke_671 and CygnusX191 like this.
  7. Nov 13, 2022 at 2:38 PM
    #3227
    Shellshock
    Iowa
    Yeah.. same idiot must have done mine :rofl:
  8. Nov 13, 2022 at 2:48 PM
    #3228
    Firn
    White OR
    That jerk gets around, he did mine too
  9. Nov 13, 2022 at 2:51 PM
    #3229
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :anonymous:
  10. Nov 13, 2022 at 4:43 PM
    #3230
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :boink:
    :D
  11. Nov 14, 2022 at 6:38 AM
    #3231
    Naoto
    Naoto Well-Known Member
    LR TRD PRO M/T
    :rofl: I thought I was the only one!
  12. Nov 14, 2022 at 10:38 AM
    #3232
    MOC221_
    Frank
    Haha, nope!
    mtip and CygnusX191 like this.
  13. Nov 23, 2022 at 7:44 AM
    #3233
    Firn
    White OR
    Anyone looked into low viscosity brake fluid to further improve clutch feel? I ran this for a while in my old car to improve abs performance (no idea if it helped, I never engaged abs after doing so)
  14. Nov 23, 2022 at 7:55 AM
    #3234
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I ran DOT 5.1 in bike for a while. It was a PITA as it caused my master seals to leak. Took me forever to figure out, including new masters. Switching back to DOT 4 fixed the issue almost immediately.
    So, you could try it, but check for other issues that might crop up.
  15. Nov 23, 2022 at 10:09 AM
    #3235
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Not recommended, not worth it, also you don't engage ABS, it engages whenever it damn well Pleases lol
  16. Nov 23, 2022 at 12:45 PM
    #3236
    Firn
    White OR
    Sorry, I was thinking specifically for the clutch.
    Since the clutch moves a greater volume of fluid than the brakes the LV fluid viscosity may have an affect on pedal feel. It should certainly have an effect when it comes to cold weather, but lv fluid may also help with the feel.
    I plan to swap out to lv soon since I think it will complement the delete disk, plus it should be a bit more consistent in the cold
    CygnusX191[QUOTED] likes this.
  17. Nov 23, 2022 at 12:49 PM
    #3237
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And since you're driving an off-road, your clutch reservoir is separate from the brake reservoir. On the sports they are the same reservoir. I would just worry about seals but it might not be a big enough difference to affect it. If you do try it, let us know.
  18. Nov 24, 2022 at 6:31 PM
    #3238
    SerialKiller
    SerialKiller Well-Known Member
    2019 Cement Tacoma OR
    I had the same issue so I had to bleed the system again and it got rid of it for the most part. It still happened a little bit but after a day or two it went away and hasn’t happened again.
    CygnusX191 and bosco76[QUOTED] like this.
  19. Nov 24, 2022 at 6:55 PM
    #3239
    bosco76
    Near A² MI
    '17 OR DC MT MGM
    Since the weather turned cold the day after I finished, I haven't wanted to crawl under the truck to re-bleed. But, I have to say the clutch, after a couple days feels great, Like you and others have said, it self heeled. Now just waiting for the weather to warm up again to get the 4th bolt back in the heat shield.
  20. Nov 30, 2022 at 11:58 PM
    #3240
    Ooh-it's all squishy!
    Ooh-it's all squishy! Where's the kaboom?
    Rod
    OK
    2020 Black TRD Pro MT
    KDMax Pro Tune, debadge, tonneau, hood struts, some ME-SO goodies, JL-Audio
    About a month and a half ago, I ordered one of @Firn's ADM discs, and it managed to get lost in USPS land, so he quite awesomely sent me another one (via UPS that time).
    Well, after about 6 weeks wandering the landscape, the USPS shipped disc finally showed up, drunk and naked :)
    So, I now have a spare disc. I spoke with Firn about this, and he thinks it's appropriate to go ahead and pay this one forward to someone here who wants one.
    I'll cover shipping.
    I think it probably won't be too horrible for any interested party to go ahead and PM me (I'll count any that show up on 1 dec as valid), and I'll toss a dice or something like that to choose the winner.
