MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Dec 19, 2022 at 10:13 AM
    #3281
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    That's a good description of that. Didn't really know how to describe it, because its not like its going to stall out gassing from a stop but it often times feels off like its struggling. A tune will take care of that?
    CygnusX191 likes this.
  2. Dec 19, 2022 at 10:14 AM
    #3282
    Firn
    Firn Well-Known Member
    White OR
    This is what I have ready to go in the truck, just need to crawl under and do it.
    https://www.amazon.com/Pentosin-1224116-Brake-Fluid-Liter/dp/B00610SK2S
    The viscosity at normal temps isn't far off regular brake fluid but when its cold its a lot thinner. I looked at as many MSDSs as I could and this was the lowest viscosity fluid I could find.
    If you have clutch issues normally I would suggest the fluid regardless. It is specifically designed to not thicken up as much in low temps, that was done for ABS but applies here too. Its not really any different hot, just doesn't get thick as fast as the temp goes down.
  3. Dec 19, 2022 at 10:14 AM
    #3283
    Firn
    White OR
    Man I hope so! Its next on my list
  4. Dec 19, 2022 at 10:22 AM
    #3284
    FlatbedTaco
    FlatbedTaco Well-Known Member
    2016 TRD Offroad 6 Speed MT
    Cooper 37's Black Rhino Bead Lock's Twin locked Kings Mits Alloy
    ill have to look into that thanks!
    TacoRL, CygnusX191 and Firn[QUOTED] like this.
  5. Dec 19, 2022 at 10:23 AM
    #3285
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It is ridiculous. I think the truck tuning group just missed the boat competely until the 3rd Gen Tundra launch. It seems that they might have gotten it mostly right there? It is crazy how well the 4.0l respond to a tune also.
    Just being able to get rolling without raising the revs is so nice.
    CygnusX191 and Shellshock like this.
  6. Dec 19, 2022 at 1:55 PM
    #3286
    CavalryTRD
    CavalryTRD Well-Known Member
    Frankie
    Cavalry blue TRD
    Not sure what tune you guys have but I got the ott tune a few weeks before I did the ADM and haven't been terribly impressed. But i think the two mods together have improved it a LOT more than I realized. I hauled off 4 pine trees today and I was able to easily start off at low rpms even with over the payload capacity in the bed. I could easily accelerate up hills(nothing crazy) in 5th gear at 2k rpm. It's very smooth at low rpm.
    CygnusX191 and Firn like this.
  7. Dec 19, 2022 at 2:20 PM
    #3287
    tonered
    tony
    Lynnwood, WA
    Any tune, including the unedited vF 2.0 Tunes, will unlock the low end torque. It is simply a failure of the Stock calibration.
  8. Dec 19, 2022 at 2:46 PM
    #3288
    CavalryTRD
    Frankie
    Cavalry blue TRD
    For sure. I've heard a lot of people prefer the ott over other tunes. But this is my first tacoma and only tune I've tried.
  9. Dec 19, 2022 at 3:53 PM
    #3289
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Does your clutch not warm up as you drive? o_O
    Keep in mind if you're in a sport, your brake and clutch reservoir is shared....
    For sure. Still running the VF2.0 all these years later.... Need to upgrade.....
    tonered[QUOTED][OP] likes this.
  10. Dec 19, 2022 at 4:53 PM
    #3290
    tonered
    tony
    Lynnwood, WA
    I have over 60k tuned miles with many variations.
    Shellshock and CygnusX191 like this.
  11. Dec 19, 2022 at 4:57 PM
    #3291
    Firn
    White OR
    I don't think clutch fluid really warms up. There is little to no connection to anything making heat. Yes, it's on a bracket on the transmission, but it's not like brake fluid or most other fluids.
    True regarding the sport. Still, if you don't mind the extra work there is no reason not to use it in the brakes too, heck the abs may even work better in the winter (that is what it is designed for)
    CygnusX191[QUOTED] likes this.
  12. Dec 19, 2022 at 6:33 PM
    #3292
    Firn
    White OR
    Well this was the impitus needed to change the fluid. Hopefully tomorrow I can tell you more
  13. Dec 19, 2022 at 6:56 PM
    #3293
    CavalryTRD
    Frankie
    Cavalry blue TRD
    "Chanting"
    DO IT, DO IT, DO IT, DO IT
    In for the results.
  14. Dec 19, 2022 at 7:02 PM
    #3294
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    Word for word, what I would describe my new manual feels like. "draggy", like the fluid is molasses, and the hard lines are the size of macaroni. What's the difference between all these tunes? Are they all fundamentally the same with just a small tweak to deliver on some end or another? Or is there a different tune for everybody, just play around until it "feels right?"
  15. Dec 19, 2022 at 7:52 PM
    #3295
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    I have the KDMax tune and it really woke the engine up and made the truck fun to drive. I bought one of your discs, just havent had time to put it in but looking forward to seeing how it changes the feel of the clutch.
    Couldn't agree more
  16. Dec 19, 2022 at 8:48 PM
    #3296
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    It warms up. Just having the reservoir in the warm engine would be enough, but the lines also run in proximity to the exhaust and the engine warms the transmission. I don't really notice it being "cold" untill around 0 F. At highway speeds with temps below -30 F it just stays cold, but will warm up at slower speeds. A winter front would help fix that. Of course, it might not be the clutch fluid, but the clutch itself that is the culprit. The pedal is a little stiff being depressed, but it is the let out that sticks. I think it is because I can put a lot of force into the pedal, but return force is the same regardless as the clutch reengages.
  17. Dec 20, 2022 at 11:46 AM
    #3297
    TacoRL
    TacoRL Member
    2020 Manual TRD Off-Road DCSB
    Looking forward to your results. Looks like the brass plate is the direction I want to go for the same reasons as you.
    We're hitting the negatives here in Montana. I have a 2020 Manual OR and the pedals feel like molasses. Not really someting that bothers me. Just the way cold weather is. But I don't want to jump on this upgrade if it won't do me good until the spring.
    If the brass plate is effective in cold weather with the new clutch fluid, then I'll be next in line.
  18. Dec 20, 2022 at 2:37 PM
    #3298
    Firn
    White OR
    Drove it today and I want to say it's better. It was a balmy 46 degrees today so I am hesitant to say it's going to be effective at very low temps.
    The LV fluid I linked is <700(cst?) at -40c, regular Dot 3 is <1500 at -40. In comparison both are about 1 (one) at 100c, or around 12 at people temps
  19. Dec 20, 2022 at 2:52 PM
    #3299
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I still don't get it, now I have only been driving a manual trans for 60 years including British stuff with fluid release I see nothing wrong with my 2011 Tacoma clutch system what do I gain?
    22Coma6MT, CygnusX191 and TeecoTaco like this.
  20. Dec 20, 2022 at 3:03 PM
    #3300
    TacoRL
    TacoRL Member
    Well in any case I'm still on the fence between direct bypass and the brass plate. $55 isn't much of an investment to be a guinea pig for everyone here on TW (concerning low temps anyway). Can always do the bypass once the warranty expires if needed.
