MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Dec 20, 2022 at 3:45 PM
    #3301
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Largely ignorant on Gen II. Does yours have an accumulator?
    I'm 65, MT's since 15 or so, and my MT 2019 clutch did have some built in puffiness. Accumulator gone now, feels like most any other clutch, timing wise.
  2. Dec 20, 2022 at 3:55 PM
    #3302
    Firn
    Firn Well-Known Member
    White OR
    Yeah, I admit that is a tough call. To be honest, since you wheel in very cold temps I myself might even recommend a full bypass. LV fluid as well
    Now that we have colder weather around the country it would be interesting to hear from other members as to the effect of cold weather on the disk.
    CygnusX191 and TacoRL[QUOTED] like this.
  3. Dec 20, 2022 at 4:53 PM
    #3303
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    So yeah...your history includes cable driven clutch, you mentioned fluid driven clutch as well. What we DO know is your 2011 does have an accumulator. You are the dood in the pilot seat so if it works for you, awesome.
    What > I < gained is more of a feel of cable driven vs fluid driven...although I have had previous fluid driven clutches that didn't "slush" as well, I figure because they were not "accumulated fluid" driven clutches. For feelz I like cable clutch...tolerate free flow fluid clutch...accumulated fluid clutch made me feels like I just learned to shift every other shift or so. Free flow eliminates the "engagement of clutch as just a suggestion" profile of an accumulated clutch profile. I want the engagement when I want the engagement, not when the bernoulli principle dictates when it should happen. If > I < wanted that, I'd introduce a torque converter and call it a slush box...that's just me.
    Besides, outside of first and reverse, I'd rather float the gears and fvck the clutch out of the equation.
    This is the beauty of MT right? You tune your guitar to your playing style! Can't have this convo if you drive an AT.
    Sorry bro, you asked, lol...
    Danbest82, tonered[OP] and CygnusX191 like this.
  4. Dec 20, 2022 at 5:54 PM
    #3304
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Damn if you didn't just describe my driving experience.
    I manual swapped my '99 4runner with the running gear from a '98 a few years back. Even with the computer freaking out over not seeing any shift solenoids, the throttle response was leaps and bounds better all around. I never had any issues heel-toeing and big-toeing the throttle and clutch maneuvering around/over obstacles offroad. The rev hang is killer on this motor, especially when cold. I've been trying to figure out how to drive this clutch and throttle combo since I picked it up in september. There's been times when everything is nice and smooth and every shift goes great, but 70% of the time, no matter how fast/slow i am on/off the throttle and clutch pedals, I end up feeling like I'm getting kicked in the seat shifting gears. Unlike the 5spd in my '99 (or really any other manual I've ever driven), this 6spd also seems to have miles of slop when shifting, and as soon as the throttle begins to bite I can feel the stick being pushed into or pulled out of my hand.
    With temps dropping, I was searching if anyone elses clutch feels extreeeeeemely sluggish. Glad I'm not the only one (I guess).
    I had been planning to do the accumulator bypass in the spring. Will be a good time to change the fluid to see if that helps in the cold.
    CygnusX191 likes this.
  5. Dec 20, 2022 at 6:06 PM
    #3305
    Firn
    White OR
    I just did the fluid, takes about 20 minutes, less if I had the correct wrenches handy (12mm and 10mm) and hadn't tried to do it without removing the heat shield first (take out 3 bolts, bend out of way)
    I have to admit, I think it would be interesting to see if lv fluid itself helps with removing the effect of the accumulator.
    If you were willing to try and change the fluid without any other mod folks may be interested in the result. Not that I expect much as far as accumulator goes, the hot viscosity is near identical, but without combining any other mod knowing how the lv fluid response might be useful
  6. Dec 20, 2022 at 7:17 PM
    #3306
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    o_O .... It's literally brake fluid. The same stuff. The same bottle. Like, it's not "like" brake fluid, you literally use DOT 4 brake fluid ...
    Why wait for the warranty to expire? Unless you're bringing it in because the accumulator is broken, and no one's going to bother looking for the accumulator. And with a bypass in place it literally affects nothing else on the truck. Even if you brought it in for a clutch warranty or TSB, we don't check the accumulator.
  7. Dec 20, 2022 at 7:35 PM
    #3307
    Firn
    White OR
    CygnusX191[QUOTED] likes this.
  8. Dec 20, 2022 at 7:36 PM
    #3308
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Makes more sense. Also.... Nice quote :rofl:
    Tbf tw has been a tad wonky lately
    Firn[QUOTED] likes this.
  9. Dec 23, 2022 at 3:23 PM
    #3309
    Firn
    White OR
    Drove the truck today in some actual cold (-4)
    Truck left a moderately warm garage (50f) and out into the cold. Clutch distinctly stiffened up but not terribly so, also did not notice the accumulator.
    After driving a while I imagine the system absorbed some heat but I can't imagine it was much.
    All in all the lv fluid seemed to work well in the cold
  10. Dec 23, 2022 at 7:16 PM
    #3310
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    As a point of reference, I drove in single digits today, not insanely cold by any stretch, but clutch was fine. Still have the accumulator (for now).
  11. Dec 23, 2022 at 10:03 PM
    #3311
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Drove mine today, was a little stiff but definitely operable. Plenty warm and rolling after about 3 minutes. Oh, and it was four degrees when I left
  12. Dec 25, 2022 at 5:17 PM
    #3312
    SerialKiller
    SerialKiller Well-Known Member
    2019 Cement Tacoma OR
    When I installed Firn’s disk I replaced all the fluid with the Lucas DOT 3 full synthetic and so far in the colder weather it seems better. I know in years past my clutch pedal was terrible leaving work when it was cold out. It would take like 10-15 minutes of driving to get a somewhat normal pedal feel back. So far this year it hasn’t happened.
    Toy_Runner and CygnusX191 like this.
  13. Dec 25, 2022 at 7:44 PM
    #3313
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    10°F my clutch pedal was reasonable
    CygnusX191 and shakerhood like this.
  14. Feb 11, 2023 at 1:51 PM
    #3314
    sdshack
    sdshack Well-Known Member
    TN
    ‘18 Tacoma OR 6MT (SOLD) - ‘99 4Runner Limited - ‘10 Cayenne TSSY - too many BMWs
    Looks like this thread hasn’t been very active lately, but I never got around to doing this mod on my truck and now I’m selling it. I have a brand new accumulator I’d gladly sell for less than Toyota’s price if anyone is looking for one to modify and swap into their truck with no down time.
  15. Feb 17, 2023 at 11:23 AM
    #3315
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Has anyone tried drilling the passages through to each other? I'm thinking it could be done, and it would work just as well. You could also claim ignorance if the dealer were to find that it has been modified. As in, the part was improperly (overdrilled) from the factory. In which case, I doubt it could be the root of a problem, and if it were, you wouldn't falsely blame them for it anyway. Lol! It is Friday after all!
  16. Feb 17, 2023 at 11:28 AM
    #3316
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You could, but you are very likely to ruin the flare seat in the process.
    The stock accumulator comes only as an assembled part. There is no reason for a shop to open it up. Further, there is next to no warranty on the clutch system anyway.
    In the end, @Firn 's disk is the simplest operation.
    Dremel'ing allows for a fast and pretty ham-fisted approach to modding the existing part.
    90% of the effort is gaining access and buttoning up.
  17. Feb 17, 2023 at 12:18 PM
    #3317
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I looked into drilling. It didn't work well because the brass insert spun out.
  18. Feb 17, 2023 at 1:12 PM
    #3318
    petethemeat
    Pete
    Ontario
    2023 TRD OR AC MT
    Thank you for the complete and thorough details, I didn't read through the whole thread. I figured there must be a reason that drilling wasn't an option besides the possibility of gooning the flare seat.
  19. Feb 17, 2023 at 1:21 PM
    #3319
    tonered
    tony
    Lynnwood, WA
    o_O
    :D
    :cheers:
  20. Feb 17, 2023 at 1:51 PM
    #3320
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    No dealership ever checks these.
    In the rare case of clutch failure, at best it was just be in the long list of parts to replace.
    petethemeat[QUOTED] likes this.
