MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Feb 21, 2023 at 9:29 AM
    #3321
    TacoRL
    TacoRL Member
    2020 Manual TRD Off-Road DCSB
    Is there a set of instructions for bleeding the clutch post delete?
    I'm not sure if I'll have to bleed the brakes as well. If not will I need extra brake fluid?
    CygnusX191 likes this.
  2. Feb 21, 2023 at 9:31 AM
    #3322
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It's just like bleeding brakes except you'll have to pick the pedal up off the floor after opening / closing the bleed nipple.
    Clutches are totally independent of the brakes.
    The ORs have a small reservoir, so do have fluid on hand.
    CygnusX191 and TacoRL[QUOTED] like this.
  3. Feb 23, 2023 at 3:21 AM
    #3323
    Danbest82
    Danbest82 Member
    Dan
    Northern Westchester, NY
    2019 Toyota Tacoma TRD Off Road 6-speed
    P265/75R16 Falken Wildpeak AT3W on stock Rims Spidertrax 1.5in wheel spacers Alldogs Offroad RCKilla 2" Coil Spring & 1.5" AAL(with overload spring) for about 2" lift. Bilstein 5100s front and rear [great setup. Soft but handles well] - need to upgrade spring to heavier rate though Lil b's hybrid front bumper mid-bar with prismatic powders cast black NY Westchester Coatings Aurora 3" cube amber led fogs(offbrandproducts.com) Apex badlands 12k lb winch TRD Pro Grill Aurora 30" NSSR white led (offbrandproducts.com) Aurora 10" NSSR amber led x2 (offbrandproducts.com) Weathertech vent visors Weathertech bug deflector BAK Revolver X2 Truck Bed Cover R4T tailgate lock AC drip tube mod RCI aluminum engine skid plate Caliraised premium roof rack with 360 light cutouts[stainless hardware upgrade, Fuck that rust-prone shit they sent with it] Aurora scene rear lights TRD reusable air filter K&N reusable cabin air filter AJT designs blackout vents and 4x4 knob Air on board switches Tacomods Anodized Aluminum Radio Knob eBay heated seats with rotary dial SpeedForm Throttle Controller Husky weatherbeater floor liners
    I plan to install ADD by @Firn soon, maybe this weekend. I'll report back with my results. Thanks for this thread of useful (and BS, haha) info.
    CygnusX191 and Firn like this.
  4. Feb 23, 2023 at 5:00 AM
    #3324
    MrMustacho
    MrMustacho Well-Known Member
    I got my disk but haven't gotten around doing this :annoyed:
  5. Feb 23, 2023 at 5:31 AM
    #3325
    tonered
    tony
    Lynnwood, WA
    I helped @NomadicCypress install a disk from @Firn . It definitely speeds up the process.
    Good stuff!
    NomadicCypress, Firn and CygnusX191 like this.
  6. Feb 23, 2023 at 7:56 AM
    #3326
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Looking to do the disk mod, but I'm so nervous about screwing something up.
  7. Feb 23, 2023 at 8:15 AM
    #3327
    MaxT
    MaxT MaxT
    St Marys, GA
    2022 Blue Crush TRD Sport MT
    Go Rhino Power Steps, MESO Puddle Pods, KDMAX Tune, Accumulator delete MOD, Mud Flaps, OEM Power Tailgate Lock, Hood Struts, Kicker Key Amp, New Speakers, New Shift Knob, OEM Bed Mat, MESO Total LED Taillights, LED 3RD Brake Light, Hitch 4TH Brake/Running/Backup Light, Scan Gauge III, Borla Cat-Back Exhaust, Jowett Oil Filter Cap, MESO Map and Dome Dual-Color Lights, Driver's Side Grab Handle Future: OEM LED Headlights, Peragon Bed Cover, Borla Exhaust Mid-Pipes
    On my 2022 Sport, the brake fluid reservoir is also the clutch fluid reservoir.
    Just keep it full as you bleed the clutch and no need to bleed the brakes.
    Pretty easy, other than physical access. Find a hose or bleed kit that fits over the slave cylinder bleed screw and run the other end into a plastic bottle with brake fluid in it.
    That keeps the hose from sucking more air into the system.
    My wife pumped the clutch pedal 20 times and held it. I opened the bleeder screw and watched the air and fluid come out.
    Close bleeder screw and repeat. But as stated above the clutch pedal stays on the floor and has to be physically pulled up to start the process again.
    I kept doing it until the last two times were nothing but fluid, no air, probably 8-10 times total.
    Clutch working so much better. I only added fluid once during the process and then topped it off at the end.
    Danbest82 and CygnusX191 like this.
  8. Feb 23, 2023 at 8:43 AM
    #3328
    tonered
    tony
    Lynnwood, WA
    That is the beauty of the @Firn 's disk. A couple less steps to deal with.
    And honestly, I got some air in my clutch line when swapping the TOB and some in @NomadicCypress 's line doing the ADM. I could still easily shift mine, but it was down to the floor. Within 5days, the system worked out all the air. @NomadicCypress was good in a day or so. Never had an issue doing about six other ADMs.
    So what I am saying is that there isn't a whole lot to worry about. Basically, if you can do a brake job, you can do the ADM.
  9. Feb 23, 2023 at 3:24 PM
    #3329
    Firn
    Firn Well-Known Member
    White OR
    Had some air in mine the first time I did it too. It fixed itself by the end of my first drive.
  10. Feb 23, 2023 at 3:40 PM
    #3330
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I did 50 burpees to flush clutch fluid, used most of a bottle. Got some bicep work pulling the pedal up too. That was a fun day!
  11. Feb 23, 2023 at 4:29 PM
    #3331
    MrMustacho
    I'm on the same boat, don't want to mess something up.
  12. Feb 23, 2023 at 5:46 PM
    #3332
    Firn
    White OR
    If you have done any maintenance yourself I would say you are safe. Very simple to do.
    If you want to be extra safe get some flare nut wrenches. Mine was a new truck so I risked it with regular wrenches, which worked fine. That said, flare nut wrenches are the safe bet.
    Aside from that it's pretty darn simple.
  13. Feb 23, 2023 at 8:01 PM
    #3333
    tonered
    tony
    Lynnwood, WA
    It was a few days of sweating it for me. I was happy to feel the engage point moving out, but feeling that stupid non-linear spring being non-linear sucked. Happy that I didn't need to touch it a second time.
  14. Mar 19, 2023 at 8:25 AM
    #3334
    Firn
    White OR
    Anyone else try the low viscosity fluid? I'm intersted in hearing others thoughts on it.
    Toy_Runner and CygnusX191 like this.
  15. Mar 22, 2023 at 8:08 AM
    #3335
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Finally did this to my 2nd gen the other day using the union and bending a new hardline.
    I can’t believe the difference in the feel of the pedal. Kinda regret waiting 10 years to do this mod.
  16. Mar 22, 2023 at 8:12 AM
    #3336
    tonered
    tony
    Lynnwood, WA
    :rofl::rofl:
    I'm glad that you're finally sorted out though. Good stuff!
  17. Apr 30, 2023 at 12:21 PM
    #3337
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    Did anyone that put a union in have problems with the clutch fork hitting the pressure plate
  18. Apr 30, 2023 at 2:02 PM
    #3338
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Been a while since I've been on this forum. What's the best way to do this mod nowadays?
  19. Apr 30, 2023 at 2:09 PM
    #3339
    tonered
    tony
    Lynnwood, WA
    Not this guy. That's a lot of throw.
  20. Apr 30, 2023 at 2:09 PM
    #3340
    tonered
    tony
    Lynnwood, WA
    @Firn 's disk. He has a thread in the BST section.
