MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. May 26, 2023 at 9:05 AM
    #3361
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    If you go with @Firn 's disk there is no modification to the line/accumulator itself, reversible if need be.
    CygnusX191 likes this.
  2. Jun 29, 2023 at 9:54 PM
    #3362
    rivets
    rivets Member
    Sorry if it's been asked. I just did this mod and it feels much better. However, when releasing the clutch and it disengages, it starts to "stick" a bit on release. Is that normal? I went under the pedal and noticed that this shaft has play in it. Thoughts?
    https://youtube.com/shorts/fdMSuELHTRI?feature=share
  3. Jun 29, 2023 at 9:56 PM
    #3363
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That play is normal. Sticking when releasing is not normal, though.
  4. Jun 29, 2023 at 9:59 PM
    #3364
    rivets
    rivets Member
    Thanks for the quick response! Sigh of relief here.
    Should the release be one smooth motion or does it have a noticeable "tension" transition (for a lack of better term) from when the clutch disengages to when the pedal comes all the way up?
  5. Jun 29, 2023 at 10:04 PM
    #3365
    BLtheP
    Plano, TX
    I want to say the clutch pedal return spring, due to the way it’s built and hooked to the pedal, provides two different feelings of feedback depending on the position of the pedal.
    Pscdouglas and CygnusX191 like this.
  6. Jun 29, 2023 at 10:07 PM
    #3366
    rivets
    rivets Member
    Sounds like it's perfectly normal then. Appreciate the insight!
  7. Jun 29, 2023 at 10:09 PM
    #3367
    BLtheP
    Plano, TX
    Is it acting differently now than before though? The accumulator delete is one thing, but the clutch spring feel is another and doesn’t change after the accumulator delete. So I’m not sure if you have a problem or not…
  8. Jun 29, 2023 at 10:12 PM
    #3368
    rivets
    rivets Member
    It's certainly different than stock. Stock was intrusive but it was at least one smooth motion engaging and disengaging. After the delete (hose bypass), it feels like there's two stages during disengagement instead of one continuous smooth motion. Engagement is normal, however. I've owned other MT vehicles in the past and this just feels different.
    For the record, this is a 2023 OR with 4k miles on it.
  9. Jun 29, 2023 at 10:26 PM
    #3369
    BLtheP
    Plano, TX
    How long ago did you finish up the work? My pedal felt very odd for about half a day, it still had air in it despite me bleeding a bunch. It worked itself to normal with some driving. The clutch still functioned normal but it felt very strange to the foot until it fixed itself. Maybe that’s what you’re feeling?
    rivets[QUOTED] and CygnusX191 like this.
  10. Jun 29, 2023 at 10:28 PM
    #3370
    rivets
    rivets Member
    That might be it. The job was done yesterday. I've only placed maybe 20 miles on it so far. It was bled several times too. I'll put some more miles on it and hopefully, it'll resolve itself
    CygnusX191 and BLtheP[QUOTED] like this.
  11. Jun 30, 2023 at 8:57 AM
    #3371
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Happened to me too.
    60,000+ miles later and no issues
    rivets likes this.
  12. Jun 30, 2023 at 10:08 AM
    #3372
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    went with the disc. always felt impossible to shift truck smoothly unless you did very slow. this fixed that issue.
    camaro322hp, RDT415 and CygnusX191 like this.
  13. Jul 11, 2023 at 5:38 PM
    #3373
    camaro322hp
    camaro322hp Active Member
    Tigard, OR
    2023 TRD Sport M6 // 1999 Z28 M6 // 2007 GSX-R750
    Hi all. My disc just arrived today (thanks @Firn) and I had a couple questions before I start. I have a '23 TRD sport and it looks like there is a single brake fluid reservoir shared by the brakes and the clutch, is that accurate? I don't see a separate reservoir for the clutch master cylinder.
    Also, on bleeding the clutch, never done that before. Am I opening the slave cylinder bleeder when the clutch pedal is on the floor or up position? And then closing it before moving the pedal again? Saw some videos that suggest gravity bleeding alone is enough, but wasn't sure on that.
    Thanks for any input. Looking forward to a less sloppy clutch.
  14. Jul 11, 2023 at 7:51 PM
    #3374
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That is correct, only one reservoir on the sport.
    Gravity bleed is fine. Just do it several times.
    Tip: wants the bleeder is closed and you are pumping the clutch, make sure there's enough fluid in the reservoir and leave the cap off. This will allow any free air pockets to get out easier. So you're not fighting against the seal. Once you've done this a couple times you can do your final push with the cap on. And see if you like the feel of your clutch.
    camaro322hp[QUOTED] likes this.
  15. Jul 11, 2023 at 8:04 PM
    #3375
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Gravity bleed seems to do the trick for most. Here's some that also did the pump method.
  16. Jul 11, 2023 at 8:41 PM
    #3376
    devinzz1
    devin
    2023 aclb trd or mt
    i completely drained system to swap all fluid to dot 5.1. gravity feeding was doing nothing. i happened to have a one way check valve brake bleeder that i put on and could quickly pump the clutch pedal and got every bit of air out.
  17. Jul 18, 2023 at 7:16 AM
    #3377
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Did the delete last night. I ended up drilling the passage through to each other. 7/64" bit. I was going to remove the accumulator entirely and had a prefab line and coupling on hand. I decided to try and carefully drill the passage since I had the line and coupling. The 3/16" line and brass seats in the accumulator are pretty close to 7/64" inside diameter. Drilling through was easy and fast. I still had to disassemble the accumulator to remove the swarf. Cleaned it thouroughly with brake clean and compressed air. After all was said and done this is just another way to accomplish the delete. :) I can feel the bite much better now.
  18. Aug 5, 2023 at 3:14 PM
    #3378
    RDT415
    RDT415 DUCTACO
    Sonoma County
    I’ve had @Firn ’s disk on my work bench for a month now. Found some time this morning and got the install done.
    I am an absolute moron for waiting so long. Should have been the first thing I did to my truck. Rev matching downshifts, creeping in traffic, backing up, banging through gears.. Anything clutch related is so much better. Especially with the YotaWerx Blackhawk tune / throttle response.
    I was solo this morning so I used a vacuum bleeder @10 psi with zero issues. If you are on the fence.. Do it.
    Thanks Firn for helping as out with an easy way to unf**k our hydraulic clutch system.
    :cheers:
    ThisBen, 6MTPro, StandardTaco and 9 others like this.
  19. Aug 5, 2023 at 3:48 PM
    #3379
    Firn
    Firn Well-Known Member
    White OR
    Thank you for the awesome feedback!
  20. Aug 15, 2023 at 6:39 AM
    #3380
    icer22x
    icer22x Too Poor For Mods
    Northwest Arkansas
    2022 TRD Off Road MT - Barcelona Red
    KDMax Tune 10.0 ADM
    Just did the hack and don’t really notice any improvement. Looking at the picture on page one, I definitely didn’t grind my channel as deep and wide. Could this be causing my lack of improvement?
