MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Dec 31, 2018 at 5:37 PM
    #401
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yep.
    I'm tucking mine away for sure.
    Although, when my warranty is up I'll probably beat it to death with a 5 pound maul. Ummm that's therapy BTW :crazy:
  2. Dec 31, 2018 at 5:45 PM
    #402
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    So, maybe a dumb question here, but what are the sealing elements on the accumulator? I don't see a gasket on the mating surface to the mounting plate. It seems like the super-simple option would be to gut the thing and re-install it. Even if that required some drilling it could be done for $0. This is 100% on my list of things to do, but I haven't looked at it yet. I'm sure someone probably thought of this but I didn't see it mentioned.
  3. Dec 31, 2018 at 5:52 PM
    #403
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Gutting it, & re-drilling is possible but not feasible. See my evaluation in post #297
    Edit: Gasket is internal to the plate. See the last 2 pics in the OP.
    tonered[OP] likes this.
  4. Dec 31, 2018 at 5:57 PM
    #404
    lapoltba
    CT - 06076
    :thumbsup: Thank you. I figured there was a good reason we were spending money on a mod that seemed like it could have been done for free!
    On the list of parts to pick up when I have time.
    *Edit* Saw those pictures but it wasn't exactly clear how that worked. The round clip is just a spacer, and the brown part is obviously the sealing element. Wouldn't that leave a gap and make the seal act like a diaphragm?
  5. Dec 31, 2018 at 6:12 PM
    #405
    fatboyfirebass
    kinda. The brass inserts just seal the flared tubes. The black quad seal is the gasket for the actual accumulator chamber. It sits under the plate with the spring directly over it , on the outside, between the plate and the body of the transmission. Basically the fluid travels in one port, up one of the channels to the very thin space between the machined surface and the plate, then down the other channel and out the other port.
  6. Dec 31, 2018 at 6:13 PM
    #406
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    My truck is passed the 3 year powertrain warranty (bought in 2015), has full arb lockers, re-geared, an alternate fuse/relay box full of electrical addons, aftermarket sound system, CMC, all different suspension. What I'm trying to say is based on previous experiences for anything warranty related with this truck, is that the dealer is more headache than taking care of it myself, or taking the truck Rogue Offroad becaused @Despized is what I call a Master Toyota Tacoma Technician.
    Everything I've replaced/upgraded on the truck was sold, I won't look back. I won't waste another minute at the dealer unless I'm buying a used car for my wife or myself.
  7. Dec 31, 2018 at 6:29 PM
    #407
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    That plus that I feel the disk is pulled inward during the engagement to squish the gasket further reduce the flow. This made it into an odd rubber band when I needed to modulate the stroke.
    Just a note that your powertrain warranty is something like 96mo/80,000mi?
  8. Dec 31, 2018 at 6:36 PM
    #408
    ajsabra
    Sin city
    You're right I goofed that, 3 year 36k is for everything. Every problem I did have they did not fix anyways, well with one exception they replaced my radio because it rebooted all the time a week into ownership. Other than that they were worthless and wasted my valuable time.
    tonered[QUOTED][OP] likes this.
  9. Dec 31, 2018 at 6:36 PM
    #409
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    PERFECT!
    Couldn’t have explained it better .
    Before I learned of this acumaltor I was blaming my self ,lazy foot,bad timing,getting old etc .
    Can’t wait to do this mod.
    oconnor, tonered[OP], MOC221_ and 4 others like this.
  10. Dec 31, 2018 at 6:45 PM
    #410
    lapoltba
    CT - 06076
    This is exactly how I feel. I shift to 1st and try to do a rolling start sometimes. 90% of the time it's garbage and then the rest it somehow works perfectly. Never had an issue in any other vehicle before
  11. Dec 31, 2018 at 6:45 PM
    #411
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Will let you know when it arrives
  12. Dec 31, 2018 at 10:24 PM
    #412
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Stop and go traffic the most, around town stuff, moving a trailer... and definitely off road, which I do use my truck for. Basically every use case for the truck.
    I've driven lots of manuals including 80s and 90s Toyotas, GM stuff, etc etc, and I belive the accumulator style clutch started coming in the early 2000s era industry wide.... It may be "normal" by today's standards, but that doesn't mean it doesn't suck.
    If you like your truck as is out of the box, good for you. I don't. Luckily, there are options for both of us to get what we want.
    MOC221_ and tonered[OP] like this.
  13. Jan 2, 2019 at 7:53 AM
    #413
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    I've never felt more insecure/doubtful about my ability to operate a vehicle more than this truck has made me feel... I thought I was going crazy until I found out I was not alone lol I love this truck, but fuck Toyota at the same time.
  14. Jan 2, 2019 at 3:55 PM
    #414
    Reluctanse
    Sam
    Newberg, Oregon
    Smoothest drive in to work today ever. Every shift the way it should be. It's like I can drive a clutch correctly again. :cool:
  15. Jan 2, 2019 at 3:58 PM
    #415
    MOC221_
    Frank
    Good to hear.
    How cold was it and what about the pedal stiffness in said cold? Any change?
  16. Jan 2, 2019 at 4:04 PM
    #416
    fatboyfirebass
    right at 32F, (0C) this morning in NW Ohio. No pedal stiffness
  17. Jan 2, 2019 at 4:07 PM
    #417
    MOC221_
    Frank
    Right on, I appreciate the feedback :)
    Mine gets really slow at about -10C.
    Anyone who has done the mod care to comment on pedal stiffness at that temp or below?
  18. Jan 2, 2019 at 4:16 PM
    #418
    Reluctanse
    Sam
    Newberg, Oregon
    I expected the pedal to return faster after I did this, but no change.
    It was in the low 30s this morning. Honestly pedal feel is about the same as it was, which is still kinda shitty in my opinion. Control is much better especially at the engagement point, but the pedal still has that slow to return feel.
    It wasn't noticably any stiffer or slower than before, but not faster either.
  19. Jan 2, 2019 at 4:18 PM
    #419
    MOC221_
    Frank
    Thanks man, looking forward to getting this done :thumbsup:
  20. Jan 2, 2019 at 4:27 PM
    #420
    Reluctanse
    Sam
    Newberg, Oregon
    Took about 2 and a half hours, fwiw. In the freezing cold. But I was dedicated to getting it done :cool:
