MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 5, 2019 at 2:11 PM
    #461
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    I had my wife pump and hold the clutch while I release the bleeder valve. Took 3 tries and less than a few mins to bleed the system.
    tonered[OP] likes this.
  2. Jan 5, 2019 at 2:11 PM
    #462
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    IT was a breeze on mine... my son helped out, by the 5th/6th pump all was good.
  3. Jan 5, 2019 at 2:12 PM
    #463
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
  4. Jan 5, 2019 at 2:44 PM
    #464
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Easy!
    MOC221_ likes this.
  5. Jan 5, 2019 at 3:39 PM
    #465
    Shellshock
    Iowa
    So apparently I’m the problem child. I’ve got a leak at my joint with the upper hardline to my line. Leaking on the bottom side… suggestions?
    @tonered @Trident904
  6. Jan 5, 2019 at 3:41 PM
    #466
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    With my minimal experience using flared fittings, if you can't get the nut completely seated by hand it isn't going to seal well. The tubing has to be well aligned and the nut should basically just go in until it seats the flare in the fitting. Then you just tighten it down with a wrench.
  7. Jan 5, 2019 at 3:46 PM
    #467
    Shellshock
    Iowa
    Gotcha. I’m going to pull it all back out and adjust the line a bit and see if I can get it to seal. The other two spots are good and not leaking.
    tonered[OP], MOC221_ and TeecoTaco like this.
  8. Jan 5, 2019 at 3:52 PM
    #468
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Did you do the upper connection last?
    When I connected mine, I did the upper connection first, then the lower. I found that I had to "fiddle" with the connection to the slave cylinder quite a bit to get it to start. As mentioned by @lapoltba , I made all the connections by hand and made sure the fittings were fully seated first before I went to the wrenches
    Norton, tonered[OP] and TeecoTaco like this.
  9. Jan 5, 2019 at 4:02 PM
    #469
    Shellshock
    Iowa
    Yep I did lower first, upper last.
    I’ll try it in reverse and see if I have better luck.
  10. Jan 5, 2019 at 4:07 PM
    #470
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    I had a leak at the same spot first time. I thought I tighten but it wasn’t enough. Gotta torque it down good.
  11. Jan 5, 2019 at 4:38 PM
    #471
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Tighten that bitch up. 1/2” wrench and 10mm flare.
    tonered[OP] and MOC221_ like this.
  12. Jan 5, 2019 at 4:39 PM
    #472
    Trident904
    Brian
    17 4Runner TRD OR
    Shoulda bought one of my kits. They come with the union already tightened.
  13. Jan 5, 2019 at 4:48 PM
    #473
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Perfect thank you sir !! I’ll e transfer you cost or send you a bag of jerky ?!?!
    TeecoTaco likes this.
  14. Jan 5, 2019 at 4:49 PM
    #474
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    You’ve already done it ?
    Edit nvm just went back a page ,, nice work!
  15. Jan 5, 2019 at 4:52 PM
    #475
    MOC221_
    Frank
    Yes sir, got er done today. Look back a few posts and you'll see my ugly assed job lol.
  16. Jan 5, 2019 at 4:53 PM
    #476
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Just did ,, nothin wrong with that man :burnrubber:
  17. Jan 5, 2019 at 4:55 PM
    #477
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Oh no man it's on...wait wut? Jerky? Do tell!
  18. Jan 5, 2019 at 4:58 PM
    #478
    MOC221_
    Frank
    I've had some of that Jerky.. nom nom nom :hungry:
    TeecoTaco[QUOTED] likes this.
  19. Jan 5, 2019 at 5:09 PM
    #479
    tonered
    tony
    Lynnwood, WA
    Sorry, @Shellshock !
    Hand threading the fittings is very important, esp as the alignment isn't a factory part.
    Good wrist tight will get you there. Not a full arm pull though.
  20. Jan 5, 2019 at 5:10 PM
    #480
    tonered
    tony
    Lynnwood, WA
    Yum! But, @TeecoTaco is the man!
    :canada:
