MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 5, 2019 at 9:24 PM
    #501
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Im wondering if you just lost system pressure like if a vacuum bleader was used. Try pushing the clutch to the floor and sliding your foot off the side to let it return at full speed a few times maybe? That should suck fluid from the reservoir.
    tonered[OP] likes this.
  2. Jan 5, 2019 at 9:27 PM
    #502
    Shellshock
    Iowa
    Did that a few times. It sticks then jumps up. It’s feels like it does when it’s very cold and slow.
  3. Jan 5, 2019 at 9:35 PM
    #503
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    Sounds like you still have air trapped in the system. What method are you using to bleed the line?
  4. Jan 5, 2019 at 9:39 PM
    #504
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I will pick one up some time this month. Will wait until summer to do the delete, too cold to be under the truck now lol.
    doublethebass likes this.
  5. Jan 5, 2019 at 10:00 PM
    #505
    Shellshock
    Iowa
    That was my thought too but if there is I’ve got no idea how or where it’s stuck if there is because after I bleed it, straight fluid comes out like it should. When I took off the delete, it ran right out with no interruptions. Done the normal open valve press clutch close valve release.
    I’ve tried about everything I can think of from the normal bleeding to gravity to running fluid through the delete then finishing the last connection and bleeding
    Constantly checked to make sure it was full so I didn’t suck more air in.
    It’s doesn’t make any sense to me
  6. Jan 5, 2019 at 10:13 PM
    #506
    nxcess
    '17 Tacoma MT 4x4
    OVTuned
    That's an odd method. I've always pump the clutch pedal a few times, then hold the clutch pedal to the floor, open and close bleeder valve. It's a 2 person job but can be done with 1 if you use a block of wood to hold the pedal to the floor.
    Norton and 2016trdtacoma like this.
  7. Jan 5, 2019 at 10:26 PM
    #507
    Shellshock
    Iowa
    I actually did it that way first. Then tried the other way I described. Been a long day of fighting with my truck. Had a second person today that could pump clutch and I opened and closed valve.
    At this point I’m not sure there’s a way I’ve seen suggested somewhere I haven’t tried
  8. Jan 5, 2019 at 10:39 PM
    #508
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    If you are now solid with no leaks, this sounds like my past experience with the vacuum bleeder.
    It is shitty because the master has no bleed nipple nor return spring. So what you have to do is pump the pedal by hand until you get the least amount of pressure. Hold and bleed that. Rinse and repeat.
    This is gonna take like 20 tries or so with probably a couple hundred pumps to play with. Eventually, the system pressure will build. Keep an eye on the reservoir. If you suck air, it is back to square one.
    I think this has to do with the compensation port and that it is difficult to get it to start sucking. You can see this if you put some brake fluid in a Mity Vac canister and apply a vacuum. You'll see a bunch of air bubbles appear and go away when the vacuum is released. You just gotta work through it because the compensation port is tiny.
    Norton and fatboyfirebass like this.
  9. Jan 5, 2019 at 10:56 PM
    #509
    Shellshock
    Iowa
    No leaks that I’ve seen this time. Not sure yet if I’ll be able to work on it tomorrow or not yet, we’ll see.
    If that works, that means my delete was working before I took it off, I just couldn’t get the air out
    Bah!
    tonered[QUOTED][OP], iexc and MOC221_ like this.
  10. Jan 6, 2019 at 4:43 AM
    #510
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Sounds like since you did the bottom connector first you got that whole lines worth of air stuck in there and needs to be bled out.
    May not be necessary but if youve got a sloped driveway maybe do it on that so you raise the front end and the nipple end of the MC so the air floats a little closer to the nipple. Probably not needed, but it could potentially help. Be sure to block your wheels properly.
    Ive also had success getting stubborned bubbles out of the brake system of my VW by tapping the lines and MC with a wrench a couple times
  11. Jan 6, 2019 at 5:05 AM
    #511
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Hope you get er sorted bud :fingerscrossed:
    The reward is how much better the clutch works!
    tonered[OP], nxcess and Livinserene like this.
  12. Jan 6, 2019 at 7:52 AM
    #512
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Good morning and thank you again.
    I can pick it up any time today or coming week nights for fun or if you prefer to ship it,it’s your call.
    I am in no rush ,let me know.
    Peace:thumbsup:
  13. Jan 6, 2019 at 9:47 AM
    #513
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Have you checked the free play between the pedal and the master cylinder push rod? Seen reports of high variation from the factory, perhaps it is affecting the way the ports in the MC are uncovered during actuation and causing you to have more issues than others?
    I'd be curious to hear others experience with cold weather improvement. That is the only time I notice something strange....not to mention pedal stiffness.
    MOC221_ and tonered[OP] like this.
  14. Jan 6, 2019 at 10:24 AM
    #514
    Shellshock
    Iowa
    Thanks for all the replies fellas.
    Checked truck this morning and I’m not finding any signs of leak. Truck is able to move but the clutch throw is all out of whack.
    Much colder here today (60 yesterday 20-30 today) and I think I’ve had about enough fun so limped it down to local repair guy and will have him check it out and get it swapped this week. He’s got heat and lift so I figure he can probably knock it out relatively quickly vs me in the cold garage.
    Hopefully it’s just bad luck on my part and nothing major :fingerscrossed:
  15. Jan 6, 2019 at 10:35 AM
    #515
    MOC221_
    Frank
    Before the delete, my clutch would become very slow at temps -10C and colder.
    Just got it done yesterday, and about +1C right now in my area (Atlantic Canada).
    It's supposed to get below -10C later this week, I'll report back then.
  16. Jan 6, 2019 at 1:34 PM
    #516
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Do you have any noise from the throwout bearing? Is it whining at idle?
    Mine started sticking when it was days from total failure.
  17. Jan 6, 2019 at 3:12 PM
    #517
    Shellshock
    Iowa
    Nothing that I’ve heard. Everything has seemed fine as far as I can tell. I haven’t noticed anything out of the ordinary, just the normal clutch wonkiness this truck has had since day 1. Unless I’ve just gotten used to something that isn’t normal...
  18. Jan 6, 2019 at 4:16 PM
    #518
    Trident904
    Brian
    17 4Runner TRD OR
    Just so everyone is aware, you have to tighten the nut that on the cylinder line all the way until it won’t turn anymore. Otherwise, it will leak.
    2016trdtacoma likes this.
  19. Jan 6, 2019 at 6:09 PM
    #519
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    I live in Utah and HATE how slow the clutch is on cold mornings! It drives so so crazy. I am really hoping this delete solves this.
  20. Jan 6, 2019 at 6:18 PM
    #520
    Shellshock
    Iowa
    Same here. That was my main reason in addition to the other weirdness it has from time to time.
