MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 6, 2019 at 6:37 PM
    #521
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Hey Kalede, it won't let me PM you. Reach out pls
  2. Jan 7, 2019 at 11:33 AM
    #522
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    More supplies arriving 1/9. I will have enough stuff to make 25 kits and then I'm done. I've got SAS stuff to do for my truck.
    Get em while they're hot.
    Norilsk likes this.
  3. Jan 7, 2019 at 11:43 AM
    #523
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Found a few places to get braided stainless lines made to the drawing I posted ~$20 +s/h.
    Norton, MOC221_ and tonered[OP] like this.
  4. Jan 7, 2019 at 1:21 PM
    #524
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Post a pic and info when you get it installed!
    MOC221_ likes this.
  5. Jan 7, 2019 at 1:37 PM
    #525
    lapoltba
    CT - 06076
    10-4 will do. Trying to decide on length and possibly getting brackets to bolt on.
    Can someone tell me the spacing of the upper two mounting bolts? Thinking of an l bracket with clip there and one on the lower mount point..
    MOC221_ and tonered[QUOTED][OP] like this.
  6. Jan 7, 2019 at 1:38 PM
    #526
    tonered
    tony
    Lynnwood, WA
    Sorry. Mine is covered. If it wasn't the biggest PITA part of the install, I'd get that for you.
  7. Jan 7, 2019 at 1:39 PM
    #527
    lapoltba
    CT - 06076
    LOL, same reason I'm not taking mine apart yet.
    tonered[QUOTED][OP] likes this.
  8. Jan 7, 2019 at 1:42 PM
    #528
    tonered
    tony
    Lynnwood, WA
    Haha!
    The exhaust support is easier to pull and gives you much more room to work. Checking your ZIP, soak the bolt on the exhaust flange with PB Blaster or some other penetrating oil a couple days before you get in there.
    MOC221_ likes this.
  9. Jan 7, 2019 at 1:46 PM
    #529
    lapoltba
    CT - 06076
    Luckily my truck has only seen about 3/4 of a winter since I picked up a winter beater/daily. The truck is too nice and.expensive to put 25k miles a year on. I'll definitely hit it with something just in case though.
  10. Jan 7, 2019 at 1:57 PM
    #530
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Word.
    I live in the worst rust belt ever and that bolt on the flange came out without trouble. First thing I did once I had the vehicle in the air was to blast it and the fittings/bleed valve with penetrating oil. :thumbsup:
  11. Jan 7, 2019 at 2:00 PM
    #531
    tonered
    tony
    Lynnwood, WA
    I don't miss the east coast salt. Not in the least. Bad wrenching memories when I was a kid.
    Norton and MOC221_[QUOTED] like this.
  12. Jan 7, 2019 at 2:00 PM
    #532
    MOC221_
    Frank
    You could also re-use the plate which forms the back of the accumulator itself.. 4 convenient holes in that. Someone on here must have a plate or accumulator body to get you the numbers..
    nxcess and tonered[OP] like this.
  13. Jan 7, 2019 at 2:10 PM
    #533
    lapoltba
    CT - 06076
    I was thinking that but wasn't sure how thick it was. I don't have a way to bend it easily at home.
    Would work for dimensions though.
    MOC221_[QUOTED] and tonered[OP] like this.
  14. Jan 7, 2019 at 2:33 PM
    #534
    Shellshock
    Iowa
    If you'd posted earlier I could have gotten this for you. don't have my truck now
    tonered[OP] likes this.
  15. Jan 7, 2019 at 2:36 PM
    #535
    MOC221_
    Frank
    Well, here's a closeup.. I just shoehorned a clamp onto the plate and called it a day:
    Norton, nxcess, tonered[OP] and 2 others like this.
  16. Jan 7, 2019 at 2:38 PM
    #536
    Shellshock
    Iowa
    lmao ive put 50,000 on mine this year
  17. Jan 7, 2019 at 2:40 PM
    #537
    MOC221_
    Frank
    Lol, there was corrosion in the accumulator body where the disc sits on the seal. To get the disc to come out, I plugged the outlet with a fitting and a pinched off piece of brake line. Then I put the accumulator in a vise, put on my PPE and applied air pressure to the inlet. A quick shot with 90 psi on tap had that thing outa there n a jiffy! Yep, check the area for people first :thumbsup:
  18. Jan 7, 2019 at 2:49 PM
    #538
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    This trick has never failed me. It’s the only way I will bleed motorcycle brakes/clutch.
    For stubborn air in the system it’s easier to push the fluid up from the bleeder to the reservoir (empty the reservoir first). I use a oil squirt can (the kind with a trigger) and a piece of clear tubing. Think of how a doctor uses a syringe, get the air out of the tube and then attach it to the bleeder. Only open it up enough to push the fluid in.
  19. Jan 7, 2019 at 3:49 PM
    #539
    lapoltba
    CT - 06076
    For work or personal use? My miles are nearly 100% work, and I like to use my money to buy nice things for myself and not to use for more work related activities.
  20. Jan 7, 2019 at 4:01 PM
    #540
    lapoltba
    CT - 06076
    Browsed through all the pictures, thank you. It looks like that is in approximately the original location?
