MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Sep 16, 2018 at 1:10 PM
    #41
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Thanks. I am very happy with the results.
    Most likely, it is ball spring with some sort of damper similar to a strut. It tries to smooth out the clutch movement, which might be good for noobs, but bothers some folks who know how to drive?
    Norton, MOC221_ and stun gun[QUOTED] like this.
  2. Sep 16, 2018 at 1:16 PM
    #42
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    It basically slows down the action of the clutch fluid travel through the hydraulic system. Creating slower clutch engagement/disengagement.
  3. Sep 16, 2018 at 9:01 PM
    #43
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    What a bizarre design. It's like a clutch cable in need of lube, and that's exactly how it feels driving my truck. I can't wait to do this mod. Someone could capitalize on it by welding up a run of fittings and brackets.
  4. Sep 16, 2018 at 9:40 PM
    #44
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    No wonder the clutch is so damn stiff in the winter...
    tonered[OP] and MOC221_ like this.
  5. Sep 17, 2018 at 2:19 AM
    #45
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Truth. I'd shell out for that.
  6. Sep 17, 2018 at 2:49 AM
    #46
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    This ^^^
    @7r41lbr34k3r
  7. Sep 17, 2018 at 3:31 AM
    #47
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Does the 1st and 2nd Gen have this also? Thinking about an MT in my future 3rd Gen purchase.
  8. Sep 17, 2018 at 4:36 AM
    #48
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    I'm in.
    I will be going dark from 9/22 through 9/29-ish, but otherwise I can join in on the fun if you think machining would provide the best solution.
  9. Sep 17, 2018 at 5:24 AM
    #49
    tonered
    tony
    Lynnwood, WA
    The 2nd Gens do have this. That's where some of the ideas about the delete came from.
    I don't know about the 1st Gens.
    Cool! I'll send you the accumulator so that you can take a look.
  10. Sep 17, 2018 at 5:34 AM
    #50
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    To reduce wear by keeping a constant clutch pressure. Why add $100 worth of componentry if it did not improve reliability and durability?
    stun gun[QUOTED] likes this.
  11. Sep 17, 2018 at 5:36 AM
    #51
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol Tony! It only bothers some folks. If I don't know anything else in life I know how to drive a stick. With that said, the accumulator does not bother me one bit.
    BillyToy likes this.
  12. Sep 17, 2018 at 5:59 AM
    #52
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    That's the same logic around the Dual Mass flywheels some manufacturers use. It in no way increases durability of the clutch system, and is twice as expensive to replace as a normal flywheel. The accumulator is a piece that theoretically will never have to be replaced, but it does affect how you release the clutch. It is designed to stop shock loads on the transmission and other components. My Legacy GT had both an accumulator and a dual mass flywheel. Made it harder to launch it, but that stopped me from burning out the clutch, as I knew it took a little time for everything to engage. Notice how Toyota is denying a lot of the clutch warranty claims? They put the possible failure point on something not covered by their warranty to protect the transmission from inexperienced drivers. I understand why they did it, but once my power train is up, or when I replace a clutch, this is coming out.
    Norton, doublethebass and tonered[OP] like this.
  13. Sep 17, 2018 at 6:32 AM
    #53
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Well yeah, I’m sure it was added deliberately. I just wanted to know how it did what it did. Like say, it acted like an expansion tank etc
    tonered[OP] and hiPSI[QUOTED] like this.
  14. Sep 17, 2018 at 6:36 AM
    #54
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Scott, unless you work as a warranty analyst for Toyota, you have no idea how many warranty claims Toyota is denying. Please do not use what you read here on TW as a basis for real life, as we are only a small fraction of owners and enthusiasts to boot. The real story might be completely opposite of what you read here. Right?
    I design accumulators into my circuits when I need A) guaranteed pressure for a critical action or B) when I need to make sure a constant pressure is needed. I use accumulators from an ounce to 20 gallon and both piston and bladder types in my circuits.
    While I understand those who want to change their clutch characteristics to get a better "feel," I also know Toyota is not a company who puts components in their circuit unnecessarily. I of course didn't design the clutch circuit and it feels fine to me so I am not going to question the engineer, so if something is put there to add reliability and durability, I am all for that. But again, I understand that some want to change it up and I am fine with that.
  15. Sep 17, 2018 at 6:38 AM
    #55
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
  16. Sep 17, 2018 at 6:39 AM
    #56
    tonered
    tony
    Lynnwood, WA
    I'd be surprised if this part cost Toyota $20. For me over the past year, getting going in 1st and downshifting into 2nd (or 1st when in stop-n-go traffic) felt like I was on the clutch pedal longer than I needed to be. IMHO, the accumulator felt like it was delaying engagement.
    Also, I'm a big fan of hydraulic clutches and this one felt different than the others that I have had. Now, it doesn't.
    Okay. I'll edit that. :cheers:
    hiPSI[QUOTED] likes this.
  17. Sep 17, 2018 at 6:41 AM
    #57
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If I had to guess, and without talking to the guy who originally designed the circuit, I would say it is in there to simply smooth out the clutch engagement. Nothing more, nothing less. While for a purist, this could be an annoyance. For me, this adds longevity to the clutch.
  18. Sep 17, 2018 at 6:46 AM
    #58
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    A friend of mine is an engineer for GM and his job is to shave cents out of designs. He worked on wiper motors for two years to save fifty cents. So if it were "only" $20 that would be huge. I used $100 just as a number. The volume of components that a company like Toyota uses in a month is staggering. ANY savings is a big deal, even just two cents!
  19. Sep 17, 2018 at 6:54 AM
    #59
    MOC221_
    Frank
    Good lord, can we just have this one? Ok I get it, it's there for a reason.
    I'm pretty sure anyone who does this delete is a big boy and understands he's changing the original design.
    I don't like the feel either FWIW.
    Keep going Tony!
    Norton, Shellshock and mtip like this.
  20. Sep 17, 2018 at 6:55 AM
    #60
    tonered
    tony
    Lynnwood, WA
    I get that. Boeing was studying what the weight savings would be if they revised their fastener grip length spec that requires two bare threads showing beyond a nut / collar.
    I'm just saying looking at the part itself and a 200,000+ part per year run, that is not a $100 part. The list price is $109. Half that for wholesale and another half to actual?
    On the GM side, an expert once said that an extra $2 spread over the entire interior could be seen and felt by the customers. Of course, they weren't spending that $2.
