MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 12, 2019 at 7:39 AM
    #581
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Quick feedback since doing the mod on Thursday,I did the dremel hack mod,35 minutes start to finish. I just love it,shifts are smooth and predictable,unlike before when it seemed like you were slipping the clutch all the time waiting for it to engage.
  2. Jan 12, 2019 at 7:42 AM
    #582
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    EXACTLY.
    Everything is repeatable now, muscle memory. Taking off on a steep grade? Also predictable. I love it.
    It's weird, here I am raving over something that Toyota should have known M/T pilots would want from their trucks.
  3. Jan 12, 2019 at 7:43 AM
    #583
    M1Awolf
    Rob
    Montana
  4. Jan 12, 2019 at 8:28 AM
    #584
    Shellshock
    Iowa
    Well fock. Figure out how to fix that!
    tonered[OP] likes this.
  5. Jan 12, 2019 at 8:28 AM
    #585
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    You mean like having it go as well as give you more power when you press the accelerator pedal? Thank god OVtune fixed that one too.
    MOC221_[QUOTED] likes this.
  6. Jan 12, 2019 at 8:37 AM
    #586
    MOC221_
    Frank
    :amen:
  7. Jan 12, 2019 at 8:39 AM
    #587
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I never had this issue, so I have nothing to look for. Garaged and temps usually above freezing around here, I suppose.
    @RedBeard1 said that removing the rubber gaiter from the slave worked for him? GDM, anybody?
    MOC221_ likes this.
  8. Jan 12, 2019 at 12:36 PM
    #588
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Something is changing with lower temperatures. I would be inclined to change fluid first and see what happens.
    Didn’t someone mention Ford brake fluid?? IDK I have CRS (can’t remember shit).
    I would try it but we don’t get that cold here :p
  9. Jan 12, 2019 at 12:44 PM
    #589
    lapoltba
    CT - 06076
    IDK that there is much that can be done. The brake fluid changes viscosity with temperature like most oils and fluids in a vehicle. I would doubt there exists a compatible fluid that we could use that maintains viscosity in cold temperatures. Remember guys, our clutch hydraulics use the same reservoir as our brakes. I personally will deal with a sluggish pedal for a few miles and not risk compromising my braking system and the expensive components in it. If the Ford fluid meets all the required specs that may be worth a try.
    MOC221_ likes this.
  10. Jan 12, 2019 at 12:50 PM
    #590
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Ive heard good things about Motul brake fluid
    https://www.motul.com/us/en-US/products/dot-5-1-brake-fluid
    mtip likes this.
  11. Jan 12, 2019 at 12:51 PM
    #591
    MOC221_
    Frank
    No sharing of reservoir on OR/PRO... BRO
    Shellshock and nxcess like this.
  12. Jan 12, 2019 at 1:12 PM
    #592
    tonered
    tony
    Lynnwood, WA
    Do not use 5.1. It is good stuff and is compatible, but shrank the seals a bit and caused my masters to leak on my motorcycle, both stock and a new one.
    I swapped in Motul DOT 4 and things got better.
    Norton and mtip like this.
  13. Jan 12, 2019 at 1:22 PM
    #593
    lapoltba
    CT - 06076
    Well maybe I wasn't talking about Pro/OR bros! :angrygirl:
    tonered[OP] and MOC221_[QUOTED] like this.
  14. Jan 12, 2019 at 2:33 PM
    #594
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I would have bet my new avatar that it would help out in colder weather. In fact, I will still say that it has to help a bit. If you don't have
    some fluid sitting in a chunk of ice cold metal, it has to help the fluid flow better. Surprisingly, we haven't had any very cold weather here
    yet this winter. Ah well... like you said, it's more about regaining the clutch feel.
  15. Jan 13, 2019 at 8:04 AM
    #595
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    Did the ADM on my truck yesterday. All I can say is holy crap, I know how to drive a stick again!!
    This along with OVTune (1.5 years ago) are by far the best two mods I've done so far; they compliment each other perfectly!
    MOC221_, kgautier, mtip and 2 others like this.
  16. Jan 13, 2019 at 8:16 AM
    #596
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    2 kits left
    specter208 likes this.
  17. Jan 13, 2019 at 8:24 AM
    #597
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Can I get one please?
  18. Jan 13, 2019 at 12:51 PM
    #598
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Would switching the fluid to a DOT4 help? Isn't DOT4 a little more viscous?
  19. Jan 13, 2019 at 1:01 PM
    #599
    Shellshock
    Iowa
    I was wondering that as well. I’m not sure if anyone has tried it
  20. Jan 13, 2019 at 1:01 PM
    #600
    M1Awolf
    Rob
    Montana
    The DOT rating applies to temperature rating not viscosity. ;)
    Norton and tonered[OP] like this.
