MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 27, 2019 at 8:02 PM
    #721
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Vacuum bleeding helps a lot, so does compressing the slave piston with the bleeder cracked, then tightening the bleeder and letting the piston oull fluid from the res.
  2. Jan 27, 2019 at 8:10 PM
    #722
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Did you have to rebend the tube? Some early build 16s are reporting a non flexible line and had to rebend ...yours and mine are pretty similar build dates as I recall...9/15
  3. Jan 27, 2019 at 8:29 PM
    #723
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    I only had to bend the supplied line.i first connected to the slave cylinder not to tight, then gently aligned it with the feed from the master cylinder being carful not to kink it then tighten both connections.
    TeecoTaco likes this.
  4. Jan 27, 2019 at 9:27 PM
    #724
    little bear
    little bear Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Come to me knowledge and wisdom any pointers to this mod-
  5. Jan 27, 2019 at 9:44 PM
    #725
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    First clamp off the rubber line leading from the reservoir to the firewall,a pair of needle nose vise grips with some fuel line over the tips works well ;) Go under the truck and remove the heat shield (4 12mm bolts) the one under the exhaust bracket is the tough one and a ratchet wrench is your friend ;)
    Next, loosen the fluid lines with a 10mm line wrench,you can then use a regular wrench and your fingers to get them the rest of the way it wont matter which one you do first.
    Remove 4 12mm mounting bracket bolts and remove accumulator.
    Dissemble accumulator and dremel a channel between the holes and reassemble. Take note,start fluid lines before bolting bracket back to transmission,having a little wiggle room makes it easier to start them and less likely to cross thread them
    Or install premade line in place of accumulator. Tip get both ends started but do not tighten,a little wiggle room helps again tighten them after you have them both started ;)
    Place container/drain pan under slave cylinder bleeder,open bleeder valve and then go up top and undo clamp and add fluid to reservoir as it gravity bleeds
    so it doesn't run dry (very important) let it drain for a good five minutes while continuously topping off,then top it off one last time and quickly go under and close bleeder screw. Check clutch operation and reinstall heat shield and you are done.
    cocephus, Norton, YotaToyZ and 5 others like this.
  6. Jan 27, 2019 at 9:57 PM
    #726
    little bear
    Barry Hobson
    Canadian, Texas
    Should note, I have the one of the last kits for the mod already in my possession.
  7. Jan 28, 2019 at 1:31 AM
    #727
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    You'll still have that ring that can flex, i'd just use the line if it were my rig.
    venezian[QUOTED] likes this.
  8. Jan 28, 2019 at 2:50 AM
    #728
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Has anyone combined the ADM with removal of that return spring contraption on the pedal assy?
    Just curious about the feel....
  9. Jan 28, 2019 at 3:59 AM
    #729
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Good stuff ...... Thanks !
  10. Jan 28, 2019 at 5:53 AM
    #730
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    The one that gives the required free play:confused:
    MOC221_[QUOTED] likes this.
  11. Jan 28, 2019 at 5:55 AM
    #731
    MOC221_
    Frank
    I dunno if it does that.
  12. Jan 28, 2019 at 5:57 AM
    #732
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I beleave so .there would have to be at least one ,if there’s another one wouldn’t surprise me on this truck!!
  13. Jan 28, 2019 at 6:08 AM
    #733
    little bear
    Barry Hobson
    Canadian, Texas
    When y’all say fluid... what fluid do I need for this-
    MOC221_ likes this.
  14. Jan 28, 2019 at 6:08 AM
    #734
    MOC221_
    Frank
    DOT3 brake fluid.
    ..and you have a Sport right? That means your fluid comes from the same reservoir as the brakes IIRC. ORs and Pros have a separate reservoir.
  15. Jan 28, 2019 at 6:12 AM
    #735
    MOC221_
    Frank
    Well, I can tell you that the pedal continues to travel upward after the clutch master cylinder rod is at the top of it's stroke. Mine was set up badly from the factory, so much so that there was an audible "click" from the pedal smacking the rod every time I pushed the clutch in. SO that top bit of pedal travel literally did nothing except make contact with the cruise control switch.
  16. Jan 28, 2019 at 6:17 AM
    #736
    little bear
    Barry Hobson
    Canadian, Texas
    Yessir- 2017 trd sport...
  17. Jan 28, 2019 at 6:20 AM
    #737
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    To all that are doing this please wear eye protection. You do not want to get brake fluid in your eyes. On top of that there is probably all kinds of dirt and road grime under your trucks.
    pinochle and doublethebass like this.
  18. Jan 28, 2019 at 6:21 AM
    #738
    little bear
    Barry Hobson
    Canadian, Texas
    Any particular brake fluid I am supposed to get? Toyota brand?
  19. Jan 28, 2019 at 6:36 AM
    #739
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    To be sure, check your owners manual. It will tell you which grade and what specs it is supposed to meet. I think some brands actually say "and use for hydraulic clutches". You wont need much. About 1/4 of the small bottle will be more than enough unless you completely empty the system.
  20. Jan 28, 2019 at 6:43 AM
    #740
    su.b.rat
    su.b.rat broken truck
    my return spring is removed, has been for months. ADM tomorrow, and I've planned to have him reinstall the spring since there doesn't seem to be value in keeping it off.
