MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Sep 17, 2018 at 9:00 AM
    #81
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I don't disagree, but I couldn't find female flare fittings?
  2. Sep 17, 2018 at 9:01 AM
    #82
    su.b.rat
    su.b.rat broken truck
    https://www.tacomaworld.com/threads...rations-welcome.406844/page-343#post-16682233
    tonered[QUOTED][OP] likes this.
  3. Sep 17, 2018 at 9:10 AM
    #83
    tonered
    tony
    Lynnwood, WA
    su.b.rat[QUOTED] likes this.
  4. Sep 17, 2018 at 11:57 AM
    #84
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
  5. Sep 17, 2018 at 12:11 PM
    #85
    tonered
    tony
    Lynnwood, WA
    Yes. I noted those in Post 68. They had them at my local store also. I wanted to make a line with two female fittings between the flares for simplicity.
    @rat107 posted a video that shows him using just one coupler to do the deed:
    https://www.tacomaworld.com/threads/what-does-a-clutch-fluid-accumulator-do.180006/#post-15468252
    It seems that either the 2nd Gens had a flex line up top and / or more slack to form the turn.
    The elbow (Toyota's name is 'way') was attractive for the simplicity. Also, needing two line wrenches and getting both in the tight spot. . .
    Feel free to go any route that you like, including just leaving the accumulator alone, or wait to see what @7r41lbr34k3r can come up with?
    M10 x 1.0 is the right thread. I believe that coupler is correct for double flare lines.
    Norton and MOC221_ like this.
  6. Sep 17, 2018 at 12:15 PM
    #86
    SContiVT
    Central Vermont
    edit - You're right, they don't have a female regular union (non-coupler) for double flare...weird
  7. Sep 17, 2018 at 12:20 PM
    #87
    tonered
    tony
    Lynnwood, WA
    No problem. Although, that looks like another coupler / union, not an end fitting for a section of line? I could be wrong since there are no other views of it. The description talks about joining two lines together.
  8. Sep 17, 2018 at 12:22 PM
    #88
    SContiVT
    Central Vermont
    I posted the wrong fitting, it doesn't exist for whatever bizarre reason.
    MOC221_ and tonered[QUOTED][OP] like this.
  9. Sep 17, 2018 at 12:24 PM
    #89
    tonered
    tony
    Lynnwood, WA
    Exactly! I tried searching around. M10x1.0 seemed to have a limited selection to start with. I'm also assuming that brake and clutch lines aren't commonly replaced on Japanese cars? :D
    SContiVT[QUOTED] likes this.
  10. Sep 17, 2018 at 2:15 PM
    #90
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    mtip and tonered[OP] like this.
  11. Sep 17, 2018 at 2:30 PM
    #91
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Smoothing out clutch engagement may have been the intent when Toyota designed it, but I find that the accumulator delay makes smooth clutch engagement unpredictable. The added delay and lack of "feel" results in the clutch engaging with a thud often, unless the clutch is excessively ridden. I'm sure this is the opposite effect Toyota intended. I have never experienced this in my older manual Civic, or any previous manual. I can't wait to toss the POS accumulator.
    Norton, hiPSI[QUOTED] and tonered[OP] like this.
  12. Sep 17, 2018 at 2:31 PM
    #92
    tonered
    tony
    Lynnwood, WA
    Whoa. That's nice!
    I've never messed with anything like these except for the pressure fittings on paintball guns. Ones like sharkbites. My bikes have / had only standard banjo fittings with braided lines from the factory.
    My questions would be:
    -- That fitting looks like it seals by wrenching it together once the line is inserted? If so, I like it.
    -- Do those fittings seal to the stock double flare? I think that is the big consideration.
    You'd only need about 70mm of line to make the connection. About 30mm bend radius.
    In general, I meant to check (forgot to) if the line fittings are straight threads or tapers like NPT?
  13. Sep 17, 2018 at 2:39 PM
    #93
    TD90S
    GA
    ‘18 TRDOR 6MT
    Norton and tonered[OP] like this.
  14. Sep 17, 2018 at 2:46 PM
    #94
    tonered
    tony
    Lynnwood, WA
    Ah! It was way down there. Are you going to give this a shot? If you do, it might be easier to go from the top line straight into the slave? Female on one end, male on the other with a support clamp or two.
    I'll check out the video later.
  15. Sep 17, 2018 at 3:10 PM
    #95
    TD90S
    GA
    ‘18 TRDOR 6MT
    Maybe. Have a spare piece of line just need the fittings. Not anytime soon, other pressing projects ATM. If I were to make one, would make it to just replace the accumulator. Easy to go back to stock if needed.
    Actually more driving time it has improved. Still not crazy about the inconsistency and slight thump that another poster mentioned.
    Also curious about the software update that some have stated improving shifts.
    Haven’t wanted to go play the dealership game just yet.
    tonered[OP] likes this.
  16. Sep 17, 2018 at 3:45 PM
    #96
    tonered
    tony
    Lynnwood, WA
    Yes. The software update improves shifting. It combined with this puts me in the sweet spot. I am really content right now.
    hiPSI and TD90S[QUOTED] like this.
  17. Sep 19, 2018 at 6:48 AM
    #97
    tonered
    tony
    Lynnwood, WA
    We had nice weather on Monday and Tuesday, so I rode to work. With weather coming in later, today was the first commute with the accumulator gone. Wow! What. A. Difference.
    IMVHO with it gone, it felt like it was delaying engagement on every shift. I don't know if the accumulator actually contributes to wear, but given that, my mind would say yes. Without it, clutch engagement is direct, feels proper, and is much smoother for me. As smooth as my other MTs. Slushbox smooth.
    BTW, the accumulator went in the mail to Rick yesterday morning. It should arrive just before he heads out on his vacation.
    Norton, cow, mtip and 6 others like this.
  18. Sep 19, 2018 at 7:36 AM
    #98
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    MY50cal likes this.
  19. Sep 19, 2018 at 7:43 AM
    #99
    tonered
    tony
    Lynnwood, WA
    Slightly confused? That link points to your post in another thread about deleting the accumulator which you say yours doesn't have?
    That is interesting that the 2.7s don't have one. I test drove used 2nd Gens with both the 4.0 and 2.7. They both drove well and about the same. I don't know if the accumulator was still on that 4.0. The clutch feel was one of the very few differences that I noticed when test driving the 3rd Gens. I was amazed that 140,000mi+ 2nd Gens were feeling about as good as new 3rd Gens. I'm expecting the same out of mine.
  20. Sep 19, 2018 at 7:56 AM
    #100
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks for the update Tony, sounds like a complete success. Can't wait to see what Rick can do with his machining skills!
    This stupid engagement delay coupled with factory ECU calibration weirdness sure made for a "different" driving experience - eh?
    TD90S and tonered[QUOTED][OP] like this.
