MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Aug 5, 2019 at 9:25 AM
    #1181
    little bear
    little bear Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    just clamped off and did the mod. May have dropped 4 or 5 drops so didn't even loose much fluid. Connected everything and then went for a drive. The clutch pedal has a long throw it seems. It sits high and then I have to push a way before it engages and I can shift but the shifts feel like they are supposed to when I am letting out the clutch into the next gear. No wondering when it would engage or that awkward bump like usual. Pedal returns quickly back to the top and I didnt notice the annoying clutch squeak anymore- but that will likely return as always :)
    lapoltba likes this.
  2. Aug 5, 2019 at 9:26 AM
    #1182
    little bear
    Barry Hobson
    Canadian, Texas
    it didnt seem to miss going into gear easily and even downshifted to first like never before when slowing to make a turn
    Am I okay or should I bleed the system for safety sake?
  3. Aug 5, 2019 at 10:09 AM
    #1183
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'd bleed it, but I'm picky about things like that. Given how simple the process is, why not just do it?
    tonered[OP] likes this.
  4. Aug 5, 2019 at 10:28 AM
    #1184
    Shellshock
    Iowa
    Yeah there’s air in the line. It’ll still work but the air compresses unlike the fluid. It’ll be noticeably different after bleeding.
    doublethebass likes this.
  5. Aug 5, 2019 at 10:52 AM
    #1185
    little bear
    Barry Hobson
    Canadian, Texas
    What tricks for bleeding then? Simply open bleed valve and let it drip a bit? That simple—-
  6. Aug 5, 2019 at 10:54 AM
    #1186
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    That's pretty much what I did. Top off the reservoir under the hood and put a hose on the bleeder. Crack it wide open and let it drip for 5-10 min. Make sure to keep the reservoir topped off. When you're satisfied, close the bleeder and make sure the reservoir has the appropriate level in it.
  7. Aug 5, 2019 at 11:50 AM
    #1187
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    you don't turn it off. you step on the brakes, then speed up with the gas pedal or pull back on the stalk and the truck accelerates. i
    I don't use the adaptive because it tends to give false alarms too often for my taste.
    Another down side is that it promotes complacency for me. I let it adjust the speed so either I tend to not pay attention to my surroundings as well as I should and/or I spend 20 miles traveling 5-10 mph below where I want to be traveling. I know it's a first world problem. But that's why it's available to turn on and off. each driver can choose their own comfort level in their own vehicles.
  8. Aug 5, 2019 at 6:40 PM
    #1188
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Then why use cruise control at all if that's your logic?
  9. Aug 5, 2019 at 6:43 PM
    #1189
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Not sure what you mean? If I’m on the highway I use cruise control all the time......I like the regular version because it’s not finnicky and I can set it and turn it off as I like.
  10. Aug 5, 2019 at 8:20 PM
    #1190
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Exactly!
    doublethebass[QUOTED] likes this.
  11. Aug 5, 2019 at 8:33 PM
    #1191
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    :stayontopic:
    since nobody wants to talk about the ADM.....I installed my URD today, haven't figured out which mod I want for the accumulator.
  12. Aug 5, 2019 at 8:34 PM
    #1192
    lapoltba
    CT - 06076
    I have the URD STS too, and you want the ADM that *DELETES* the accumulator.
    tonered[OP] and edgerat[QUOTED] like this.
  13. Aug 5, 2019 at 8:43 PM
    #1193
    tonered
    tony
    Lynnwood, WA
    OT BS is always welcome, IMO.
    Enjoy the shifter.
    Some folks are big fans of the Dremel mod. I'd say to skip the brake line elbow one if you can. Too much bending on the existing lines, but it is there as a backup.
  14. Aug 5, 2019 at 8:51 PM
    #1194
    lapoltba
    CT - 06076
    Yup. Less than $10 of parts sourced locally.
    Garab and tonered[QUOTED][OP] like this.
  15. Aug 6, 2019 at 4:42 AM
    #1195
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Is the Dremel mod just as effective? I'd rather the accumulator be there for "warranty purpose" even if it doesn't actually do anything
  16. Aug 6, 2019 at 5:29 AM
    #1196
    tonered
    tony
    Lynnwood, WA
    Regarding warranty, if you have any kind of miles on your Taco, there will be no warranty on the clutch. They classify it as a wear item. There have been a couple extremely bad material problems with the friction plate on very low mileage Tacos. They owners struggled to get any warranty support. This was before the ADM got traction here.
    Norton and doublethebass like this.
  17. Aug 6, 2019 at 9:09 AM
    #1197
    lapoltba
    CT - 06076
    Love my URD STS. I had one on my 2nd gen and got one for my 2017 before I even picked it up from the dealer. It's not quite as big of a difference as it was on the 2nd gen, but we started out a bit shorter on the 3rd gen anyway. I don't have any issues with reverse, and shifts are nice and smooth. I was able to install without any cutting of the transmission tunnel with a lot of patience and some swearing. Some have better luck than others, but if I had to cut up my truck the STS would have been shipped back to URD.
    I guess CORE makes one for both the 4 banger and 6cyl. I know nothing about it though. It is also $300.
    https://core-shifters.com/collections/shifters-for-toyota-tacoma
    0uTkAsT[QUOTED] likes this.
  18. Aug 6, 2019 at 9:11 AM
    #1198
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    I had it on my 2nd gen 4cyl and it was awesome, only had two drives on the new one on the 3.5 but it seems to be just as good. The instructions in the box were for a 2nd gen and they didn't give me the same screws for the whole thing. Lucky for me I knew how to install it. @Gadget makes good stuff, just wish the little things like different bolts and no instructions could be better. Or, having instructions on the website would be rad. Performance in there though.
  19. Aug 6, 2019 at 9:13 AM
    #1199
    su.b.rat
    su.b.rat broken truck
    i have the URD also. it's good. i'm about 2 years into it and it has loosened up only about 25% or so.
    i ordered a Core, it's in production. shipping to me end of this week, install in two more. all the reviews say it's the one.
  20. Aug 6, 2019 at 9:20 AM
    #1200
    fatboyfirebass
    It was a bit of a PITA to install, but afterward with the heavier shift knob from @7r41lbr34k3r it is well worth the effort.
    Don't know of any other options out there. there may be some now, at the time URD was my only choice.
    0uTkAsT[QUOTED] and 7r41lbr34k3r like this.
