MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Oct 21, 2019 at 10:08 AM
    #1341
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    ok thanks man, i'll give it another go first chance i get and let you know
    CygnusX191 and tonered[OP] like this.
  2. Oct 21, 2019 at 10:11 AM
    #1342
    Shellshock
    Iowa
    are you just cracking the bleeder and letting it out or do you have a hose on it? You can suck air back in through the bleeder. If you put a hose on it, it won’t.
    CygnusX191, nxcess and tonered[OP] like this.
  3. Oct 21, 2019 at 10:11 AM
    #1343
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Definitely lets us know. :cheers:
    CygnusX191 likes this.
  4. Oct 21, 2019 at 10:15 AM
    #1344
    ArmandHammer83
    Raymond
    Alabama
    none yet
    honestly, just doing it like i do brakes....to me its pretty much the same principle, correct?
    edit....crack it open let it flow out then close it pump 10-15 times and repeat....probably should get a hose so i can watch it huh?
  5. Oct 21, 2019 at 10:19 AM
    #1345
    tonered
    tony
    Lynnwood, WA
    Yes. Same as the brakes with a helper. You don't need 10-15 pumps though. Maybe 2 max. Pumping can drive air higher in the line.
    CygnusX191 and fatboyfirebass like this.
  6. Oct 21, 2019 at 10:24 AM
    #1346
    ArmandHammer83
    Raymond
    Alabama
    none yet
    that would be my luck..i'll get it one of these days LOL
  7. Oct 21, 2019 at 10:29 AM
    #1347
    tonered
    tony
    Lynnwood, WA
    You're mobile, so that is good enough for now.
  8. Oct 21, 2019 at 10:31 AM
    #1348
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Also, when working with a helper, the pedal may stay on the floor after you close the bleeder underneath. Don't let that bother you. Pull the pedal up by hand and it will be good.
  9. Oct 21, 2019 at 10:36 AM
    #1349
    Shellshock
    Iowa
    Lies. 25 pumps per bleed. Do it the Shellshock way :militarypress:
  10. Oct 21, 2019 at 10:37 AM
    #1350
    Shellshock
    Iowa
    that’s what I did the first time. Using a hose worked way better and my clutch is solid now. Also made way less of a mess
    tonered[OP] likes this.
  11. Oct 21, 2019 at 10:38 AM
    #1351
    tonered
    tony
    Lynnwood, WA
    :rofl::rofl::rofl:
    Okay. There is that. But, only if your pedal never comes back off the floor. I've been in those shoes.
  12. Oct 21, 2019 at 10:54 AM
    #1352
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    I have a small electric vacuum pump. Was able to bleed the clutch system in a few seconds. Good to have one if doing brake or hydraulic work even on an occasional basis (pump was $50 on ebay).
  13. Oct 21, 2019 at 11:02 AM
    #1353
    ArmandHammer83
    Raymond
    Alabama
    none yet
    LMAO good to see i'm not alone in the quest for better clutch feel...if i make it a habit of doing stuff like this on a regular basis i might be inclined to fork over the dough but for now i'll stick with trial and error thanks though @MGB
    CygnusX191, Junkhead and tonered[OP] like this.
  14. Oct 21, 2019 at 11:03 AM
    #1354
    Shellshock
    Iowa
    @tonered says these are bad for tacos
  15. Oct 21, 2019 at 11:14 AM
    #1355
    tonered
    tony
    Lynnwood, WA
    Yes! I am not a fan of vacuum pumps on hydraulic clutches. I failed miserably twice without emptying the reservoir, but have heard for other folks that they had no problems. The issue is the amount of pumping and bleeding that needs to be done once it goes sideways. That is why, in general, I say to stay away. Usually, 10min max with a helper gets it done.
    But then, it was once posted that someone completely drains down the brake system when bleeding and has no troubles. So, there is that.
  16. Oct 21, 2019 at 2:57 PM
    #1356
    MGB
    I have used the pump on may different hydraulic systems including clutches and brakes. The only times I had problems were when there was an air leak in the hydraulic system from a bad fitting or seal. For the taco clutch I attached the hose, turned on the pump, cracked the bleeder (no need to open it wide) and waited about 10 seconds until there was an inch of fluid in the hose. Closed the bleeder and the job was finished.
  17. Oct 21, 2019 at 3:41 PM
    #1357
    tonered
    tony
    Lynnwood, WA
    That is excellent and sounds reasonable.
    I had no leaks when I tried. Completely mess up a car and a bike clutch. It was more than an hour of work to get pressure back. That was a lesson learned for me.
    For me, I'll stick to brakes with pumps.
  18. Oct 30, 2019 at 6:29 AM
    #1358
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    So...randomly this morning my clutch is somewhat slow to come back up, and if I mash it to the floor it will stick for a split second before popping back up. If the reservoir is still adequately full, I’m assuming a need to bleed it...or could it be herpes? Not looking forward to a bleed...PTSD.
  19. Oct 30, 2019 at 6:33 AM
    #1359
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep, and check to see if you have any wet spots around the slave. Sounds like you still have air in the system.
  20. Oct 30, 2019 at 6:36 AM
    #1360
    Tacoma816
    Fred and Ginger
    Reported this response for racist overtones.
