MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Oct 30, 2019 at 6:36 AM
    #1361
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    undertones?
    CygnusX191 and tonered[OP] like this.
  2. Oct 30, 2019 at 6:37 AM
    #1362
    Tacoma816
    Fred and Ginger
    In between tones.
  3. Oct 30, 2019 at 6:37 AM
    #1363
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Deftones
  4. Oct 30, 2019 at 6:38 AM
    #1364
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Deftones FTW!!
  5. Oct 30, 2019 at 6:39 AM
    #1365
    Shellshock
    Iowa
    You got air or a leak letting in air
  6. Oct 30, 2019 at 6:40 AM
    #1366
    Tacoma816
    Fred and Ginger
    you made me have wet spots.
  7. Oct 30, 2019 at 6:40 AM
    #1367
    Tacoma816
    Fred and Ginger
    fucks.
    tonered[OP] likes this.
  8. Nov 1, 2019 at 1:18 PM
    #1368
    TacoSundae
    TacoSundae Well-Known Member
    FL
    2018 CGM MT DCSB Sport
    Did anyone else have to adjust their clutch free play after doing the ADM? I have probably 1" at the top of the clutch stroke now which is just a dead zone. Clutch still disengages fully at bottom of stroke. Maybe I need to bleed it more. I've been driving it around for a week like this, and I need to find some way to remedy it, it's driving me crazy.
    Sorry if this has already been covered.
    CygnusX191 and TeecoTaco like this.
  9. Nov 1, 2019 at 1:20 PM
    #1369
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    The engagement zone and stroke felt more or less identical before and after. Just the feel of the clutch and its response changed for me.
    I would be on a bit of air in there.
    :cheers:
    Shellshock and CygnusX191 like this.
  10. Nov 1, 2019 at 1:22 PM
    #1370
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Mine was same after....just a bit off what it was going in. Within a few hundred miles it corrected itself
  11. Nov 1, 2019 at 3:39 PM
    #1371
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    So this morning was 35 degrees, not cold but colder than it has been and my clutch stuck to the floor and would not return until i pulled it up. It remained spongy all day.
    I've been procrastinating doing this mod. Now I'm wandering, does this fix this issue as well or should i take it to the dealer before doing the mod since I'm under warranty.
    I've never had a clutch do this in the cold, ever. Yet now I'm reading that it's "normal"
    What the hell happens when it actually gets cold, like 0 degrees cold?
    Junkhead likes this.
  12. Nov 1, 2019 at 3:45 PM
    #1372
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I never had this issue before the ADM, but i read that ADM helped some owners that had what you are describing.
  13. Nov 1, 2019 at 3:52 PM
    #1373
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    We had some serious cold weather well below zero for days/weeks last year, mine did it several times before and after the ADM. It just needs warmed up a bit and it works fine. Good thing the exhaust runs right by the lines...
  14. Nov 1, 2019 at 6:12 PM
    #1374
    TacoSundae
    FL
    Welp, I bled and bled and bled and it didn't go away. I figured it must be the pedal free play that somehow changed. Got in there to adjust it, and promptly found that when I had the clutch TSB done at the dealer, they never tightened the locknut on my new master cylinder. Talk about dangerous. :mad:
  15. Nov 1, 2019 at 6:37 PM
    #1375
    Tacoma816
    Fred and Ginger
    i has this exact same issue AFTER the ADM. bleeding tomorrow again. Hope it fixes it.
  16. Nov 1, 2019 at 6:39 PM
    #1376
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    :bananadead::help::confused::(:mad:
    CygnusX191 and Junkhead like this.
  17. Nov 1, 2019 at 6:57 PM
    #1377
    TeecoTaco
    SW Ontario
    From factory at 35 F I can't see happening as normal. Pre ADM I would get stiff, but not retrieval required response at sub zero...like -10F otherwise no problem. This will be my first winter ADM but I don't suspect it will alter previous behaviour in that regard...
  18. Nov 1, 2019 at 7:06 PM
    #1378
    Shellshock
    Iowa
    I’ve had mine stuck to the floor pre ADM. it was pretty bad last winter with the brutal temps we had here. We’ll see how it does this winter.
  19. Nov 1, 2019 at 7:19 PM
    #1379
    tonered
    tony
    Lynnwood, WA
    Nice sleuthing!
    CygnusX191 likes this.
  20. Nov 1, 2019 at 7:39 PM
    #1380
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    That is crazy! Good thing you found it!
