MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Nov 13, 2019 at 11:29 AM
    #1421
    su.b.rat
    su.b.rat broken truck
    pm me and if i can find it I'll send it to you tomorrow.
    wait, better yet let me look and I'll pm you. o_O probably tonight.
    CygnusX191 likes this.
  2. Nov 13, 2019 at 11:36 AM
    #1422
    Shellshock
    Iowa
    Mine is sitting in the garage. A milled replacement would be awesome!
  3. Nov 13, 2019 at 11:53 AM
    #1423
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Thanks a million! PM incoming.
    You're next if St. Germain can't find his...haha
  4. Nov 13, 2019 at 12:21 PM
    #1424
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    We did take a look at that. The block is no big deal but I believe it was said that the seats for the fittings are pressed in brass. Given the thin walls and features for it, it would be pretty hard and expensive to do on a small scale.
    Do take a look though. I no long have mine as it was sent out for evaluation.
  5. Nov 13, 2019 at 2:04 PM
    #1425
    bradshawnh
    Boston, MA
    I’m thinking this should be easy given the design of the factory piece. If nothing else it’s just a fancy shaped union that bolts right up to the factory location and accepts the factory lines with no modification.
  6. Nov 13, 2019 at 2:23 PM
    #1426
    tonered
    tony
    Lynnwood, WA
    Yes. The block itself is dead simple. I was surprised by the feedback also. The female threaded ends in the accumulator are pressed in brass. This was the tricky part of it and what made it not worth pursuing.
    Note that there were leak issues for some ADM folks, so it is a highly detailed area that is unfortunately not quick or easy.
    I am not telling you to stop or anything like that. Just giving you a warning that it we went down this path a while ago.
  7. Nov 13, 2019 at 3:01 PM
    #1427
    bradshawnh
    Boston, MA
    I was thinking about just machining the threads and flare directly into the block itself (similar to how the slave cylinder would be, for example).
    I’m a mechanical engineer by career and willing and certain to come up with a solution. :D
    Junkhead and tonered[QUOTED][OP] like this.
  8. Nov 13, 2019 at 3:11 PM
    #1428
    tonered
    tony
    Lynnwood, WA
    That was my assumption when I first had it apart and in my hands.
    I'm an aero that OJT'ed into a mechanical engineer, certification, QMS, IT, teamster at times, and a generally useless laborer.
    Junkhead likes this.
  9. Nov 13, 2019 at 4:03 PM
    #1429
    Shellshock
    Iowa
    You could have just said you are a wizard:hattip:
  10. Nov 13, 2019 at 5:20 PM
    #1430
    tonered
    tony
    Lynnwood, WA
    LoL! :D
    I like useless laborer best!
  11. Nov 13, 2019 at 7:16 PM
    #1431
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Here are a couple pics of the accumulator ports. I'm a CNC Programmer/machinist and personally I don't think its worth the hassle over the hardline option. It would need to be made as three pieces and have the brass cone/seats pressed in after the main body is machined/ tapped to depth.
  12. Nov 13, 2019 at 7:30 PM
    #1432
    tonered
    tony
    Lynnwood, WA
    Don't forget that dremel-ing the accumulator does work for this also.
    CygnusX191 and Junkhead like this.
  13. Nov 13, 2019 at 7:40 PM
    #1433
    Shellshock
    Iowa
    Yeah but that’s not nearly as cool!
  14. Nov 13, 2019 at 7:41 PM
    #1434
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Deja vue all over again
    CygnusX191, Junkhead and tonered[OP] like this.
  15. Nov 13, 2019 at 7:44 PM
    #1435
    tonered
    tony
    Lynnwood, WA
    Whatever it takes to eliminate the effect. Today, I let off the clutch a bit too quickly pulling out and heard a chirp. It made me smile thinking that the accumulator was not there messing with me.
    CygnusX191, Junkhead and TeecoTaco like this.
  16. Nov 13, 2019 at 7:46 PM
    #1436
    Shellshock
    Iowa
    I’ve had to learn to drive reasonably again now that the snow is flying. Between the tune and ADM, my truck likes to go
    Gvsukids, CygnusX191, Norton and 3 others like this.
  17. Nov 13, 2019 at 7:47 PM
    #1437
    TeecoTaco
    SW Ontario
    Haven't had that on launch unexpectantly, but got two chirps on downshift from 6-3 then 3-2 hard braking for a wild turkey.
    Gotta protect the grill eh
  18. Nov 13, 2019 at 7:48 PM
    #1438
    tonered
    tony
    Lynnwood, WA
    That thoughts of snow have me thinking it is too soon, but I do want to play with the new tires. We typically see it in the low lands after the new year unless it is an unusual year.
    TeecoTaco likes this.
  19. Nov 13, 2019 at 7:49 PM
    #1439
    tonered
    tony
    Lynnwood, WA
    Yeah. No road kill without a plate bumper.
  20. Nov 13, 2019 at 7:49 PM
    #1440
    TeecoTaco
    SW Ontario
    10 inches on Monday...
