MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jan 21, 2020 at 6:54 AM
    #1481
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Same.
  2. Jan 21, 2020 at 12:59 PM
    #1482
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine probably isn't as drastic as some describe but it is better.
    Junkhead, TacoTim85 and tonered[OP] like this.
  3. Jan 21, 2020 at 1:01 PM
    #1483
    su.b.rat
    su.b.rat broken truck
    couldn't find the bite point or modulate from it before the ADM. now i can. :notsure:
    Doobfucious, Junkhead, Norton and 3 others like this.
  4. Jan 21, 2020 at 1:03 PM
    #1484
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It hasn't been posted here, but @Trident904 talked about some folks coming back to him with leaks. He said it was about making really good double flares and testing them and also about getting the right fittings. The common ones don't thread to the end (have a smooth bore) and the threads on the slave are a bit shallow.
    That said, a lot of folks have used the common fittings with no trouble.
    oconnor, Junkhead, Norton and 2 others like this.
  5. Feb 2, 2020 at 12:58 AM
    #1485
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I really want to do this, but I am not sure my skills are up to the task. :cool:
    Junkhead likes this.
  6. Feb 2, 2020 at 2:42 AM
    #1486
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Just make sure you select the correct fittings: inverted flare (Japanese style).
  7. Feb 2, 2020 at 6:04 AM
    #1487
    Shellshock
    Iowa
    Just make sure you have a flare nut wrench
    pinochle, Norton, CygnusX191 and 2 others like this.
  8. Feb 2, 2020 at 7:05 AM
    #1488
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    A what now?
    C41n likes this.
  9. Feb 2, 2020 at 7:16 AM
    #1489
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's what I said. I got one to do the job with, not sure what the big deal is. It helped, but as long as you're not a dunce, I personally did not see where it was "required"
    Just ask at your local auto parts store. Should have all kinds of sizes available.
    oconnor and tonered[OP] like this.
  10. Feb 2, 2020 at 7:20 AM
    #1490
    tonered
    tony
    Lynnwood, WA
    Definitely required. We have one person stuck with the accumulator because they rounded off the upper fitting with a standard wrench.
    Only the 10mm is need, but these worked like a champ:
  11. Feb 2, 2020 at 7:35 AM
    #1491
    Shellshock
    Iowa
    It’s easy to round off the fitting without one. Even if you could *technically* do it without, I’d spend the $3 to not jack up the fittings. It’s enough of a PITA as is
    ^ what tony said
  12. Feb 2, 2020 at 7:37 AM
    #1492
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    This is one of those things where having the right tool is both cheap and recommended if for no other reason than Toyotas typically only need one wrench. Open end wrenches will wear down the fittings a little each time and since you can't just swap out a brass fitting like you can a nut, it's not a good idea to do it when you don't have to.
  13. Feb 2, 2020 at 7:46 AM
    #1493
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    There it is, folks. Get a flarenut wrench.
    For the record, I did use one :anonymous:
    tonered[OP] and Junkhead like this.
  14. Feb 2, 2020 at 8:35 AM
    #1494
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You can always ask your favourite shop to do it.
    CygnusX191 and su.b.rat like this.
  15. Feb 2, 2020 at 10:48 AM
    #1495
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Was considering this, but I wasn't sure if a shop would want to do "custom" work. I don't actually have a shop I trust. Gone though a bunch of shops I don't trust in my decade plus in my city, but yet to find a a great one.
    Junkhead[QUOTED] likes this.
  16. Feb 2, 2020 at 10:48 AM
    #1496
    TuRDLYFE
    2020 AG TRD Pro 6MT
    It's hardly custom work. I can't imagine it would even take the layperson longer than 2 hours to do it if he or she was terrible with mechanical things.
    CygnusX191 likes this.
  17. Feb 2, 2020 at 11:02 AM
    #1497
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Gonna say - 1-2 hours max for a shop. Where are you in the PNW? If Seattle/Redmondish, I can recommend a couple.
    Junkhead and CygnusX191 like this.
  18. Feb 2, 2020 at 11:06 AM
    #1498
    Shellshock
    Iowa
    I know one layperson it took longer than 2 hours :anonymous:
  19. Feb 2, 2020 at 11:57 AM
    #1499
    TuRDLYFE
    2020 AG TRD Pro 6MT
  20. Feb 2, 2020 at 12:56 PM
    #1500
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I am in Portland. Thanks though.
    I have done many "easy" mods over the years. Always takes me twice as long or longer than everyone else did.
    Junkhead, CygnusX191 and TacoTim85 like this.
