MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Mar 6, 2020 at 9:42 AM
    #1561
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I was incorrectly guessing that there were hidden parts in the accumulator ports. In reality, the entire function of it is the disk providing surface area and the seal compressing under the vacuum pressure of the clutch pedal releasing. This restricts the flow back toward the master cylinder. The main body of the accumulator is just a solid hunk of aluminum as you see it, with fitting seats pressed into each port to create a seal. No hidden parts, just the machined passages.
    Adding the channel just bypasses the function of the disk and seal since no negative pressure can be generated.
    CygnusX191, ChouDawg[QUOTED] and C41n like this.
  2. Mar 6, 2020 at 10:13 AM
    #1562
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I did not modify the heat shield. I had it all lined up before tightening it down to fit under the heat shield by test fitting the heat shield after getting everything starting on the threads. I was not careful enough when tightening down and that resulted in it moving without my noticing. (It was dark and I was using a headlamp).
    Also at this point, I don't think that is where I got the air in the line. I had tubing on the bleed nipple that was slightly too big allowing air to suck back when bleeding. Not the best idea.
    All in all though, the honda line worked great. In one of my pictures you can see the line extends slightly outside the heat shield. I could not find a route that did not result in a bad bend or this. I don't think this will be a problem, but it's worth noting.
  3. Mar 6, 2020 at 10:18 AM
    #1563
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Seems like a lot of work for little gain if it ain't broke don't fix it. Guess you could take all that junk off and replace them with bell cranks and push rods from the 60's.
    MOC221_ likes this.
  4. Mar 6, 2020 at 10:22 AM
    #1564
    tonered
    tony
    Lynnwood, WA
    Some folks don't feel the effect, but from what has been posted here, many feel a large change just like I did.
    While I enjoy a cable throttle, cable clutches or push rods are not my cup of tea. I much prefer a simple, self adjusting hydraulic clutch.
    In the end on an MT, a device between the master and slave cylinder is just silly.
    mtip, CygnusX191, Norton and 3 others like this.
  5. Mar 6, 2020 at 10:25 AM
    #1565
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    To me it was nothing short of night and day difference. I have driven many 10-20 year old cars that had better feeling clutches than the stock one on my 3rd gen Tacoma. That is insane. The stock clutch just felt wrong. Every shift. It was driving me insane. I hated it. No brand new manual should feel like that. After the mod, it feels like it should.
    I cannot recommend this mod enough.
    Lucifer1, GBR, CygnusX191 and 4 others like this.
  6. Mar 6, 2020 at 10:27 AM
    #1566
    su.b.rat
    su.b.rat broken truck
    'seems' is the word
    and so is 'broke'
  7. Mar 6, 2020 at 10:53 AM
    #1567
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    It really isn't a lot of work lol
    TacoTim85 and tonered[OP] like this.
  8. Mar 6, 2020 at 10:59 AM
    #1568
    Shellshock
    Iowa
    For the $15 it costs me, it’s well worth it lol
  9. Mar 6, 2020 at 11:01 AM
    #1569
    MOC221_
    Frank
    Do you own a 3rd gen?
    Shellshock likes this.
  10. Mar 6, 2020 at 11:07 AM
    #1570
    tonered
    tony
    Lynnwood, WA
    The 2nd Gens had them also. There were not many posts about it that I could find, but it was where I searched for info.
  11. Mar 6, 2020 at 12:26 PM
    #1571
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I almost did the dremel mod. Decided not to so I could save my stock parts just in case I didn't like it....
    I like it.
  12. Mar 6, 2020 at 12:59 PM
    #1572
    MOC221_
    Frank
    Fair enough.. I was in the unique position where I had done it on my previous 3rd gen so I knew I'd like it. This time around I went dremel for "stealth" lol.
  13. Mar 6, 2020 at 1:02 PM
    #1573
    MOC221_
    Frank
    On both the 4cyl and V6?
    The other unknown is how much fuckery the 2nd gen unit added to the clutch feel. We know what it does to the 3rd gen ...
  14. Mar 6, 2020 at 1:05 PM
    #1574
    tonered
    tony
    Lynnwood, WA
    As far as the 4cyl, all that I know is the 3rd Gen didn't have it.
    You may have a point there. It feels like the 3rd Gen has less bite, so it might not be the same issue for them? I only test drove two 2nd Gen MTs and the clutch was NBD on either (2.7l and 4.0l). The thing that stuck out was the weezy top end on the 4.0l. I immediately scratched my head with the longer throw and less feels on both 2017s that I drove (drove one / bought one).
    Also, one 2nd Gen guy that did the ADM said that it gave him a bit more PP throw that he needed for the Stage 2 clutch that he installed.
  15. Mar 6, 2020 at 1:26 PM
    #1575
    MOC221_
    Frank
    Right on, I'm just glad mine is "bypassed".
  16. Mar 6, 2020 at 1:28 PM
    #1576
    tonered
    tony
    Lynnwood, WA
    Same!
    CygnusX191 likes this.
  17. Mar 6, 2020 at 2:06 PM
    #1577
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    3rded!
    tonered[QUOTED][OP] likes this.
  18. Mar 6, 2020 at 2:07 PM
    #1578
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    And that’s how I ended up here:anonymous:
  19. Mar 6, 2020 at 2:08 PM
    #1579
    tonered
    tony
    Lynnwood, WA
    We're happy to have you!
    :cheers:
  20. Mar 6, 2020 at 2:28 PM
    #1580
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    So... any second Gens creeping the thread that have this figured out so I don’t have to start my truck in gear and power shift back to the parts store to get the right shit?
    moondog1 and CygnusX191 like this.
