MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Jun 23, 2020 at 5:23 PM
    #1701
    Shellshock
    Iowa
    you can come drive mine. plus its tuned
    we can sell you on all kinds of things
    I know a guy with the tuning software who can hook you up after you start drooling :rofl:
  2. Jun 23, 2020 at 5:24 PM
    #1702
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    For sure! It will at least remind you of the accumulator.
    Test drives are always fun.
    CygnusX191 and jcm[QUOTED] like this.
  3. Jun 23, 2020 at 5:27 PM
    #1703
    jcm
    jcm Well-Known Member
    2017 TRD-OR 6M
    I've been eyeing that OVTune something fierce.
    Bring it down to Texas and talk me into it haha
    CygnusX191 and tonered[OP] like this.
  4. Jun 23, 2020 at 5:35 PM
    #1704
    Shellshock
    Iowa
    @mZiggy got you covered :thumbsup:
    CygnusX191, mZiggy and tonered[OP] like this.
  5. Jun 23, 2020 at 5:49 PM
    #1705
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    El Paso, TX. Come on by.
  6. Jun 23, 2020 at 5:55 PM
    #1706
    jcm
    2017 TRD-OR 6M
    Much appreciated, how often do you travel 600 miles east?
  7. Jun 23, 2020 at 5:56 PM
    #1707
    mZiggy
    mZiggy Honey badger
    Marc
    Less than once a year
    jcm[QUOTED] likes this.
  8. Jun 23, 2020 at 5:59 PM
    #1708
    Shellshock
    Iowa
    How many taco friends you got out there? He can be persuaded.. or I could lol
    CygnusX191, jcm[QUOTED] and mZiggy like this.
  9. Jun 23, 2020 at 6:02 PM
    #1709
    mZiggy
    mZiggy Honey badger
    Marc
    Exactly. Unfortunately the sale off one tune would barely cover the cost of gas, and two is not 100% tempting enough for that kind of drive. Would be ideally preferring 3+ trucks
    CygnusX191 and jcm like this.
  10. Jun 23, 2020 at 6:12 PM
    #1710
    jcm
    2017 TRD-OR 6M
    I don't want to brag, but at least 0 and upwards of 1
    C41n, CygnusX191 and mZiggy like this.
  11. Jun 23, 2020 at 6:13 PM
    #1711
    jcm
    2017 TRD-OR 6M
    Do you sell the OVTune?
    CygnusX191 likes this.
  12. Jun 24, 2020 at 10:40 AM
    #1712
    mZiggy
    mZiggy Honey badger
    Marc
    I can get you tuned with OVT maps.
  13. Jun 24, 2020 at 1:27 PM
    #1713
    MountainMike68
    MountainMike68 Well-Known Member
    55°N
    2016 TRD Sport AC/MT
    Finally got around to doing this one. WOW what a difference. I was able to bypass and remove the accumulator without having to disconnect the forward drive shaft or exhaust support bracket. Thanks OP for starting this.
  14. Jun 24, 2020 at 1:28 PM
    #1714
    tonered
    tony
    Lynnwood, WA
    :hattip:
    You're welcome!
    Enjoy the improved shifting.
    CygnusX191 and Junkhead like this.
  15. Jun 24, 2020 at 2:03 PM
    #1715
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Right on man! Happy rev matching!
    :burnrubber:
  16. Jun 26, 2020 at 6:24 AM
    #1716
    Connecticut_Tacoma
    Connecticut_Tacoma Well-Known Member
    Old Greenwich, CT
    2016 Tacoma TRD SPORT 6-speed Access Cab
    Looking for some help here please. It seems that I need to bleed my clutch maybe once every week after the accumulator delete, urd clutch upgrade and short shifter install. When I bleed it I only get ONE bubble that comes out in the liquid. No gas or air comes out that I can hear, it's only in the liquid (that one bubble). My clutch does not engage properly in first gear, it seems like it's not fully catching and I feel something spinning. Once I do the bleeding it is fine for about a week. Is it possible that I have a leak somewhere without actually losing any fluid? I'm thinking of putting the accumulator back on but not sure if that would do anything.
    Any help is appreciated. I'm getting tired of bleeding the clutch just to get one little air bubble out. I have bled the clutch 3 times now (I have my girlfriend pump the clutch 50 times and then I release the valve down below, we repeat this only 3 times). Is it possible that there is still air in there?
  17. Jun 26, 2020 at 6:29 AM
    #1717
    Shellshock
    Iowa
    Sure sounds like a leak to me
  18. Jun 26, 2020 at 6:41 AM
    #1718
    tonered
    tony
    Lynnwood, WA
    Air is less viscous than brake fluid, so it could be getting in. I would take the ADM off and look at the flare fittings and fitting seats to be sure that there is nothing wrong or any specs of dirt in there and go from there.
  19. Jun 26, 2020 at 7:23 AM
    #1719
    Connecticut_Tacoma
    Old Greenwich, CT
    Ok thanks, I'll do that. Valid point
    Junkhead, CygnusX191 and tonered[OP] like this.
  20. Jul 9, 2020 at 5:23 PM
    #1720
    MickeyB
    MickeyB Well-Known Member
    '17 TRD OR 6MT 4x4
    Mobtown skids and sliders
    I've been reading this thread over the last couple weeks and one thing I keep wondering about is the bleeding process. Step 6 of the PDF states: "Loosen the bleeder on the slave cylinder, then once loose, go into the engine bay and remove your clamp from Step 1. By the time you get back under the truck, it should be dripping pretty good and you can tighten the bleeder screw." But I've read that others are pumping the clutch 1-10+ times. If I understand correctly, "step 6" is the gravity method, so when would you pump the clutch? I've done brakes before but never bled a clutch.
    TeecoTaco likes this.
