MT Accumulator Delete Mod (ADM) and BS Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 14, 2018.
  1. Oct 14, 2020 at 11:32 AM
    #1881
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    I've got 4 bottles of redline sitting in the garage waiting to go into the Taco and my Jeep. By my calculations I should end up about 0.2 quarts short. W/in 5mm of fill hole though on both and I should be fine. I need to quit being so lazy about it.
    daveeasa and tonered[OP] like this.
  2. Oct 14, 2020 at 11:34 AM
    #1882
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Was planning on doing redline in mine soon.used it in my 95 Pathfinder, miracle stuff
    tonered[QUOTED][OP] likes this.
  3. Oct 14, 2020 at 11:35 AM
    #1883
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I did some searching, and feeling like maybe I can attempt to do this but any chance someone has a link to a thread discussing changing to MT-90 for MT transmission oil? I assume some sort of flush and bleed sort of thing but not even sure how much to buy...
    EDIT: So, like 1 gallon of this?
  4. Oct 14, 2020 at 11:38 AM
    #1884
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
  5. Oct 14, 2020 at 11:38 AM
    #1885
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    You should be good to go. That bit won't matter.
    It is! Made slick shifters out of our other notchy shifters.
    This is a great thread:
    https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/
    No flush needed as the fluid is compatible. I've done that flush dance in the past with incompatible stuff that didn't even help.
  6. Oct 20, 2020 at 3:00 PM
    #1886
    Myles G
    Myles G Well-Known Member
    Myles
    Just did the ADM and when I put the clutch in it makes a noise now? Not the rattle not the squeak sounds like it actually might be the clutch. On one of the forms someone else mentioned it. Anyone got any input? I’ll try to upload a video.
    tonered[OP] likes this.
  7. Oct 20, 2020 at 3:06 PM
    #1887
    tonered
    tony
    Lynnwood, WA
    The 2nd Gen guy that lead me to this mod said that he did it to get a bit of extra throw for the Stage 2 or Stage 3 clutch that he installed. I'm not sure how we could get extra throw out of it, but maybe that has something to do with it?
    Myself, I have developed an external squeak toward the end of summer. The info that I found just said that Toyota pickup clutches can be loud. I ran through some puddles a couple weeks ago. It either lubed it up or freed whatever was causing it?
    Looking forward to your vid.
    Also, any air in the lines can make a sound, but it wouldn't be a squeak.
    Junkhead and CygnusX191 like this.
  8. Oct 20, 2020 at 3:09 PM
    #1888
    Myles G
    Myles
    here’s the video
  9. Oct 20, 2020 at 3:12 PM
    #1889
    tonered
    tony
    Lynnwood, WA
    That sounds like something is continuing to move after you reach the bottom of the stroke? Like a kickstarter?
    Otherwise, I would say air? Has you engage point moved after the ADM?
    CygnusX191 likes this.
  10. Oct 20, 2020 at 3:21 PM
    #1890
    Myles G
    Myles
    Engagement point has not changed or If it did I can’t notice. Bare with me because I’m not mechanically inclined. I’m guessing it is air left in the lines from what I’ve read, but will this grenade my clutch or cause any other issues? But I’m guessing either way have the shop get the air out.
  11. Oct 20, 2020 at 3:24 PM
    #1891
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    interesting sound. when the clutch goes to the floor, the TOB presses against the pressure plate. the TOB spins, but that doesn't sound like a failing bearing. Maybe? Or maybe i'm still too emotionally scarred from taking my clutch apart twice.
    btw for those keeping track, my pressure plate has been silent recently... I've given up and just assume this truck is loud a f and makes noises i don't understand lol
    CygnusX191 and tonered[OP] like this.
  12. Oct 20, 2020 at 3:24 PM
    #1892
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Who did the work? You or the shop?
    If you, could you describe the point where you 1. Clamped the fluid line and 2. Your bleed process
    If shop did the work, that should have never been released
    shakerhood and tonered[OP] like this.
  13. Oct 20, 2020 at 3:27 PM
    #1893
    Myles G
    Myles
    Bearing was replaced within the year. Could be but also could be the “Toyota’s are just loud”
    b3itz[QUOTED] and tonered[OP] like this.
  14. Oct 20, 2020 at 3:27 PM
    #1894
    tonered
    tony
    Lynnwood, WA
    Just for clarity, the TOB starts to spin pretty much as you start to move the pedal.
    Nice! That is great to hear. So, just some break in stress?
    b3itz[QUOTED] likes this.
  15. Oct 20, 2020 at 3:28 PM
    #1895
    tonered
    tony
    Lynnwood, WA
    Possibly, but what is your engagement point like?
  16. Oct 20, 2020 at 3:28 PM
    #1896
    Myles G
    Myles
    Shop did it, should I have them take another look and make sure everything was bled correctly? It’s a hit or miss shop ive has them rebuild a Shelby for me and it’s flawless but I’ve also had them put a bumper on and they couldn’t get it to align.
    tonered[OP] and CygnusX191 like this.
  17. Oct 20, 2020 at 3:28 PM
    #1897
    Myles G
    Myles
    Engagement is fine just as it was before
  18. Oct 20, 2020 at 3:29 PM
    #1898
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Mine makes a squeak (more like a metal noise, but it's the clutch squeak we all know a love) but nothing like what you've got
    tonered[OP] and Myles G like this.
  19. Oct 20, 2020 at 3:29 PM
    #1899
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Maybe.... I have no idea. I have a new adapter ring and clip thingy to install one day if it starts acting up again. beats me! :mudding:
  20. Oct 20, 2020 at 3:30 PM
    #1900
    Myles G
    Myles
    Happy for you! Lmfao :rofl::frusty:
