MT coilovers with LT parts
Discussion in 'Suspension' started by Spvrtan, Aug 23, 2016.
  1. Aug 23, 2016 at 2:59 AM
    Spvrtan
    Spvrtan [OP] "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    This is more of a general truck question since I was curious but is it possible to run MT coilovers with LT parts (UCA, LCA, axles, tie rods). Obviously you wouldn't reach the full potential of the parts but you'd still get more "travel" than with the MT parts due to the longer/wider arc. I'm thinking this would be a good compromise for those that have MT but want to slowly go to LT.
  2. Aug 23, 2016 at 3:09 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    They make spacers for extended travel shocks (oem length) that will fit on some LT kits. I don't think you're getting anywhere near the travel, I don't know a whole lot about it, but its basically a strut spacer if I recall.
  3. Aug 23, 2016 at 10:41 AM
    Spvrtan
    Kris
    If I did this slow upgrade, I'd probably skip the spacers and just deal with "in between" travel.
  4. Aug 23, 2016 at 1:13 PM
    VolcomTacoma
    Jeff
    NorCal
    Nononono I'm not even sure if they would fit. But if the shocks did manage to fit, you would probably break them the first time you moved. The spacers at least put the shock around where it needs to be to prevent serious damage. I would highly recommend you just hold up on installing until you get a set of shocks. Even if you have to grab some random ones in shite condition for a couple hundred bucks, get a quick rebuild on them and throw them on
  5. Aug 23, 2016 at 2:54 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    2 words: limit straps.
    Unless you want to buy new shocks.
