MT double clutch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by offthewallsurfer, Oct 23, 2017.
  1. Oct 23, 2017 at 5:48 PM
    offthewallsurfer
    offthewallsurfer [OP] Well-Known Member
    Just curious as to see how many of you MT drivers shift normal or double clutch shift? If you double clutch what's your reasoning and or benefits other than spoiling the shafts to alleviate synchro stress, isn't that defeating the purpose of synchros in the first place? Just looking for more clarification on the subject.
  2. Oct 23, 2017 at 5:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No need to.
    Paul631, hoverlover, Jooo and 4 others like this.
  3. Oct 23, 2017 at 5:53 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Because Vin Diesel says so.
  4. Oct 23, 2017 at 6:07 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ditto
  5. Oct 23, 2017 at 6:09 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I drove a tandem Dodge dump truck for years.... I was taught to double-clutch it.... By the end of the day my left leg was a bit sore....
    I soon learned to shift without the clutch..... Much easier on the leg and the clutch pedal spring... hehe.... It's all in the revs man..... Get' em right and NO stinkin' clutch needed.....
    I actually drove an Austin Morris for 3 yrs. without a clutch as I could NOT afford to fix it..!! It makes life interesting at times when you come up a hill to a red light and have to stop....hehe
  6. Oct 23, 2017 at 6:45 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    The transmission has synchros for a reason. Unless you’re slamming gears at high RPMs, the synchros will easy last well over 200k miles if the fluid is changed on schedule.
    More clutch disengagements means more wear on the hydraulic system, TOB (and the grease that libricates it), and the pressure plate diaphragm.
    Just shift smoothly and consistently and you will likely never reach the point where the synchros are worn and need to be replaced
  7. Oct 23, 2017 at 6:48 PM
    Paterico
    San Antonio, TX
  8. Oct 23, 2017 at 7:56 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Double clutching is a waste of time.
    offthewallsurfer[OP] likes this.
  9. Oct 23, 2017 at 8:45 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    double clutching is a waste of time...I double shift instead.:burnrubber:
  10. Oct 23, 2017 at 10:47 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I mean.... I rev match to downshift because prefer to have smoother downshifts, but I am not sure why you would need to double clutch on a car that was made in the 1980s or later.
    Can someone explain to me the benefit of double clutching? Maybe I don't know what double clutching really is?
  11. Oct 24, 2017 at 6:34 AM
    offthewallsurfer
    That's exactly what I'm trying to figure out, there are a bunch of YouTube videos on it, mostly fast and furious wannabes, I just don't understand the reasoning as to why it would be beneficial to a tacoma driver IF someone drives this way.
    specter208 likes this.
  12. Oct 24, 2017 at 6:45 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Double clutching was for transmissions that didn't have synchros. You would push the clutch. Shift to neutral. Clutch again and then finally shift to your gear.
    Fast and furious was talking about tapping clutch in a bit at wot to rev the motor. Does nothing but slow you down and wear your clutch.
  13. Oct 24, 2017 at 6:48 AM
    JayRolla
    Colorado Springs
    Just shift your car. Double clutching does nothing.
    Now if your making over 700whp and shifting at 9k rpms you will be replacing synchros anyways. Hard to double clutch at the track. Lol.
  14. Oct 24, 2017 at 6:50 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    No need. Just rev match and down shift for butter smooth transitions.
    JayRolla and AdventureKid like this.
  15. Oct 24, 2017 at 6:50 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    double clutching serves one purpose. to synchronize gears in an un-synchronized transmission. needless to say the tacoma has a synchronized transmission therefore double clutching is absolutely useless. if you want more technical information google and learn about the two types of manual transmissions and it should become clear.
  16. Oct 24, 2017 at 6:50 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    I triple clutch just to be extra safe.
  17. Oct 24, 2017 at 6:52 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    No, I have never double clutched my Taco or any other modern passenger cars/trucks. I do give it a small "blip" on the accelerator to rev match as mentioned for smooth down shifts. Is it necessary, probably not and most likely not, but I have always driven MT's this way. The Taco has one of the smoothest MT's I have owned / driven - I really do enjoy this truck!
    MOC221_ likes this.
  18. Oct 24, 2017 at 6:53 AM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Completely agree. One of my favorite activity while driving a manual transmission :)
  19. Oct 24, 2017 at 8:16 AM
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    IMO, double clutching seems like common core math, a waste of time.
  20. Oct 24, 2017 at 9:26 AM
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    how does one drive without a clutch?
