MT fill and frain plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timinco77, Jul 7, 2009.
  1. Jul 7, 2009 at 8:42 AM
    timinco77
    timinco77 [OP] Active Member
    Colorado Springs
    07 Tacoma Access Cab
    Rear TSB
    I am having trouble finding the fill and drain plugs for an 07 tacoma v6 manuel transmission 6 speed, could anyone help me out? Or direct me to a write up.
  2. Jul 7, 2009 at 8:54 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I looked at a picture of the Aisin 6spd in the new Camaro which is supposed to be the same trans that the V6 Tacoma uses. The drain plug is at the back of the trans on the bottom. The fill plug is toward the front of the trans on the driver's side. Hope this helps.
  3. Jul 7, 2009 at 8:56 AM
    timinco77
    Colorado Springs
    Rear TSB
    when i looked at it that is what I figured just wanted to make sure, does it use the same 24mm socket as the rear diff and transfer case use?
  4. Jul 7, 2009 at 9:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Jul 7, 2009 at 9:03 AM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    That I don't know. My truck is a 4cyl 5 speed and I haven't serviced the trans yet. Sorry I haven't been much help, but there are guys on this site that will know the answers and I'm sure they will chime in soon.
  6. Jul 7, 2009 at 9:31 AM
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Yes, and as with the transfer case do not over-tighten the bolts. If I remember correctly I used a wrench for the fill plug, based on the space that is available.
