MT Fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KK87, May 31, 2016.
  1. May 31, 2016 at 11:01 AM
    KK87
    KK87 [OP] Well-Known Member
    2016 Quicksand TRD OR DC MT
    All the calamity galore of low AT fluid makes me want to have the dealer look at my MT fluid as well. Has anyone checked the MT fluid level yet? Thanks.
  2. May 31, 2016 at 11:12 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    My dealer was "supposed" to have checked it at my 5K service... I looked, the rear diff was checked not the front diff and not the transfer case.. they all had painted plugs from factory.
    I just ordered 1 litre of transmission gear oil and 1 litre of diff oil today from my local dealer. The parts guy had to look up the product numbers to order them. Pricey too at $26/litre or thereabouts. Adding gear oil is a pain .... need a long hose with funnel and 3 hands. My wife will help me.
  3. May 31, 2016 at 11:18 AM
    captain murphy
    captain murphy Knight of Mars
    DFW, TX
    2016 4x4 DCSB OR MT
    I checked mine. Between the rear diff and trans I used about a quart of 75w90 gear oil. I used the Arnold pump kit from home deport. Work quite well, just pump slow and prime it before you start.
  4. May 31, 2016 at 11:26 AM
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    Awesome I'll be checking my mt tonight along with diffs, u-joint grease, and u-bolt torque. All things one should check on a brand new truck with 247 miles on the odo.
  5. May 31, 2016 at 11:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't bother with the dealer. It's too easy to do yourself. You'll be all wrapped up in the time it would take to drive to the dealer and have your first doughnut while watching Jerry Springer.
    mavfox, bobrown14 and TacoCat like this.
  6. May 31, 2016 at 11:39 AM
    KK87
    So the MT is also filled with insufficient tranny fluid as well?
  7. May 31, 2016 at 11:39 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    That ^^^ by the time I got done fighting with the service mgr I'd have already been washed up and onto something else like a beer or 3.
  8. May 31, 2016 at 12:39 PM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    Just crawl under, open the fill bolt, and see for yourself.
  9. May 31, 2016 at 1:26 PM
    BeaverNation
    BeaverNation Well-Known Member
    I really doubt mt's will be low, they only take 2qts
