MT low range shifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Aug 27, 2020.
  1. Aug 27, 2020 at 9:27 PM
    microsnook
    microsnook [OP] Well-Known Member
    '20 TRD OR MGM MT
    Is there any special techniques to shifting while in low range? Its my first truck and I've used low range a few times and going from 1-2 just feels weird. Im not sure if its the accumulator or Im just not doing something right. It feels like it holds me back until I let the RPMs drop then shift.
    Junkhead likes this.
  2. Aug 27, 2020 at 9:30 PM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    1-2 sucks, this motor likes to rev hang, so gotta be patient.
    Cool_Calm_B and e6400ultra like this.
  3. Aug 27, 2020 at 9:30 PM
    microsnook
    '20 TRD OR MGM MT
    So just shift nice and slow?
  4. Aug 27, 2020 at 9:31 PM
    Bishop84
    Bishop84 Well-Known Member
    It's normal, what terrain are you on? I usually just stay in 2nd on flat normal trails. 1st for challenge or uphill.
    02Duck and Junkhead like this.
  5. Aug 27, 2020 at 9:32 PM
    BillW
    N. Phoenix
    2018 DCSB TRD OR MT
    Pretty much, and like the guy ahead of the, stay in 2nd and above as much as you can.
  6. Aug 27, 2020 at 9:37 PM
    microsnook
    '20 TRD OR MGM MT
    Ok, cool. I usually just shift dramatically slowly and it turns out fine. I'm on rocky stuff out in CO. Usually use 2nd too but 1st when getting steep and technical and need to go super slow.
  7. Aug 27, 2020 at 9:42 PM
    Bishop84
    I loved aspects of M/T offroading with my jeep, but I found it to be tiring on a trail, the tacoma o/r auto made way more sense after years of shifting haha.
    With water crossings in the spring, a good habit is to never shift while in water. The clutch can hydro lock and not re-engage on the 2nd gear shift leaving you stuck in water. So 2nd in, 2nd out.
  8. Aug 27, 2020 at 9:43 PM
    BillW
    N. Phoenix
    2018 DCSB TRD OR MT
    And while we're on that topic, do the rear diff breather mod.
    D2., David K, m603holden and 6 others like this.
  9. Aug 27, 2020 at 9:47 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You dont use 1st in low, unless you are on very steep hill. You take off in 2nd if you are on flat or even on a minor hill.
    Also, the rev hang doesnt help, gotta release the clutch slower to let those rpms drop for a smoother shift from 1st to 2nd.
  10. Aug 28, 2020 at 1:24 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    You'll get use to it and once you do you'll love it just as the rest of us did. Shift Slower till you get the feel for it.$.02
    microsnook[OP] likes this.
  11. Aug 31, 2020 at 10:11 AM
    microsnook
    '20 TRD OR MGM MT
    Awesome, thanks for all the replies everyone. I have watched videos and learned to not shift while crossing water. Luckily the water crossings aren't too deep here. But I do love driving through water. I heard 1st was better that way if you stall you can use the clutch start cancel and start the truck in gear..... but i suppose it depends also on how fast you need to go through and how long it is, how deep, etc.
    I'll keep practicing in 4LO and shift slow like i have been. I do use 1st for the steeps and have learned that I can take off in 2nd on the flats.
    Thanks again
  12. Aug 31, 2020 at 10:13 AM
    microsnook
    '20 TRD OR MGM MT
    Oh, yea and the Tacoma is rated to ford so many inches of water....I can't remember exactly what the specs of this is. But at what point do you need to do the breather mod? Ive seen so many tacos without it (assuming) driving through water without issues. Im sure at a certain point its necessary but then wouldn't a snorkel be as well at that point? Thanks
  13. Aug 31, 2020 at 10:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you're in lo range shifting gears shouldn't happen often. Pick one and leave it there. It won't hurt a thing in most cases to just start in 2nd gear if 1st is too low.
    The factory breather tube goes up past the top of the tires. Unless you're up to your headlights you should be fine. If you're needing a snorkel to get air to the engine then you need to extend the tube.
  14. Aug 31, 2020 at 10:21 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    It's really super overkill, but in the 2-4 range you can also double clutch to help make those shifts a bit smoother until you get a feel for it. Old school technique that isn't needed any more, but can help with this just to get your bearings
  15. Aug 31, 2020 at 10:22 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Great tip, thanks:thumbsup:
  16. Aug 31, 2020 at 10:22 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    When I was in the army we used to always skip 1st gear. We replaced a lot of clutches! Just saying.
  17. Aug 31, 2020 at 10:28 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    1st gear in taco is quite low, no need to use on a flat surface, even slight incline. You just release the clutch and she goes no problem. On slight uphills you gotta give it about 1k rpm and all good.
  18. Aug 31, 2020 at 10:29 AM
    microsnook
    '20 TRD OR MGM MT
    That's been my experience. Usually 2nd low is where I need to be till it gets steep, Then I stop and downshift and walk up the obstacle.
    Ok, that's great advice. When I do the snorkel, I will do the diff breather mod too.
  19. Aug 31, 2020 at 10:29 AM
    microsnook
    '20 TRD OR MGM MT
    Yea, not really wear and tear cause its so low and slow. I love that the truck can drive itself in 1st
    Junkhead[QUOTED] likes this.
  20. Aug 31, 2020 at 10:30 AM
    microsnook
    '20 TRD OR MGM MT
    Double clutching is something I need to look up! I've had a few manual cars, but never got super technical with the driving, just drove it normally mostly.
