MT occasionally locks out 2nd gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by camaro322hp, Sep 17, 2023.
  1. Sep 17, 2023 at 10:54 AM
    camaro322hp
    camaro322hp [OP] Active Member
    Tigard, OR
    2023 TRD Sport M6 // 1999 Z28 M6 // 2007 GSX-R750
    Hey all. I've had this happen 2 or 3 times now so thought I'd ask about it. 2023 TRD Sport MT with ~1,500 miles. 2nd gear becomes completely locked out. The best I can recall is I'm downshifting at the time, but not coming to a complete stop. Speed is around 20 mph, so 3rd will result in no power and 1st isn't great to downshift to at that speed. The last time I ended up panicking because I was in heavy traffic and a guy almost merged into me and I ended up in 3rd with no acceleration. After I go into 1st or 3rd, then 2nd is available as normal again.
    I haven't found the sequence of events that triggers it, so can't really take it to dealer because I know their answer will be some variation of "works on my box." Anyone else ever have this happen? What am I doing wrong?
    Expecting the AT guys to chime in and say "should have got an auto..." :)
  2. Sep 17, 2023 at 10:56 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What do you mean by “locked out”? Are you sure you aren’t just moving the shift lever incorrectly? It happens to the best of us.
    doublethebass and Junkhead like this.
  3. Sep 17, 2023 at 11:00 AM
    camaro322hp
    Tigard, OR
    Feels like something physically blocking the path to 2nd. It goes into 3rd or 1st fine. Pretty hard to get 2nd wrong - left, down. I hear you, but I genuinely don't think I'm just blowing the shift, been driving manuals for 30 years, although this is my first Tacoma.
    Edit: oh, I see what you're saying. Maybe I'm going too far left into the reverse column? That could be it I guess
    doublethebass likes this.
  4. Sep 17, 2023 at 11:06 AM
    gudujarlson
    Minnesota
    Yes, I think that might have happened to me a couple times when I’m in a hurry or distracted. More often Ive put it in reverse instead of first, but Ive gotten better at that over time. Reverse was right and down on all my other transmissions. They were 4 and 5 speeds.
    Junkhead and camaro322hp[OP] like this.
  5. Sep 17, 2023 at 11:12 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This happens to me on the mountain. I need to pass so I need to get it in 2nd, but all attempts fail over a certain MPH. Even rev matching the snot out of it, it still won't go.
  6. Sep 17, 2023 at 11:14 AM
    camaro322hp
    Tigard, OR
    OK, the more I think about it, this is probably what's happening since these have been times when I've been shifting in a hurry so probably gave it some extra juice. I have also done the accidental reverse instead of 1st a couple times. I don't love the reverse location on this trans, but still miles better than an auto. :)
    Thanks for pointing me in the right direction, it was user error after all.
    50Buck, doublethebass and Junkhead like this.
  7. Sep 17, 2023 at 11:16 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    This only happens with 1st to me… 2nd is usually good.
  8. Sep 17, 2023 at 11:17 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    For me initiating the reverse gear selection requires a deliberate motion so don’t think that could be the problem. Next time it happens, if it’s safe to do, with clutch pedal depressed, increase engine rpms and put slight pressure on shifter to see if you can rev match engine and transmission. Mine will feel like it’s locked out if I try to downshift and the rpms are not high enough. I’m conservative downshifting and make sure vehicle speed is slow enough for trans to ‘drop’ into gear. If it sounds like I’m saying you aren’t shifting properly I’m not. Just suggesting.
    shakerhood likes this.
  9. Sep 17, 2023 at 11:27 AM
    camaro322hp
    Tigard, OR
    Thanks. If it happens again, and I can confirm I'm not in the reverse column, I'll try rev matching.
  10. Sep 17, 2023 at 11:40 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Absolutely no issues here, 50k miles. Transmission was a bit “notchy” but broke in really nicely.
    I got “locked out” of first a few times over the years but that happened on all my MT vehicles.
  11. Sep 17, 2023 at 11:48 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I’ve done accidental R twice so far.:) Yeah not a fan of location but it’s a very minor thing.
    Both times wasn’t paying attention sitting at a red light…
  12. Sep 17, 2023 at 12:46 PM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    Very pricey, but a short throw shifter solved the absurdly weak reverse indent when going to 1st/2nd in a rush when short stopping with the stock shifter.
    BillyE, Superdave1.0 and CCATT-RN like this.
  13. Sep 17, 2023 at 12:53 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I had this issue but with 4th when my truck was new. Tried the dealer and was told to give it 30'000kms for the transmission to break in. Crazy and dangerous yes but, it did correct itself. I changed my transmission fluid at 10'000kms and it was much better but the odd time would block 4th on a downshift but now at 145'000kms I don't know the last time it even happened. It sounds like these transmissions just take a while to break in from similar hicups i've read on here. All in all I would change the transmission fluid after a few thousand more miles and run it till mid way through your basic warranty and go from there(as sketchy as it sounds)
  14. Sep 17, 2023 at 1:32 PM
    gudujarlson
    Minnesota
    I think it’s more likely that people get better at shifting their transmission than the transmission gets better at being shifted.
    Chew, Junkhead and doublethebass like this.
  15. Sep 17, 2023 at 3:09 PM
    joba27n
    Nolan
    Alberta
    I kinda disagree because I test drove a few other brand new Tacoma's fighting with my dealer to address an issue with mine and I drove them all the same and could feel the difference
    Superdave1.0 likes this.
  16. Sep 17, 2023 at 3:41 PM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    I have a 2023 mt. The shifting was a bit notchy when new; but I wrote that off to lack of experience with the Tacoma gearbox. However, I changed the transmission, both differentials and the transfer case gear oil to Amsoil at about 700 miles. This was far from necessary, but I like doing simple maintenance like this. Got out some dark oil with metallic swirls in it. Since the change, shifting as been smooth as butter. My imagination? Maybe. But maybe also worth a try.
    joba27n likes this.
  17. Sep 17, 2023 at 4:27 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    stupid question, but are you rev-matching while downshifting? i can't speak on the tacoma's manual, but without rev-matching, my brz will absolutely be harder to get into a lower gear.
    and the reason i ask is i once had the displeasure of watching a corvette driver attempt to show the world he had a manual on a long state road with a few stop lights. i witnessed him downshift to at least 4 stop lights from 6th all the way to 1st without ever rev-matching. i could literally hear the car shouting in pain every time it lurched on clutch release...
    Chew likes this.
  18. Sep 18, 2023 at 12:14 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Yep, I still have the 2nd gear lock-out from time to time @ 70K miles. Usually, I am in lightly accelerating in 3rd and need a quick 2nd gear (and usually going up a slight grade.) Just sit there and coast and fumble around until it lets you in. Doesn't happen often, but it DOES happen. I also don't understand why it does that. I run Redline MT90 oil but that made no difference.
    bbartol likes this.
  19. Sep 18, 2023 at 12:54 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Ywah this happens to me too going from neutral to 1st at a stop sometimes.
    Figure it’s something with the synchros not quite lining up or some other weird quirk. Putting the lever quickly into 2nd and back to 1st always works for me.
    TacoGranny and doublethebass like this.
  20. Sep 18, 2023 at 4:41 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Slow down your shift let the rpm drop before shifting in that gear . If you try shifting into that gear at higher rpm the truck will fight you .
