MT start to warm up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fire133, Apr 16, 2023.
  1. Apr 16, 2023 at 10:19 AM
    fire133
    fire133 [OP] Well-Known Member
    Frank
    2023 Red Tacoma Sport
    I’m getting a manual Sport soon. Since it doesn’t have remote start what happens if I start it to warm up in the winter and walk away?
    Does it shut off? Does it need the key close by?
  2. Apr 16, 2023 at 10:24 AM
    Firn
    Firn Well-Known Member
    White OR
    You need to leave the key in the ignition.
    86_MR2, BillyE, wilcam47 and 4 others like this.
  3. Apr 16, 2023 at 10:26 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Keyed ignition only, so you’ll be leaving the key with it if you wish to do so.
    fire133[OP] and Junkhead like this.
  4. Apr 16, 2023 at 10:28 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    There is no need to warm it up in the winter though. There is a “defrost” button that uses elements for almost instant heat.
    Driving is the quickest way to warm up the engine/tranny.
  5. Apr 16, 2023 at 10:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    then someone drives away,,, with it
  6. Apr 16, 2023 at 10:45 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    If you turn temp and fan to max heat get some heat from a supplemental heating element until the coolant warms up.
    Enjoy the third pedal I'm dreading the end of the option.
    BillyE, Stevie17, shakerhood and 2 others like this.
  7. Apr 16, 2023 at 11:28 AM
    fire133
    Frank
    Please explain the defrost button/supplemental heat, I've watched countless vids on my new truck but never heard of this
  8. Apr 16, 2023 at 11:38 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I believe our trucks have a supplemental electric heating element in the ductwork, to allow for near instant “heat”, now it’s not HOT, but when it’s 12F and you can get near instant 40-60F air, it helps,,, a lot.
    Disclaimer- I made those numbers up, but I think it get the idea.
    02Duck, RustyGreen and fire133[OP] like this.
  9. Apr 16, 2023 at 11:43 AM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    I know it's already been answered - but to share my personal experience, my Tacoma is probably the quickest to start blowing hot or cool air of any vehicle I've had...As for the cool air - I can literally freeze myself in 85 degree full sun within a couple of blocks. I do have Carbon CXP tint, which I'm sure helps that.
    That said - as for "warm up" time (unrelated to cabin temperature) - I just wait for the Continue button on the center stack to "click itself" just to give everything time to start up, then I put it in Drive and off I go.
  10. Apr 16, 2023 at 12:01 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Hm, my Tacoma is the slowest to blow hot air out of all my previous vehicles. Takes a while to get to normal operating temperature, 4-5 miles in the wintertime.
    MulletTaco likes this.
  11. Apr 16, 2023 at 12:03 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    There are a few requirements in order for the PTC heater to turn on.
    Firstly, it only comes with the V6 model Tacoma.
    Next, the following parameters must be met:
    • AC temperature set to max heat
    • Blower turned on
    • Coolant temp 65°C (149°F) or lower
    • Ambient temp 10°C (50°F) or lower
    86_MR2, 02Duck, RustyGreen and 3 others like this.
  12. Apr 16, 2023 at 12:07 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    You definitely aren’t slow to blow hot air :rofl:
    Reggie4x4 likes this.
  13. Apr 16, 2023 at 12:13 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Bad idea; bad for the engine as warming up does significantly more harm than starting it, clicking on your seatbelt, and driving away, and bad for you when someone hops in your vehicle and drives away with it.
    fire133[QUOTED][OP] likes this.
  14. Apr 16, 2023 at 1:12 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  15. Apr 16, 2023 at 1:52 PM
    02Duck
    This is what I have experienced also. Works pretty well on cold mornings.
  16. Apr 17, 2023 at 3:48 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Did not know the Tacoma had that. Interested to see how that works once mine gets delivered.
    I know know the '23 in certain models comes with remote start with the AT. Does anyone know if the manual has the components but the remote start is disabled?
  17. Apr 17, 2023 at 4:01 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    1: when it’s -40 I don’t care, I want a warm truck
    2: I’ve had vehicles with over 300k on them and always let them idle to warm up in my yard, literally everyone in northern climates I know do this as well. Never an issue.
    If it is “bad” for the engine it must be negligible
    OP, if it’s in your yard just run out and start your truck, or buy an aftermarket remote starter. I wouldn’t live without one in the cold winter months.
