MT Summer Meet - August 2011
Discussion in 'North West' started by MTgirl, Jul 13, 2011.
  1. Jul 26, 2011 at 5:22 PM
    #161
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    So we are having a Montana Mini Meet in Idaho??:confused:
  2. Jul 26, 2011 at 5:43 PM
    #162
    MTgirl
    MTgirl [OP] too many frogs, not enough princes... Moderator
    Weesa
    Bob's secret mod lair
    No....in the Gravelly Range...where we were for the August meet last year.
  3. Jul 26, 2011 at 5:58 PM
    #163
    MTgirl
    Weesa
    either we need an update from Ben or I'm gonna need some more poppycorn :popcorn:
  4. Jul 26, 2011 at 6:44 PM
    #164
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Ben you still out there?:yawn:
  5. Jul 26, 2011 at 10:03 PM
    #165
    JDenny15
    JDenny15 Well-Known Member
    Bozeman, Montana
    05 Tacoma TRD offroad
    Custom built front bumper, URD true cold air intake, Throttle body spacer, Jardine cat-back Exhaust, URD short throw shift, custom flatbed, rear airbags, led light bars, ooga horn, CB, PA
    of course my friend has a taco
  6. Jul 26, 2011 at 10:14 PM
    #166
    Hardwater
    Hardwater Well-Known Member
    Great Falls, MT
    2011 MGM TRD AC
    1.5" Add-A-Leaf, Toytec Coilover kit @ 2", LR UCA's, Bilstein 5100's all the way around, ProComp 7032's, 265/75 16 Duratracs, bed mat, Weather Techs Digital Fit Floor Mats, Wet Okole Seat Covers, Satoshi
    Channel locks are your friend, not familiar with the 1st gen so not sure they will get in there, but they work if you have room, I never bother with actual filter wrenches. Another thing you can do is pound a screw driver through the bottom, again only if you have room(this will be messy)... It should not be this tight in the first place, someone didn't lube the rubber o-ring when they put your last one on.... Make sure you rub used or new oil on the rubber o-ring on the new filter and only tighten it as much as your own hand will allow, you will avoid this B.S. next time.
  7. Jul 26, 2011 at 10:26 PM
    #167
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This ^^^
    Pound a long screw driver through the old filter can. This will give you a good grip to twist it off.
  8. Jul 26, 2011 at 10:37 PM
    #168
    Hardwater
    Great Falls, MT
    2011 MGM TRD AC
    That thing with a strap on it is called a strap wrench.
    You just need to lube the o-ring or gasket on the filter, the filter will fill on it's own very quickly when you get oil pressure, some people will argue it needs oil so your engine isn't starved for a split second, but I've never bought into this.
  9. Jul 26, 2011 at 10:40 PM
    #169
    Digiratus
    Roaming the PNW
    The RedHead
    I just put some oil on the gasket, all the way around so its not dry and just hand tighten.
  10. Jul 27, 2011 at 7:23 AM
    #170
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Good job Ben! Your off to a good start:)
  11. Jul 27, 2011 at 8:01 AM
    #171
    MTgirl
    Weesa
    :cool: I was just kidding anyways...anyone is welcome!
    Interesting read huh? :laugh:
    Save yourself a step next time and buy the Toyota OEM filters...they come pre-lubed. You can get them by the case (10) on ebay for like $40 free shipping too!
    :smack: and that's for leaving us all wondering if you were OK!
  12. Jul 27, 2011 at 9:38 AM
    #172
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    I could have swore I read on the first page of this thread that there is a mini meet in Idaho on the weekend of the 12th...Is the plan to go into the Gravelies from the Idaho side and come out south of Ennis?
  13. Jul 27, 2011 at 9:41 AM
    #173
    MTgirl
    Weesa
    I plan on meeting up with Ben at Henry's Lake, ID...its like 4 miles over the border...and then continuing on into the Gravellies from the south. See the map below
  14. Jul 27, 2011 at 10:01 AM
    #174
    MTgirl
    Weesa
    I was hoping early...say 10 or 11 ish? Its a 2 hour drive for me so I'd have to leave home by 8 or 9. I've never been on that southern stretch of road from Henry's Lake to the Gravelly road so I don't know how long it will take us + we still have a drive to get to camp etc....and that would be the main day to explore up there unless you were thinking of spending most of Sunday exploring too :notsure:
  15. Jul 27, 2011 at 11:55 AM
    #175
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    I will have to think about this one, Google maps says I have a six and a half hour drive:confused:
  16. Jul 27, 2011 at 3:20 PM
    #176
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Said like a true prophet. :cool:
    WOOT!!!!! Eibach coils and 5150s showed up today!! :D :D :D :D now i officially have ALL of my suspention...gonna be a good weekend :D:goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    And there is still a chance ill be joing you guys on the 13th...maaaaaybe
  17. Jul 27, 2011 at 4:05 PM
    #177
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    You giving that baby a lift?
  18. Jul 27, 2011 at 4:06 PM
    #178
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    And i have not said no yet:D
  19. Jul 27, 2011 at 4:59 PM
    #179
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yesss sir :D
    ill have Eibach coils up front with Billy 5100s. Then in the back ill have Wheelers 5pk and Billy 5150s. I have some 1.5'' shackes too from toyo tech...but i dont think ill need them anymore after seeing how well the 5pks do on their own...plus shackles lifts a cheater ways :p lol
  20. Jul 27, 2011 at 5:05 PM
    #180
    MTgirl
    Weesa
    5 pack and 5100's here...the rear sits at about 38" from ground to top of fender if that helps you make up your mind before taking the truck apart...
