MT won't go into gear in RWD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stonybrook, Nov 5, 2023.
  1. Nov 5, 2023 at 5:30 PM
    stonybrook
    stonybrook [OP] Well-Known Member
    Santa Fe, NM
    Hi All,
    Need some of your collective brain power.
    Today, wife was driving the truck. She parks and when she returns it won't budge. Reverse, 1st, 2nd, 3rd. Nothing gets it to move.
    I suggested putting it in 4H and she was able to drive it a short distance home.
    I wasn't there during any of this, but when I got home I put it back in 2WD and of course it seems to drive fine.
    I have an '08, V6, 6 spd manual, ~200k miles. Haven't had problems with the rear diff, transfer case, transmission up until now. I did look under the truck. Honestly just trying to see if something was majorly abnormal. The drive shaft hasn't fallen out, everything looks like it did 2 days ago when I replaced the oil.
  2. Nov 6, 2023 at 12:11 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, just curious as to whether the clutch has ever been replaced? Some of these that had engagement problems had the center of the clutch disc coming apart.
    I'll have to ponder this a bit as why it was a RWD thing.
  3. Nov 6, 2023 at 12:29 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll guess a broken or frozen rr parking brake cable
    Rock Lobster and SR-71A like this.
  4. Nov 6, 2023 at 2:52 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Wife drove it. Sorry for your loss.
    Did she maybe accidentally put the T case into neutral somehow and not realize it? When she was fiddling with 4wd maybe she engaged it again?
  5. Nov 6, 2023 at 3:50 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Was it just revving up or did it act like its stuck? Any moisture will cause the rear drums to "seize" when the parking brake applied. Makes sense as it's a manual. Putting it in 4WD gives it the extra oomph to get it to break free. I'm probably completely wrong here, but just throwing it out there.
  6. Nov 6, 2023 at 3:56 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    yeah that kinda makes sense, same happened to me after taking a boat out. First time I was able to put it in 4lo and pop it out. Second time it was stuck hard and wouldn’t budge at all. Luckily I was in my driveway so I jacked it up and hammered the drums till they popped free.
    OP, any wet weather or deep puddles she may have crossed through?
    Delta09[QUOTED] likes this.
  7. Nov 6, 2023 at 7:01 AM
    stonybrook
    Santa Fe, NM
    It has not had the clutch replaced. Has been shifting fine leading up to this. I did the transmission fluids ~40k miles ago, and have plans to do again this weekend
  8. Nov 6, 2023 at 7:04 AM
    stonybrook
    Santa Fe, NM
    All great ideas.
    It's New Mexico in Fall, so there hasn't been any water for a while. The parking brake has been a bit sticky. I'll look up the instructions and maybe swap it out.
  9. Nov 6, 2023 at 7:12 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Next time it happens, try getting unstuck in reverse (or at least alternate pushing directions).
    My parking brake got stuck once after I washed the truck, so I tried it in reverse (hearing that drums are weaker in that direction), and it popped free right away. (This was in my Tacoma).
  10. Nov 6, 2023 at 8:04 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like user error :anonymous:
  11. Nov 6, 2023 at 12:53 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I don't let anybody drive my truck,especially a MT and a woman on top of that,and no I don't care who's feelings get hurt because of that fact.
  12. Nov 6, 2023 at 1:36 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I let my sister drive my MT trucks, she was taught by me :deadhorse:
  13. Nov 6, 2023 at 4:32 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My own mother taught me how to drive stick. At 67 she can still drive my truck if need to be, and has. :laugh:
    knottyrope[QUOTED] likes this.
  14. Nov 7, 2023 at 4:47 PM
    stonybrook
    Santa Fe, NM
    My mom taught me on Chevy 450 Dually. Know far too many braggarts (all male) that talk a big game but can'. But while this topic is devolving into spray, I'm still trying to fix it.
    Today it acted up on me. Drove fine for a couple of days. Today, it would not go into gear with the clutch to the floor and the engine running. However, I could turn off the truck put the clutch in, and put it in gear.
    I was able to limp it home. I noticed that even with the clutch to the floor, it's not truly in neutral. It's still rolling slightly forward. Turn the engine off and shifts great.
    Clutch master cylinder looks good (no obvious leaks)
    Any thoughts?
  15. Nov 7, 2023 at 4:53 PM
    81shark
    81shark Well-Known Member
    Just a thought. Maybe good, maybe bad...
    There is a small bushing on the end of the shifter that is a wear item. When it wears, it doesn't like sliding into gear. Swapped mine a couple of years ago and it was better. That said, I never had an issue get a gear, but I was grinding gears way more often
    stonybrook[OP] likes this.
  16. Nov 7, 2023 at 5:27 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    This won't help much but I had a 3rd gen pro do this to me when I was a valet.
    I put the parking brake down, shifter into the reverse and let the clutch out.
    Truck goes no where.
    Put it in first and same thing.
    I put it 4wd and it drives perfectly fine.
    I never really got am explanation as to what happened. I put the truck back in 2wd when I parked it and the owner picked it up and left. Always found it strange.
  17. Nov 7, 2023 at 5:29 PM
    Heyyo_Friday
    Derek
    Dfw, texas
    2020 tundra 1794
    Slave cylinder would be my next look. Not sure how the clutch set up is on tacos
  18. Nov 7, 2023 at 6:18 PM
    fxntime
    Time for a new clutch and pressure plate. You are at the end of it's life. Every yota I had acted the same way at the end of it's clutch life. You will likely find it acts a bit differently depending on temperature.
  19. Nov 7, 2023 at 7:12 PM
    stonybrook
    Santa Fe, NM
    Huh, the times it was screwing up was morning. Then was "better" by the afternoon.
  20. Nov 8, 2023 at 10:47 AM
    knottyrope
    Knotty
    Bahstun
    put a rag in clutch MC to remove the fluid by soaking
    fill up with fresh brake fluid
    pump 20 times and see how it is after
    Did wonders on my F350
