Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. May 30, 2017 at 10:33 AM
    #4801
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    No problem. The whole reason you have to replace the UCA is to bring suspension geometry back into alignment specs, which the SPCs do sufficiently. The difference being that the Uni-ball UCAs offer a little more angle than the ball joints on the SPS do, which is good for mid-travel coilovers. But the ball joint is good enough, unless your purpose includes jumping your truck.
    jc11taco89[QUOTED] likes this.
  2. May 30, 2017 at 10:40 AM
    #4802
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Hahaha yaa nope definitely don't intend on it being airborne at any time, but who knows crazier shit has happened. Thanks again for all the info bud
    Supra4x4[QUOTED] likes this.
  3. May 30, 2017 at 10:55 AM
    #4803
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    The other issue is the extended travel. This gives you about 3/4" more extension on the shock, which will almost certainly be more articulation than that ball joint (or truthfully most Uni-Ball) arms can handle. The result is you're using the Ball Joint as a limit stop for down travel, how bad this is depends on how often and how hard your front tires come off the ground. Limit straps are the answer if it's a problem.
    All that said, lotsa folks using SPC arms and extended travel coil overs, not many (I can't think of any) people complaining about breaking shit, so you're probably OK.
  4. May 30, 2017 at 11:12 AM
    #4804
    jc11taco89
    jon
    Naugatuck CT
    Awesome definitely appreciate thee info, and ya some day down the road I may up grade to a uni ball but for now definitely glad to hear there adequate hahaha. Thanks again bud.
    Arcticelf[QUOTED] likes this.
  5. Jun 1, 2017 at 7:46 AM
    #4805
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    when i had SPC arms i found this to be a nice part about having them. The ball joint is lower than the mounting point of the Uniballs so it allowed for more lift and travel. I had to de-crank quite a bit when i swapped to Uniballs.
    By allowing more lift im simply meaning i was able to crank more than with uniball arms because the position and location of the BJ. They didnt add any lift, simply allowed me to crank for more height without being severe angled.
    jc11taco89 likes this.
  6. Jun 1, 2017 at 9:30 AM
    #4806
    Arcticelf
    Gladiator
    Interesting. There is no good reason I know of not to adjust the angles of the ball joint or uniball to make the joint not a limiting factor in articulation.
    I think people use the joint to limit articulation because it prevents damage to the CV by over extending it.
    jc11taco89 and LTDSC[QUOTED] like this.
  7. Jun 1, 2017 at 9:33 AM
    #4807
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    100% agree. I just kept going until it was an issue for more height. But when i switched to the uniball arms i realized i was way over cranked.
  8. Jun 1, 2017 at 9:36 AM
    #4808
    Arcticelf
    Gladiator
    I made a custom set of uniball misalignment spaces for my Upper arms, and then added limit straps to prevent binding in the CV. The real issue is total down-travel, not ride height.
  9. Jun 4, 2017 at 1:33 AM
    #4809
    toytac05
    toytac05 Well-Known Member
    los angeles
    05 trd sport
    icon ext travel co dirt king lca dirt king heimed uca fox bumps dmz sua icon piggy back fox bumps Solo Motorsports pre runner bumper ifs trans tcase skids demello wrap around rear bumper mcniel fiberglass fenders and bedsides front suspension and rear suspension set up by Solo Motorsports
  10. Jun 5, 2017 at 6:51 AM
    #4810
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I took my truck out for the first tail of the year, after all the work was completed, and I had an issue. The UCA is hitting the coilover spring, but only on the driver side.
    What causes the UCA to hit the spring? On the passenger side it has at least .5" space, while the driver is basically resting on the spring.
  11. Jun 5, 2017 at 7:02 AM
    #4811
    Arcticelf
    Gladiator
    Are both sides drooping the same amount? It may be that the difference in how the alignment cams are set gives one side room and the other hits. That would mean something else is stopping the down travel on the passengers side.
  12. Jun 5, 2017 at 7:07 AM
    #4812
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Yea, the issue is at ride height... I have the coilovers cranked right now and was taking it on a moderate trail to see if it would settle some. The drivers side is resting on the spring while the passenger has plenty of clearance.
  13. Jun 5, 2017 at 7:07 AM
    #4813
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    What control arms are you running?
  14. Jun 5, 2017 at 7:08 AM
    #4814
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
  15. Jun 5, 2017 at 7:15 AM
    #4815
    Arcticelf
    Gladiator
    How much lift is on those things?
    Since you've got adjustable UCAs, is there a difference in how much thread is showing on the adjustments?
  16. Jun 5, 2017 at 7:20 AM
    #4816
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    I haven't adjusted them yet, and I do not see any threads visible. I've had them on for about 3 trails and about 600 miles. The latest change I made was swapping from a 600lb spring to 650lb spring, on my Fox coilovers. The shittest part for me is when I dropped off my truck to have majority of the work done last year, the shop lost the adjustment/alignment bar for the heims.
    I'm thinking the direction you're going is correct. I'll need to call Rokmen, see if I can get the alignment bar, and figure this out.
  17. Jun 5, 2017 at 7:31 AM
    #4817
    Arcticelf
    Gladiator
    Interesting problem, and shitty from the shop. I'd check the symmetry on top and bottom between the two sides.
    You can fix the coil issue by adjusting the heims out, but that will screw up your alignment if you cant also adjust the LCA out.
  18. Jun 5, 2017 at 7:32 AM
    #4818
    jc11taco89
    jon
    Naugatuck CT
    Hey @BigRedToy the exact same thing was happening to me a while back, idk what your running up front but when I did my 5100 I brought it to a local shop to compress the springs and the dumbass put the coilspring seat upside down which gave me like 4 1/4 inches of lift which made the coil rub up against the UCA.
    Arcticelf likes this.
  19. Jun 5, 2017 at 7:33 AM
    #4819
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You try rotating the coil so the UCA ends up inbetween coils?
    BigRedToy likes this.
  20. Jun 5, 2017 at 7:34 AM
    #4820
    Arcticelf
    Gladiator
    FFS....
