MTS / CC - lifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Oct 28, 2018.
  1. Oct 28, 2018 at 10:41 AM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Hey everyone. Apologies if this has been answered or it’s a stupid obvious question. But if you lift your trucks or modify the suspension / tires does the crawl control / mts or locker functions still work? I know all of it is computerized so not sure if the new lift or bigger tires affect it at all. Any off road owners have experience with this and verifying it all works (or not)?
  2. Oct 28, 2018 at 10:56 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Doesn’t affect at all
    tcjacado likes this.
  3. Oct 28, 2018 at 10:57 AM
    ejewels
    CT
    Good to hear. Thanks
  4. Nov 6, 2018 at 8:03 PM
    ejewels
    CT
    Bumping my own thread but will be doing a 2” lift soon, waiting on install date. I read a few threads on VSC and ABS systems needing resetting on a few lift stories. Generally at 2”... will all my systems (CC, MTS, Locker and VSC) still work OK?
  5. Nov 6, 2018 at 8:06 PM
    tcjacado
    tcjacado Well-Known Member
    All systems will still work. Only thing that maybe highly sensitive is the VSC .
    ejewels[OP] likes this.
  6. Nov 6, 2018 at 8:06 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You might need a zero point calibration (google it) if your vsc gets confused. Other stuff will work fine.
    ejewels[QUOTED][OP] and tcjacado like this.
  7. Nov 6, 2018 at 8:08 PM
    ejewels
    CT
    Thanks guys. Is this luck of the draw or should I expect to have to reset the VSC?
  8. Nov 6, 2018 at 8:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Luck.
    tcjacado and ejewels[QUOTED][OP] like this.
  9. Nov 6, 2018 at 8:25 PM
    ejewels
    CT
    I also read it would only be affected if you went really large tires because of the speed sensors on the wheel.
  10. Nov 6, 2018 at 8:38 PM
    tcjacado
    The VSC has to do with the steering sensors. If you turn left or right and it doesn't like it.... it will brake and pull you you to the opposite direction of the turn.
    ejewels[QUOTED][OP] and hiPSI like this.
