Mud flap hanging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dwood, Feb 22, 2023.
  1. Feb 22, 2023 at 1:52 PM
    Dwood
    Dwood [OP] Well-Known Member
    Dave
    Minneapolis, MN
    2012 Silver DCLB TRD Sport
    35% Tint all around - Meso Dual Bright Dome - GY6.35 reverse bulb hack - Bedlinered Wheels - Tailgate dampener - dashcam hardwire - max liner mats - stubby antenna
  2. Feb 22, 2023 at 3:09 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
  3. Feb 22, 2023 at 5:02 PM
    Dwood
    Dave
    Minneapolis, MN
    Sorry I just need the fasteners, that’s my bad.
  4. Feb 22, 2023 at 8:33 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Each mud flap looks to be fastened by 3 clips (P/N 90467-07188) and 3 screws (P/N 90159-60603).
    Too Stroked, TnShooter and TireFire like this.
  5. Feb 23, 2023 at 1:45 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I went with oversize clips very tight to get the base in then pound the pin in with a small hammer been on for years. Seems the stock size is often too loose.
    Amazon.com: Ginsco 102pcs 6.3mm 8mm 9mm 10mm Bumper Push Fasteners Rivet Clips Expansion Screws Replacement Kit : Automotive
    Use these on many places as other clips are removed for access and fall apart such as holding on front wheel well liners, front plastic grill, etc.
    For screws and bolts I use ACE as they have every size and finish again may need slightly oversized to really hold as those rear flaps flex on rocks.
  6. Feb 23, 2023 at 8:10 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    think 1/4 hardware can replace a lot of it just need to get your fingers into the smaller spaces
  7. Feb 23, 2023 at 9:15 AM
    MR5X5
    MR5X5 Well-Known Member
    By chance are your running oversized tires and getting some rubbing? Pretty common.... Tin snips to knock down the protruding bits, heavier pins or 1/4 fasteners to reattach.
  8. Feb 23, 2023 at 9:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Push pins can be found at Lowes or HD
