mud flap modification
Discussion in 'Wheels & Tires' started by orangebutte, Feb 17, 2008.
  1. Feb 17, 2008 at 12:33 PM
    orangebutte
    orangebutte [OP] Well-Known Member
    Tucson, AZ
    08 access cab 4x4 trd off road w/lock diff
    I don't intend to lift my truck anytime in the near future. As a result, when I'm out in the desert, I can hear the mud flaps scrape against rocks, etc. I modified them to alleviate most of the issues:
    . used construction paper and taped it to the interior of the flap; paper will extend beneath the bottom of the flap
    . used a marker to trace the outline of the bottom of the flap
    . cut out the pattern
    . place the pattern on the exterior of the flap and measure upwards how much you want to trim off
    . I took 3" off each flap
    . trace the outline of the pattern ( curvature of the bottom of the flap) with a marker on the flap
    . I used a Dremel with a cut-off disc to cut the flap along the curvature pattern
    . afterwards I smoothed it out with a Dremel brush bit
    . I parked my truck on ramps to make it a little easier
  2. Feb 17, 2008 at 1:35 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Looks like this belongs on the cheap/free mod thread. But....
    :worthless:
  3. Feb 17, 2008 at 2:08 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    I was thinking that too...let's get some pics!
  4. Feb 17, 2008 at 2:28 PM
    orangebutte
    Tucson, AZ
    I bought a Tacoma instead of a digital camera! Maybe that will be my next purchase. Priorities you know! My daughter will have to teach me how to use it.
  5. Feb 17, 2008 at 2:57 PM
    Roland
    Rhode Island
    I bet you know someone that has a camera or even a cell phone with a camera built in. :boink:
  6. Feb 18, 2008 at 4:29 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I kind of feel it's a rite of passage to wear them out... to each there own :D
