Mud flap question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unicorn Taco, Feb 25, 2024.
  1. Feb 25, 2024 at 10:10 AM
    Unicorn Taco
    Unicorn Taco [OP] Member
    2022 Tacoma SR Access Cab
    I recently installed 265/75/16s on my 22’ SR. Since the SR is not equipped with factory fender flares like the other trim packages, the wider 265’s cause a ton of spray onto the sides of the truck. Not a huge issue but since the truck is white, it’s pretty hard to keep clean. Does anyone know if there will be rubbing issues if I install mud flaps with the larger tires?
  2. Feb 25, 2024 at 10:16 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Go with rokblokz. They have cutouts for bigger tires
  3. Feb 25, 2024 at 10:21 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I went from 265/70/16 to 265/75/16 without rubbing on the stock mud-flaps.
  4. Feb 25, 2024 at 10:28 AM
    Unicorn Taco
    Unfortunately the rokblokz do not fit the SR due to not having the factory fender flares.
  5. Feb 25, 2024 at 10:30 AM
    Manitoba
    It wouldn't be hard to make them work.
  6. Feb 25, 2024 at 10:36 AM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I have your exact situation, white 21 SR with the same tire size. I installed rekgen flaps which can rub a hair when I hit a bump while turning on the front wheels, but barely. I'm fine with it though. Heads up if you get them, for a while their instructions were backwards for which bolt spacer goes on each side inside of the flap, but they may have changed that by now. The flaps do help with keeping debris off the side of the truck but they don't eliminate it completely. My wheels are zero offset which also makes it a bit worse than factory wheels. Come to think of it, I am not sure if the flaps would even rub at all with factory offset wheels.
  7. Feb 25, 2024 at 10:39 AM
    Bishop84
    Bishop84 Well-Known Member
    The up size only typically rubs with slightly higher offset and that size, typically factory rims and 265/75R16 doesnt rub the flaps.
    You can easily resolve it with a high caster alignment.
    Finn-2187 likes this.
