Mud Flap Replacements???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aljohn208, Nov 20, 2016.
  1. Nov 23, 2016 at 3:27 PM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
  2. Nov 26, 2016 at 7:07 AM
    NM Lance
    NM Lance Well-Known Member
    If anyone happens to have a good close-up picture of the Husky's on a Gen II, particularly the rears, can you please post it? I have Googled and looked for good images, but I haven't seen any good pictures... even on Google! :confused:
    Edit: If you have an image looking directly at the back end of the truck from 15 or so feet away, it would be perfect. All the images I find are way too close, or at goofy angles.
  3. Nov 29, 2016 at 6:27 PM
    aljohn208
    aljohn208 [OP] New Member
    Alec
    2014 Tacoma TRD
    I saw a thread somewhere before about trimming your existing flaps. I did this and it turned out great. I cut a straight line 2.5 inches from the bottom of my front flaps with a pair of tin snips to make them the same length as the rear ones. I then used the pieces that I cut off to trace the radius on the flaps and cut them. Then used a file on any uneven spots then sanded for a smooth finish. They look stock and saved having to spend 25 bucks/ flap for new ones. Took less than 30 minutes. Highly recommend.
  4. Nov 29, 2016 at 7:28 PM
    dedmouse
    dedmouse Well-Known Member
    Dammit
    South Central Missouri
    2010 Black Tacoma Base, 6 spd manual tranny, V6.
    Are these flaps just plastic/hard rubber that can be cut on a bandsaw? There's no metal sandwiched in there to stiffen it?
  5. Nov 30, 2016 at 4:48 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Bandsaw? You can cut them with tin snips or hardcore scissors. Nothin but plastic.
  6. Dec 1, 2016 at 10:45 PM
    AmorPatriae
    AmorPatriae Well-Known Member
    12 DCSB SR5 4x4
    TRD Sport Hood, Truxedo Lo Pro Tonneau cover, OEM Bed Extender, SOS Front Bumper, SOS Rear Bumper, Pro Comp 84 Series Vapor, Goodyear Wrangler Duratrac
    My truck is a 2012 with OEM flaps. I've heard that there can be some wear on the panel from the flaps. Is that noticeable if you switch to husky flaps or do they cover it? Hopefully someone has experience and knows what at I'm talking about.
  7. Dec 2, 2016 at 1:19 AM
    DirtTaco
    DirtTaco Well-Known Member
    Yup I removed stock mud flaps on a white Tacoma and there are wear marks . I don't care really but it is probably easy to touch up with color match paint of some sort.
  8. Dec 2, 2016 at 4:12 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I can only speak to the front, but the husky covered up most of the wear.
  9. Dec 2, 2016 at 5:39 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Idk I think you are better off removing them or getting bigger tires. I think small mud flaps are like getting bushwacker fender flared but not getting wider tires. Just looks goofy. Just my opinion.
