Mud flaps and removing them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bambooshoots, Apr 1, 2009.
  1. Apr 1, 2009 at 1:21 PM
    bambooshoots
    bambooshoots [OP] Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    How do I get the mudflaps off my 2nd ten Tacoma?
  2. Apr 1, 2009 at 1:28 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    three screws and about three clips that pop out on each
  3. Apr 1, 2009 at 1:38 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Or you could do as many others have and just run over a curb or something similar like an ant hill and have them ripped off. :D
  4. Apr 1, 2009 at 2:09 PM
    bambooshoots
    Kevin
    College Station, TX
    So the clips DO pop off, ok. I was prying on them with my knife earlier and they wouldn't pop out.
    My truck is lifted and has Bilsteins, so I don't think the ripping mud flaps off would work :)
  5. Apr 1, 2009 at 2:12 PM
    jolayiv
    Jim
    Hertford NC
    The clips are a PITA. All but one of mine broke during the removal. That could be b/c I wasn't doing it right...? Who knows?
  6. Apr 1, 2009 at 2:14 PM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    The center of the clips pull out with a small screw driver, a little force may be required, then the clip pulls out. Remove the three 10mm bolts, remove the mud flap, and reinstall one bolt. I just removed the front ones on my prerunner today.
  7. Apr 10, 2009 at 11:18 AM
    Glocktex
    Glocktex Active Member
    Texas
    05 PreRunner
    what kind of screwdriver did you guys use to get them off?
  8. Apr 10, 2009 at 11:21 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    flat head
  9. Apr 10, 2009 at 11:23 AM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    easy as pie
    took no more then 15 minutes total, and i took my time and got all of the clips out with out breaking any of them
  10. Apr 10, 2009 at 12:21 PM
    Glocktex
    Texas
    05 PreRunner
    I realize a flat or phillips will work. I guess I should have asked, do you remove the tire or use a shorter screwdriver?
  11. Apr 10, 2009 at 12:53 PM
    white91formula
    Boston, MA
    05 6speed TRD OR
    flat head
    i took all 4 off with out even turning the wheel, can keep them on and straight
