Mud flaps....are they worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ncnative, Oct 3, 2020.
  1. Dec 28, 2020 at 2:49 AM
    #61
    tacoma_JT
    tacoma_JT Well-Known Member
    2021 Tacoma DCSB TRD OR
    I just installed a set of the Tufskinz too. Wanted the protection, but also loved the 4WD graphic... reminds me of the older Toyota trucks that first got my attention years ago.
    Rick111 and MissoulaGriz[QUOTED] like this.
  2. Dec 28, 2020 at 2:53 AM
    #62
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    What are the dimensions (length x width) of those flaps, please?
  3. Dec 28, 2020 at 2:58 AM
    #63
    tacoma_JT
    I’m out in the woods for a couple of days and don’t have anything to measure them with. I can help you out when I get back though.
  4. Dec 28, 2020 at 5:56 AM
    #64
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    Installed a set of Weathertechs last Saturday. Great design and fit, with NO drilling. Only one extra screw needed per flap, and it was included. Maybe 5 minutes per flap to install.
    Tacoma13_NC likes this.
  5. Dec 28, 2020 at 6:39 AM
    #65
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    approx 11x15 is tufskinz standard measurements but, you can contact them, give them specific dimensions, and they will custom make the size you like/want. the 11x15 are approx 2 inches shorter in the front, and 1 inch shorter in the rear, than the stock oem toyota molded mudguards. I asked them to make me a complete set front and rear 11x18" for me, those measurements would offer more protection for road slop. if i had to do it again, i would have went with 20" long flaps on the fronts, and a white logo, instead of the cement logo i ordered. here is a link to a discussion on them. for the custom size, it only took 10 days to order, and receive... and that was mid pandemic, and christmas shipping. Ski
    https://www.tacomaworld.com/threads/tufskinz-mud-flaps.688680/
  6. Dec 28, 2020 at 7:55 AM
    #66
    crbr
    east TN
    Thanks. I am on their list.
    tacoma_JT likes this.
  7. Dec 28, 2020 at 1:41 PM
    #67
    Bigeshorte45
    Bigeshorte45 Well-Known Member
    VA
    2017 DCSB 4x4 Sport
    The one's I purchased are now listed for $49.99 on Amazon and the listing is titled "A-Premium Mud Flaps Splash Guards Replacement for Toyota Tacoma 2016-2021 Molded with OEM Fender Flares (Doesn't Fit SR Models) Front and Rear 4-PC Set"
    Tacoma13_NC[QUOTED] likes this.
  8. Dec 28, 2020 at 1:59 PM
    #68
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    FWIW, I like the subtle cement rather than brilliant white on the flaps.
  9. Dec 28, 2020 at 2:57 PM
    #69
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Do you mind taking a pic of the inside front flap from the wheel well? I have been waiting to see your follow up. I wanted longer flaps also and am now debating between 18” or 20” as you said.
  10. Dec 29, 2020 at 7:41 AM
    #70
    skidooboy
    central lower mich
    @Silentshredr hope these help, the flaps are shiny on the inside so, you get a mirror reflection, that is why you see the stones in the driveway so well. :D Ski
  11. Dec 30, 2020 at 5:06 AM
    #71
    D500
    D500 Well-Known Member
    David
    SE Georgia
    Ski, Could I impose upon you to get a measurement from the ground to the bottom of the flap? I'm having a hard time deciding on the length I want to order. As you say, custom order, better get it right the first time.
    Thanks
  12. Dec 30, 2020 at 6:58 AM
    #72
    skidooboy
    central lower mich
    unless we are both lifted and have the same size wheels and tires, that will not help you much. i have a 19 sport with 17" 265/65/17, and 265/70/17 tires (winter/summer), i have a 2" front lift, and 1" rear lift. you will be better off measuring from the bottom of the flare. do you have the factory moulded mudguards? the dimensions are easier having those to compare to. Ski
  13. Dec 30, 2020 at 7:47 AM
    #73
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Draw a straight line from bottom of tire to bottom of flap this will show area of protection/not protected. When mounting remember, the front wheels turn and take this into consideration on how far outside the fender to mount flaps.
  14. Dec 30, 2020 at 11:49 AM
    #74
    D500
    David
    SE Georgia
    Didn't realize you were lifted, I have a 2020 Sport with the exact same 265/65 x 17 Toyo tires as yours, but not lifted, and probably won't ever be. If yours is lifted 2 and 1, that tells me what I needed to know, the 11 x 18 will be to long on mine. I think the standard 11 x 15 will be about right.
    Thanks for your help, I appreciate you taking the time.
    I need to go place an order.
    By the way, the idea of winter tires is unknown here in SE Georgia. Some winters, the idea of winter is pretty much unknown.
  15. Dec 30, 2020 at 12:30 PM
    #75
    skidooboy
    central lower mich
    personally, I would go with my length, if i were on stock height. i now that i have them, i would want the fronts another inch or even 2 longer. the rears at 18" are perfect, for me. Ski
  16. Dec 31, 2020 at 4:00 AM
    #76
    pwgunny
    pwgunny Well-Known Member
    Patrick
    Charleston, SC
    2021 TRD PRO LR, 2020 T4R SR5, 2004 T4R Sport V6( Sold)
    Mud flaps are cheap and easy, so put them on.
    Vmax540 likes this.
  17. Dec 31, 2020 at 8:10 AM
    #77
    Silentshredr
    Chuck
    16 DclbOr4x4
    I appreciate it!
    skidooboy[QUOTED] likes this.
  18. Dec 31, 2020 at 8:34 AM
    #78
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I like them. Helps kick down rocks and other debris. I also think it looks utilitarian. I used 1/8 ABS plastic to make mine since no aftermarket options would work for my bumper. Need to work on how to mount some to the front without rubbing.
  19. Feb 1, 2021 at 1:37 PM
    #79
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    Do you have a link to the Gen 2 RekGen?
  20. Feb 1, 2021 at 1:53 PM
    #80
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    I bought my '20 TRD OR 4x4 used, with the OEM flaps already installed. I've debated taking them off, or leaving only the rears but they don't really bother me so I've left them alone, so far. They do seem vulnerable to being yanked-off doing even moderate off-roading.
