Mud flaps left a scar!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TRDTACO, Nov 7, 2008.
  1. Nov 7, 2008 at 10:14 PM
    05TRDTACO
    05TRDTACO [OP] Member
    Justin
    Utah
    2013 Tacoma DC-silver TRD Off-Road
    Fabtech 6" lift, Bilstein 5100 rear shocks, TRD air filter, TRD exhaust, Optima redtop battery, 18% tint all around, debadged, fog light mod, power plugs hot all the time mod, Streamlight Stinger mounted behind seat, Viper 5704v security system and remote start, rear diff breather mod, & auxiliary fuse box
    Okay so I just lift my 05 double cab 3 inches and in preparation to getting new tires I wanted to remove the mud flaps. When I removed the rear mud flap there was a very deep scratch along my fender where the flap had been. My Taco is silver so that black scar sticks out like a sore thumb! Has anyone else had this issue? and also any ideas on how to hide that while still getting rid of the mud flaps? Thanks in advance
    -05TRDTACO
  2. Nov 7, 2008 at 10:26 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Yep, same on mine. I'd get some touch-up paint from the dealer. There is several threads on here that discuss paint touch-up if you haven't done it before.
  3. Nov 7, 2008 at 10:28 PM
    05TRDTACO
    Justin
    Utah
    Thanks! I'll probably just go get some touch up paint tomorrow so I can get those things off ASAP!!
  4. Nov 8, 2008 at 1:06 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    my front left a little mark like this when i took em off but its only like 3" long and pretty minor so i chose to just ignore it......
  5. Nov 8, 2008 at 5:38 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    HOLD UP on the paint, if you have a silver taco check out the pic's below.
    If interested in the tape let me know.
    Before.
  6. Nov 8, 2008 at 5:40 AM
    longbow
    Bill
    Indiana
    After.....with 10 min of your time.
  7. Nov 8, 2008 at 8:05 AM
    05TRDTACO
    Justin
    Utah
    Wow! That looks really good. Did you say that is just tape? I'd like to try that before i do touch up! -05TRDTACO
  8. Nov 8, 2008 at 8:12 AM
    05TRDTACO
    Justin
    Utah
    Yeah if you have some to sell I'll take it!
  9. Nov 8, 2008 at 9:07 AM
    longbow
    Bill
    Indiana
    It is a type of pin strip tape, about an 1" wide so you will need to trim it to the pattern you want. It also has protective film over the top so once you peel the backing off, get the placement you like, then peel of the semi clear film and you are good to go.
    Send me a PM with your address and I will get you 2 pieces out on Monday. No charge! :)
  10. Nov 8, 2008 at 9:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Great find LongBow. Is that something special or just pinstripe that a body man could get, I have some buddies that paint for a living.
  11. Nov 8, 2008 at 9:25 AM
    longbow
    Bill
    Indiana
    I got this a number of years ago, if you can remember when Toyota trucks had pin strips (wide) on the hood.
    In any case this stuff is top notch, I am using it and have sent it off for others to try. No bad reports as of yet.
    Just went and looked at the backing of it, it is 3M Scotchcal. That is all that is written
  12. Nov 8, 2008 at 10:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thanks I'll look around.
  13. Nov 8, 2008 at 10:39 PM
    justeday
    justeday diving fanatic
    campbell river, BC
    06 toy tacoma, silver mica
    265/75/16, bed mat, knaak tool box, custom headache rack with side rails,rear floods, rear rack, sirius
    u're lucky, i removed 3 of my mudflaps backing up onto a barge... didn't bother to put the front ones back on... any ideas on flexible mudflaps, ones that can take a 12 inch rise in reverse?
  14. Nov 8, 2008 at 10:42 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    There are no aftermarket mudflaps for our trucks. Do what I did and take all of them off. I've seen sets of 4 selling on Ebay for $150+. Easy money.
