mud flaps, on or off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Duderino 480, Jan 24, 2009.
Keep em on or off??
  1. ON!
    280 vote(s)
    50.6%
  2. OFF!
    273 vote(s)
    49.4%
  1. Jan 24, 2009 at 4:03 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    front flaps off for looks and a strip of spray on bed liner for protection :cool:
  2. Jan 24, 2009 at 4:08 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2019 TRD OR Double Cab
    Mine's the same. They were rubbing so off they came.
  3. Jan 24, 2009 at 5:33 PM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    I vote for OFF cause mine are really pissing me off getting caught up in deep snow.
  4. Jan 24, 2009 at 6:57 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    looks clean with them off, though i am sure with a lift you might keep em on so you don't bust out to many windshields and sorts.
  5. Jan 24, 2009 at 7:24 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Off!
    I still have my back ones on. They will probably stay.
  6. Jan 24, 2009 at 7:51 PM
    williegator
    williegator Well-Known Member
    atlantic beach florida
    trd sport 4x4
    toytec Ultimate kit set @ 3 inches, Light Racing UCA's, HELO HE791 17X8 WHEELS, BFG 285-70-17's, secondary air filter removed, ARI drop in filter, Scan Gauge, Roll N Lock
    Rear are fine, the front ones sux. Took them off within 2 weeks...
  7. Jan 24, 2009 at 9:52 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    There should be an option to vote for front "off" and rear "on" :D That's my VOTE!
  8. Jan 24, 2009 at 10:26 PM
    Dave Russell
    Dave Russell Active Member
    Tacoma 4x4
    Looks better off -Keeps paint looking good when on. Having said that - the 1st time you drive thru 2 ft deep snow or do some rock crawling (or drive over a sidewalk) you will probably lose them- and they ain't cheap to replace! If you want to attempt any of the above fun activities cut them back by at least 1/2 or take them off until you get bored with the above or get pissed at the pitted paintjob.
  9. Jan 25, 2009 at 3:00 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    I vote "take them off and buy some sliders if you are worried about rock chips."
  10. Jan 25, 2009 at 4:27 PM
    ERdept
    ERdept Well-Known Member
    On for courtesy and protection.
    Courtesy of others behind you. It's bad when you fling up a rock and break a windshield.
    Protection of the body from stones, splashes, etc.
    I did cut mine shorter though because stock ones are about 7 feet long.
  11. Jan 26, 2009 at 3:52 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    28-958.01. Rear fender splash guards
    A. A person shall not operate a truck, trailer, semitrailer or bus on a highway unless the vehicle is equipped with rear fender splash guards that comply with the specifications provided in this section.
    B. The splash guards:
    1. Shall be attached in a manner that prevents the splashing of mud or water on the windshield of other motor vehicles.
    2. Shall extend to a length of not more than eight inches from the ground.
    3. Shall be wide enough to cover the full tread or treads of the tires being protected.
    4. Shall be installed close enough to the tread surface of the tire or wheel to control the side throw of the bulk of the thrown road surface material.
    5. May be constructed of a flexible rubberized material.
    6. Shall be attached in a manner that, regardless of movement either in the splash guards or the vehicle, the splash guards retain their general parallel relationship to the tread surface of the tire or wheel under all ordinary operating conditions.
    C. This section does not apply to:
    1. A vehicle commonly known as a pickup truck with a manufacturer's rating of three-quarter ton or less, except that this section applies if the pickup truck has been modified from the original bumper height design to raise the center of gravity of the pickup truck.
    2. A truck tractor or converter dolly when used in combination with another vehicle.
    3. A single axle trailer with fenders wide enough to cover the full tread or treads of the tires being protected and that extend to a length of not more than fourteen inches from the ground
  12. Jan 26, 2009 at 10:56 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Somebody please send me a drivers' front mudflap?
    Thanks,
    Dan
  13. Feb 23, 2009 at 7:23 PM
    El Duderino 480
    El Duderino 480 [OP] "The Dude"
    Jeremy
    Oceanside, Ca
    Silver 08 PreRunner Sr5
    K&N 77 Series,Flowmaster Exhaust, OME N140's, OME 885's, Billy 5100's, Toytec AAL's
    post it up on the Buy/Sell section, and on craigslist..im sure you will find someone
  14. Feb 23, 2009 at 7:47 PM
    Jaybo
    Jaybo Well-Known Member
    Jaybo Talbo
    SC
    07 PreRunner
    i say off... it looks sportier without and you dont have to worry bout hitting the mudflaps on anything... thats why i took mine off
  15. Feb 23, 2009 at 9:30 PM
    #35
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I'm like Firefighter. I had to take my front ones off when I got my wheels and the 265/75's because of the rub, but I left the back ones on because I like the 4x4 logo. I like for people to know it's a 4 wheel drive. My wheels are 16x10 and I still have a little bit of a rub when in reverse, but it's not too bad. I kind of like the looks of them with the flaps on though.
  16. Mar 4, 2009 at 1:34 PM
    #36
    Siafu
    Siafu Eat My Dirt
    Redlands!
    V6 Camry XLE
    Limo tint on Windows, Removed all emblems, Powdercoated Rims Black
    front off. back on.
  17. Mar 5, 2009 at 6:57 AM
    #37
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    so i was messing around one day and was trying to get the rivets off without snapping them.... didnt work to well i stoped after i broke the first one, how do u get them off without destroying them lol
  18. Mar 5, 2009 at 8:21 AM
    #38
    El Duderino 480
    Jeremy
    Oceanside, Ca
    take off your tire, use a screwdriver to take out the screws..should be good!
  19. Mar 31, 2009 at 1:06 PM
    #39
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    Hard decision. Looks tough without them but you also get alot of paint chips...
  20. Mar 31, 2009 at 5:37 PM
    #40
    skynyrd
    skynyrd Member
    denver
    08 taco 4x4 quadcab TRD off road 3 inch lift
    3 inch toytech lift 285/75/16 BFG AT KO
    My front flaps are off after bigger tires and lift, rear flaps are still on. i like the look with the front ones off.
