Mud flaps - Point me in the direction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bigfishhunter, Aug 23, 2015.
  1. Aug 23, 2015 at 2:14 PM
    Bigfishhunter
    Bigfishhunter [OP] Member
    I have been doing some searching but can't seem to find any threads about removing old broken mud flaps and installing new after market ones.
    I just purchased some heavy duty rubber flaps that need to be drilled and screwed in but I can't seem to find any info on how to remove all the old stuff. I guess I could just go out there and experiment, but I like to do a little research first. Any insight out there? I'm sure this has been hashed out before.
  2. Aug 23, 2015 at 2:24 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I'm pretty sure the stock flaps use the same plastic "rivets" as other parts of the truck. I flathead screwdriver should pop them right out. I'm thinking of replacing my stock flaps with Huskys.
  3. Aug 23, 2015 at 2:25 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    take the screws out and then pull hard on the flaps to get the plastic rivet things out
  4. Aug 23, 2015 at 2:26 PM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    The stock mudflaps on my trd-offroad have 3 plastic re-usable rivets and 3 10mm allen head screws on each corner for a total of 24 fasteners. They can be removed in about 10 minutes of work
  5. Aug 23, 2015 at 4:04 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Yeah the old ones have three plastic rivets and two screws/bolts.
    You need to just a flathead and put just the center out before they will come loose.
    You can use a socket for the screws rather than a screwdriver.
  6. Aug 23, 2015 at 4:54 PM
    TrackAttack
    TrackAttack Well-Known Member
    Joe
    St. Louis, MO
    15 Supercharged Inferno Red TRD Pro
    Educate me on the Husky flaps... I have seen several posts where folks have replaced the stock flaps with Huskys. What is the benefit?
  7. Aug 23, 2015 at 6:23 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My front flaps cracked and broke within 3 years. They were constantly dragging the ground on rutted roads and off road. I never to any serious hard core off roading. I just took all 4 off and trashed them. I figured even replacements would do the same in a matter of time. Don't miss em, in fact I think it looks better and they only did a marginal job of keeping the truck clean when they were on there.
  8. Aug 23, 2015 at 7:37 PM
    wrangler2155
    wrangler2155 Member
    2006 Taco DCSB 6spd
    10mm socket/ratchet and a flat head screw driver and 2 mins. use the flat head to pop the center of the clip out and the whole clip pulls out , they are in there a little tight so it may take some wiggling.
  9. Aug 23, 2015 at 7:47 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Just leave the mudflaps off.
  10. Aug 23, 2015 at 8:05 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The Huskys are pre-molded like the OEM flaps, and fit the fender perfectly. They are slightly shorter for larger ground clearance, with less tendency to rip off.
    Mine came with a bolt-nut combination to replace those plastic rivets.
    TrackAttack[QUOTED] likes this.
  11. Aug 23, 2015 at 8:19 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    My .02, take them off. If you're running wider tires than the flaps, than wtf are they doing on there. The point of them is to block mud from getting on the vehicle's sides, if your tires are bigger, then they are obsolete. + they look better off anyway.
  12. Aug 23, 2015 at 8:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Rokbloks or Rally Armor
    PVT Pablo likes this.
  13. Aug 23, 2015 at 8:24 PM
    OZ-T
    Peter North
    British Columbia
    They also keep you from being the asshole thats launching rocks all over the vehicles following you
    DoorDing and MadDaddy like this.
  14. Aug 23, 2015 at 8:27 PM
    PapaBear
    Austin
    SIN CITY
    That's the price you pay for going 4 wheeling... i do agree though. Could always get glass for that problem.
  15. Aug 23, 2015 at 8:28 PM
    OZ-T
    Peter North
    British Columbia
    We have gravel roads
  16. Aug 23, 2015 at 8:31 PM
    PapaBear
    Austin
    SIN CITY
    We do too. o_O
  17. Aug 24, 2015 at 8:02 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    If you have aggressive tires that tend to hold stones and you drive on public roads without mudflaps, it's a bit of a dick move, so thanks from my chipped paint and windshield. You can spit gravel on other traffic, even traffic coming in the opposing direction. Mud flaps don't completely eliminate it, but greatly reduces it. But I also notice that people that recommend removing the mud flaps never live in the snow belt. I can't pull them off with 150+ inches of snowfall a year. Plus I'm not a dick.
    mpm likes this.
  18. Aug 24, 2015 at 11:42 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  19. Aug 24, 2015 at 12:24 PM
    bigcrab
    bigcrab Well-Known Member
    2014 DCSB 4x4 TRD OR
  20. Aug 24, 2015 at 2:43 PM
    Marshall R
    Marshall
    none
    It was snow/ice that finally convinced me to take mine off. It built up so thick it finally broke the front flaps. The flaps only got in the way. Toyota is the ONLY truck manufacturer to even offer mud flaps. If they were needed all the other trucks would come with them.
    PapaBear likes this.
