Mud Flaps trimmed (with pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 26, 2012.
  1. May 26, 2012 at 4:55 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    I decided to trim my front mud flaps. The original measurement from bottom of fender to bottom center of mud flap is 12 inches. The rears measure 10 inches. After the trim the fronts measure 8 14/16 inches & they came out even, thankfully!
    I used a die grinder, a small level, a black magic marker, sanding block, course sand paper (used on sheet rock) followed by fine sand paper (used for wet sanding). I don't know the grit of the sand paper. I had them in my tool box. It's my 1st time doing something like this so I am happy with the results. Hope you agree:
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1057.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1058.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1059.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1061.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1062.jpg
    1) Measure from the lower fender section down to the bottom of the mud flap. Choose the desired length & mark it with a dot using a black marker.
    2) Put the level over the dot, align the level, draw a line accross the width of the flap.
    3) Get your die grinder (or cutting tool of your choice) & cut.
    4) Get the piece that you cut & align the bottom of it with the newly cut bottm of the flap.
    5) Hold it securely, get your marker & trace the curve of the cut piece over the newly cut mud flap.
    6) get your die grinder again & slice away.
    7) You now have a rough looking mud flap similiar to the original cut.
    8) Get the course sand paper with the block & start sanding the edges (long strokes).
    9) Do the same with the "wet sand" sand paper.
    10) Enjoy!
  2. May 26, 2012 at 5:00 PM
    fenway.park27
    fenway.park27 Well-Known Member
    Al
    CT
    09 TRD off road access cab
    Front and rear Weathertech floormats, ImMrYo Rear-View Mirror Bracket, anytime fog lights, always on cigarette lighter & power outlet mod, center console and glovebox organizer, LED map and dome lights, Flyzeye LED, Fumoto oil drain valve, FT-8800 ham radio, tailgate theft mod
    Very nice job. I like!
  3. May 27, 2012 at 3:09 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Duck's Ditch, SC
    2011 DCSB 4x4 SCed
    TRD Blower, Ham Radio
    for the lazy like me
  4. May 27, 2012 at 4:16 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    nice, i trimmed mine the same way. i think it looks better and still keeps rocks and mud from hitting the body.
  5. May 28, 2012 at 9:15 AM
    tktv
    tktv Member
    Tom
    Back Here/Not There Anymore
    08 SR5 DC 4x4, 6sp manual. Stock for now.
    Nothing...yet. ;)
    good stuff. i'm looking at doing the same with mine (or just completely removing the front flaps).
  6. May 28, 2012 at 9:57 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I shortened the fronts by 4" and the rears by 1" to keep them from scraping before I lifted it 3" and now wish I hadn't.
