mud flaps, which are best for tacoma with 17 inch wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by twoputz, Oct 10, 2020.
  1. Oct 10, 2020 at 1:02 AM
    twoputz
    twoputz [OP] New Member
    Marcus
    2020 taco SR5 2WD
    Looking to do a mud flap mod for my third gen. I have 17 inch wheels (Method) and the tires stand out a bit. Don't know if oems will be wide enough. Any suggestions?
  2. Oct 10, 2020 at 7:50 AM
    spin180
    spin180 Well-Known Member
    WNC
    2022 Army Green TRD Off-Road DCSB
    There's a good chance you'll rub with the OEM mudflaps. REKGEN or RockBlockz will likely be your best options. Both use factory mounting locations and are made such that you can adjust their position for better coverage with larger tires or wheels with more offset.
    I have REKGENs on my truck; very happy with them. Either should serve you well.
  3. Oct 10, 2020 at 8:34 AM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    I'd stay away from the OEM one's. Yes they look pretty good, but they are made out of a hard plastic. If you really want them, I have a full set that I took off at 2k miles when I did my lift and wheels/tires. Put RokBlokz on the rear. Don't have any flaps in the front anymore.
  4. Oct 10, 2020 at 9:06 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I use Rockblokz extended (1" wider than stock). Any less width and mud/rocks are bouncing off the sides of the truck....
    I've got 2nd gen rims on my truck on 265/65/17 duratrac tires.
