mud flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hanrock, Nov 14, 2014.
  1. Nov 14, 2014 at 5:56 PM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    what has any one found for replacement flaps that would fit my 2012 dc lb 4x4 the originals had a few cracks from before now with the new grabber at2 they have pounded holes right through the rears it has been cold lately -25 in the morning something a little more rubbery would probably be best. i drive 50 k of gravel every day to work
  2. Nov 14, 2014 at 6:19 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
  3. Nov 14, 2014 at 6:22 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    I agree. I had both weathertech and husky. The husky has better material and hardware.
  4. Nov 14, 2014 at 6:23 PM
    NoH8Da808
    NoH8Da808 Member
    Kalani
    Kauai, HI
    2010 MGM TRD Sport DCSB 4x4
    TRD CAI, 6" ProComp Stage 2, 18x10 Moto Metal 962 Black, Nitto Trail Grapplers, Jungle Fender Flares, RokBlokz Mudflaps, Wet Okoles, Ultragauge, Huskyliners, Light Racing UCA
    RokBlokz.com they are flexible and they have a short version. Specifically made for the Tacoma, uses oem mounting holes and have side to side adjustability. A little pricey but they work and look great.
  5. Nov 14, 2014 at 6:59 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I have these in my Amazon Wish List. I'll get them soon - only because the stock flaps are gaudy and ugly.
  6. Nov 14, 2014 at 7:58 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I have Rally Armor on my car and have loved them since I got them. The Urethane ones are expensive but totally worth it. They're soft enough to be flexible and not break when they have to bend, but thick enough to hold up and not tear or flap constantly.
    I don't know if the universal ones fit the tacoma well, but I'd definitely look into it.
    http://www.rallyarmor.com/index.php...6_168?osCsid=6147366018221be37d7b739a2af95808
  7. Nov 14, 2014 at 8:12 PM
    BeBeep
    BeBeep Still Plays With Cars, Trucks, Bikes & Guns
    Bob
    NRH, TX
    15 DCSB TRD Sport PreRunner
    TRD Exhaust, Gentex Mirror w/ Homelink, Autodim, Temp & Compass, Pop & Lock Tailgate Lock, Toyota Bedmat, Underhood LED Lighting Toytec Ultimate 3" lift w/3 Leaf Progressive Rear Springs (overload spring removed), Hypertech Speedo Calibrator
  8. Nov 16, 2014 at 12:41 PM
    danno85
    danno85 New Member
    Dan
    Wisconsin
    2005 Toyota Tacoma DoubleCab Long BoTRD Sport
    Tonneau Cover
    X2 for the husky liners. I have them with grabber AT2's in a 265/70/17 and have worked great.
  9. Nov 16, 2014 at 5:29 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    I run straight up rubber on my rig with no issues thus far. Got them on Amazon for about $30 a pair. Had 2 of the OEM stiff-long flaps break off, front passenger in snow and the rear driver while wheelin. Dumped them for rubber and no lookin back.
  10. Nov 16, 2014 at 5:35 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I took my front ones off when I got the 285's, they rubbed. Are the Weathertech's a different fit in any way from factory?
  11. Nov 16, 2014 at 6:26 PM
    single cab
    single cab Well-Known Member
    upstate ny
    2012 Single cab 4x4 mt
    i have the huskyliners and love them and they look a lot better then the junky stock ones
  12. Nov 16, 2014 at 6:33 PM
    ThomasMore66
    But will my 285's hit them? I'm running a full 3" lift.
